Toymods » Tech & Conversions » Radiator problem on st162, found temp solution!!!
TRD-ST162
Radiator problem on st162, found temp solution!!! Sun, 18 July 2004 07:26 Go to next message
Hey,
My radiator has this wierd arse problem, apart from the fact that its leaking somewhere else, the main problem was the top tank on my car. Why did they have to make one of the hottest components out of hardened plastic... Sad Sad
This happens!!!!
http://img18.exs.cx/img18/2231/badradiator.jpg
It has a crack in it, when the car gets hot it will slowly drip out. The thermo fans come on quite a bit, even when the car isn't given a bit more of a brisk drive!!!
http://img18.exs.cx/img18/3503/tempfix.jpg
I got through for a while with some electric tape covering the leak. It was working for a while.
It was nearly off today, so i decided to try somethin else, got some SELLEYS ALL FIX or whatever its called, covered the area, and then applied a few pieces of 100 mile an hour tap to seal it up and help the SELLEYS hold together, hopefully it works...
I'm just trying to find the money to buy another radiator...
Regards
Adrian
[Updated on: Sun, 18 July 2004 07:27]
people100
Rocklea qld
Re: Radiator problem on st162, found temp solution!!! Sun, 18 July 2004 08:52 Go to previous messageGo to next message
U dont need a new rad. You can get a new tank put on for around $120 plus GST from your local rad shop.
TRD-ST162
Re: Radiator problem on st162, found temp solution!!! Sun, 18 July 2004 10:02 Go to previous message
I think the bottom of the tank is leaking too...
At the wreckers they usually have them for about $130 with a pressure test and flushed...
Still unsure..
If i got the new top tank i'd still have to do the rest of it eventually
Regards
Adrian
Previous Topic:New Corolla engine Vs 4age comments
Next Topic:timing out of wack
Current Time: Fri Oct 23 21:17:00 UTC 2026
Total time taken to generate the page: 0.0055480003356934 seconds
