Toymods » Tech & Conversions » efi start up,
ta2272
efi start up, Sat, 17 July 2004 08:39 Go to next message
just putting efi on my 2tg and ay the moment i havnt got it started, im about to go down and check dizzy timing and try check if im getting fuel of the injectors, (which im unsure if i can do it) it has a microtech ecu and the lights and stuff are lighting up, just wondering if anyone owuld have somthing to help me get it going.
Jason
Re: efi start up, Sat, 17 July 2004 11:22 Go to previous messageGo to next message
An engine needs two thing to start: fuel and spark. Spark is easy enough to check, and with fuel injection it's easy to tell if the injectors are working because you can hear them clicking as the engine cranks over. A screwdriver to the ear helps if you can't hear them over the starter.
The other thing to check is the fuel pressure, which should be a constant 30-35psi at the fuel rail. Provided you have correct fuel pressure and the injectors are clicking, the engine will be getting fuel!
AE86slut
Baulko Hillo
Re: efi start up, Sat, 17 July 2004 13:07 Go to previous messageGo to next message
And don't forget to double check your vacuum lines and stuff too to make sure they are all connected or blocked.
You might want to have a can of aerostart (sp) handy too, but shouldn't need it if everything is connected properly.
ta2272
Re: efi start up, Sun, 18 July 2004 11:37 Go to previous messageGo to next message
i can hear the the ticking noise from my injectors, wondering if i have the right fuel pressure the pump is pumping,( i only hav eon fuel pump which is placed in the engine bay of my ta22)no surge tank. is there any way i can test my pump has right pressure and the injectors are working?
Jason
celicaboy
Re: efi start up, Sun, 18 July 2004 11:44 Go to previous messageGo to next message
are you using a electronic fuel pump? if so is it a high pressure one or a low pressure one?
the electronic fuel pump works best as close to the tank as you can
ta2272
Re: efi start up, Sun, 18 July 2004 11:45 Go to previous messageGo to next message
Using a vl high pressure pump which is in the engine bay.
celicaboy
Re: efi start up, Sun, 18 July 2004 11:50 Go to previous message
put a fuel pressure guage on the lines after the pump and before the fuel rail and check the pressure...... the vl pump should be giving it good pressure i am using one of them to, on both of my cars... if you cant get a fuel pressure guage take the line off and put it into a 600ml bottle and see how long it take to half fill when cranking over... if it takes forever to fill half way then your pump is lazy
Previous Topic:2tg firing order,
Next Topic:3t oil pressure problems
Current Time: Sat Oct 24 07:50:16 UTC 2026
Total time taken to generate the page: 0.0047709941864014 seconds
