Toymods » Tech & Conversions » Heat Shielding......
Spanktown
Inside a giant turbo (syd...
Heat Shielding...... Sat, 17 July 2004 09:01 Go to next message
Hey guys i recently turboed my aw11 mr2. The problem is the exhaust manifold sits very close to the old heat shielding thats on the firewall currently, and due to the heat of it it has made it brittle and it is gradually falling away. What options do i have as far as this goes? or what would be the best?
Re: Heat Shielding...... Sat, 17 July 2004 11:12 Go to previous messageGo to next message
You could get the manifold and turbo housing HPC coated. Not cheap but very effective at keeping the heat in. Looks good too!
Spanktown
Re: Heat Shielding...... Sat, 17 July 2004 12:07 Go to previous messageGo to next message
that would be the best option, but yes its exspensive, i was an oversight before installing it all. I was more looking at quick solutions i can just slap in there for the mean time...
fade-e
Re: Heat Shielding...... Sat, 17 July 2004 12:36 Go to previous messageGo to next message
if the heat sheild is a metal plate then just put another one there on top of the current one and pop rivet it in
now thats a quick for ya...
Re: Heat Shielding...... Sat, 17 July 2004 14:39 Go to previous messageGo to next message
Well you did ask "what would be best", not "what would be cheapest". Smile
As above, a quick and easy solution is a metal heat shield. If you're really cheap you can go to the wreckers and look for something that might fit. A lot of cars have heat shields above the catalytic converter, so you might be able to adapt something like that.
BlackSupra
Re: Heat Shielding...... Sat, 17 July 2004 23:37 Go to previous messageGo to next message
exhaust wrap is also a possibility
Re: Heat Shielding...... Sun, 18 July 2004 01:38 Go to previous messageGo to next message
at uni recently we got some large sheets of woven ceramic matting to use for some of our furnaces...
i can't remember what it was made from (but can find out) but it is meant to be good for 1200-1300C (compared to the exhaust wrap which melts around 600C).
we got mats that were about 1m wide and abotu 2m in length... and is very flexible...
i'll find out what it was..
Spanktown
Re: Heat Shielding...... Sun, 18 July 2004 03:38 Go to previous messageGo to next message
the 'heat shield' thats currently there isnt a metal shield, its more insulation similiar to that thats on the bottom of most normal cars bonnets. Yeah that would be great if you could find out old corrolla. Im thinking most of the damage thats currently there on the heatshield happened when it was on the dyno, with hardly any airflow.
EVOSTi
cambo
      no
Re: Heat Shielding...... Sun, 18 July 2004 10:12 Go to previous messageGo to next message
yeh i was thinking something similar for my turbo conversion, the turbo sits just above the starter motor which couldnt be too good for it, and theres notmuch room for shielding, which also means not much distance for the heat to travel to it haha.
Spanktown
Re: Heat Shielding...... Sun, 18 July 2004 12:00 Go to previous messageGo to next message
just as a quick fix, i put some fire resistant fibre cloth inbetween the firewall and exhaust manifold.
Re: Heat Shielding...... Mon, 19 July 2004 02:09 Go to previous message
okay
the company that provided the cloth is Bellis Australia. main office is
171 musgrave road, coopers plains, QLD 4108, (07)32778988
or sydney is
Unit 21
566 Gardeners Road
Mascot NSW 2020
(02) 9317 2888
email: sales@bellis.com.au
http://www.bellis.com.au/thermfab.htm
(they even list "turbo covers" as one of their products!!!!!)
the material is
TTP287 Bellis Ceramic Cloth -SP-3E
Quote:
Bellis TTP287 is a heavy duty Ceramic Fibre Fabric with a special 304 Stainless Steel wire reinforcing. Designed and manufactured for high temperature industrial applications, which require stability, flexibility, strength and thickness. Maximum continuous temperatures up to 1000 C degrees.
Thickness = 3mm
Width = 1000mm
weight/sqm = 1500gms
manufactured by "Nippon Steel Chemicals Co. Ltd.
cost is around $50 per square metre.
Previous Topic:2T Choke issues
Next Topic:Diff ratios for sprinter
Current Time: Fri Oct 23 20:28:47 UTC 2026
Total time taken to generate the page: 0.0055239200592041 seconds
