Toymods » Tech & Conversions » KE20 DIFF CHOICES, I NEED HELP
1973_KE20
KE20 DIFF CHOICES, I NEED HELP Sun, 18 July 2004 10:22 Go to next message
Hey, i am currently putting a 4AGE into my ke20 and i have a sprinter diff that looks like it will be too wide(it is 95mm wider than the stocker). I have been told i will need 25mm spacers each side when i buy wheels, so a diff that is 50mm wider than a stock ke20 one would be ok but i dont wanna get anything wider than that and i dont want to have to shorten a diff.
Dodgy_Haro
Re: KE20 DIFF CHOICES, I NEED HELP Sun, 18 July 2004 10:40 Go to previous messageGo to next message
Hmmm ... if you're after a perfect fit, you'd have to shorten the sprinter diff, no easy way around it. Is it a T or S series diff?
Also, you'll have to upgrade your hubs at the front to 114.3 PCD studs, otherwise you'd be fitting sprinter wheels at the rear and keeping KE20 wheels on the front, unless the front's not stock.
As for spacers, what's important is the offset of the wheels. I am assuming by 25mm spacers you mean the front only because the rear will stick out more with the Sprinter diff?
Don't forget, you may have to get flares if they extend beyond the fender lip.
1973_KE20
Re: KE20 DIFF CHOICES, I NEED HELP Sun, 18 July 2004 10:51 Go to previous messageGo to next message
not sure on the series of the diff sorry, i have front sprinter struts also, so thats no a problem. when i said i need spacers i mean i need spacers for the stocko diff not the sprinter, so they are saying i need an extra 50mm of width to make the wheels look proper, so i need a diff that is 50mm wider than a stock diff or anything shorter than that, that will put up with a 4age. The sprinter diff i have is 95mm wider, so technically it is 45mm too wide. Please name some alternatives to a sprinter diff.
Pube
Camden
Re: KE20 DIFF CHOICES, I NEED HELP Sun, 18 July 2004 13:21 Go to previous messageGo to next message
how about a Ford 9 inch Very Happy
DJ345
eastern suburbs, Melb
Re: KE20 DIFF CHOICES, I NEED HELP Sun, 18 July 2004 13:23 Go to previous messageGo to next message
Id be trying a t series TA22 celica diff.
schnitzel
Bendigo
Re: KE20 DIFF CHOICES, I NEED HELP Mon, 19 July 2004 05:00 Go to previous messageGo to next message
When I had my KE20 I used the wider KE55 diff,but is not great solution have heard of ta22 being put in but don't think that would necessarily be much better. Just but be careful with the fronts my biggest hassle was making the strut tops fit as KE20 was different to later models, but definetly made it easier getting wheels etc with bigger PCD
SeptemberSquallIndustries
Re: KE20 DIFF CHOICES, I NEED HELP Mon, 19 July 2004 05:22 Go to previous messageGo to next message
If your present wheels are low (ie. RWD) offset, try a pair of FWD offset (ie +35) on the rear. Increasing wheel offset by 20mm will nullify 40mm of differential width.
Super Jamie
On Probation
North East NSW
Re: KE20 DIFF CHOICES, I NEED HELP Mon, 19 July 2004 13:16 Go to previous message
conversion page in my faq may have some ideas for you
http://www.superjamie.net/oldcorollas/
basically: T series, F series, G series hilux, r31 skyline, mazda RX
you could probably use an S series from a ke70, or T series from a T18 without shortening. maybe. the stock diff will last for ages with a stock 4ag, nikki (as in fast fours Rollie nikki) used to give hers heaps of shit and hers was a stock ke55 borg warner. not sure if they have more splines than ke20/30 jap diff, but they probably do
Previous Topic:7mge...wheres the intake air temperature sensor?
Next Topic:RA60 Conversion's ?
Current Time: Wed Nov 18 20:54:10 UTC 2026
Total time taken to generate the page: 0.0048370361328125 seconds
