Toymods » Tech & Conversions » 4A-GTE, Aftermarket ECU
dorikin ichiban
Auckland, New Zealand
4A-GTE, Aftermarket ECU Tue, 10 September 2002 21:53 Go to next message
For the people running a large port head with the AE86 Intake Manifold.
How many of you run the Cold Start Injector or Use the Intake Air Temp sensor?
For those running GZE blocks
Do you use the factory knock sensor at all?
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 00:48 Go to previous messageGo to next message
As mine runs on LPG, I can't use the CSI, but I use a Delco air temp sensor in the intake pipe, and Haltech IG5 doesn't have an input for a knock sensor... I'd suggest you use a temp sensor, forget the CSI and knock sensor, tune it properly and it should be fine anyways. After all, what really is the use of a CSI if you work out the cranking/cold running fuel map properly?
Grega
melbourne.victoria.austra...
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 00:52 Go to previous messageGo to next message
should remove the CSI mrshin and replace it with a nos fogger? Smile
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 00:53 Go to previous messageGo to next message
Damn.... knew I'd forgotten something when I got that hole welded up!
dorikin ichiban
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 01:32 Go to previous messageGo to next message
hrm nos...
Hey on a quick note, on the rear water outlet (on the back of the head) what is the 2nd plug for? I know one is for the water temp sensor.
mrshin: what inj are you running?
[Updated on: Wed, 11 September 2002 01:33]
Grega
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 02:53 Go to previous messageGo to next message
cold start injector time switch dude.
dorikin ichiban
Re: 4A-GTE, Aftermarket ECU Wed, 11 September 2002 03:19 Go to previous messageGo to next message
Does anyone know if the 3S-GTE has a cold start injector?
Karl_skewes
New Zealand
Re: 4A-GTE, Aftermarket ECU Sun, 15 September 2002 10:37 Go to previous messageGo to next message
every EFI car runs a cold start injector.
Other plug is thermotime injector switch. When car is cranking power is fed to it, and if the temp is cold enough, it will send power to CSI. Apparently runs for 7 seconds or so on 2TGEU. But i reckon more like just the time it takes to start the motor.
However, if you just set up your fuel map so that below 500rpm or so it runs hell rich, then you wouldn't need to use a CSI.
Grega
Re: 4A-GTE, Aftermarket ECU Sun, 15 September 2002 19:58 Go to previous messageGo to next message
karl, not every car runs a cold start injector. most toyotas do i know that much.
some cars have fuel maps programmed for cold start enrichment - so that when things are cold they run rich as buggery until things warm up a little..
Karl_skewes
New Zealand
Re: 4A-GTE, Aftermarket ECU Sun, 15 September 2002 22:31 Go to previous messageGo to next message
temperature enrichment coefficient..... Actually built into all Toyota ECUs. Enriches standard map and extra enrichment on throttle..... as you say........ really really really rich.
Well, All Toyotas that I've seen have CSI.
ae102_3sgte
Canada
Re: 4A-GTE, Aftermarket ECU Mon, 16 September 2002 03:19 Go to previous messageGo to next message
Most newer versions of engines fitted to new models after about 1992 do without the cold start injector.
There are exceptions though.
Statts
Adelaide, SA
Re: 4A-GTE, Aftermarket ECU Mon, 16 September 2002 11:41 Go to previous messageGo to next message
I am currently building a 4A-GTE based on a 4th gen 4A-GZE (map, coil pack, hich comp)
I am using RWD manifold, and will be using Haltech E6K
TE72_Turbo
Re: 4A-GTE, Aftermarket ECU Mon, 16 September 2002 12:55 Go to previous message
Statts: Did you empty my garage, or are you doing exactly the same as me! Very Happy
I also have a late high comp 4AGZE, Haltech E6K & RWD intake manifold.
Have you made up an exhaust manifold already? I'm about to get started...
BTW: Why would toyota tune their EFI cars to run super rich when cold??? What could possibly benefit from that? Do you think that they might rather be compensating for the fact that the fuel mixture tends to 'stick' to the cold walls of the intake manifold & ports, therefore resulting in a lean mixture unless they compensate with a cold start injector? Throttle pump values also need to be increased with a cold motor.
Previous Topic:r34 GTR intercooler in a ra23
Next Topic:st-gte ta63
Current Time: Thu Oct 22 10:51:10 UTC 2026
Total time taken to generate the page: 0.004802942276001 seconds
