Toymods » Tech & Conversions » crank angle sensor (4age)
45aken
NSW.south coast.Drifting
crank angle sensor (4age) Sun, 18 July 2004 16:28 Go to next message
hello there,
im putting a microtech ltx8 on my 4agte bigport 86kw and was wanting to use multiple coils instead of the dizzy (direct fire system isn't it?). just wondering if the crank angle sensor off a 100kw 4age or 4agze will fit, or if not: what others will, or/and what else do i have to do?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: crank angle sensor (4age) Sun, 18 July 2004 21:23 Go to previous messageGo to next message
You can chop off 3 of the teeth on the top wheel in the dizzy, the 2, 3 & 4 cylinders teeth, leaving of course the no. 1 cylinders TDC reference. As far as I understand, the GZE CAS has only one tooth on it's wheel but 2 sensors sitting opposite each other, plus the same 24 tooth single sensor wheel underneath, but the microtech is only wired up to one of the top sensors, so with your dizzy modified as above, you should be sweet.
That's what I did to mine to use with a microtech, but now I'm going to use an Autronic ECU & CDI unit instead, & that also can be wired up to the standard dizzy with this mod.
FKN16V
NSW, East Coast
Re: crank angle sensor (4age) Sun, 18 July 2004 23:50 Go to previous messageGo to next message
I remember someone using the crank angle sensor from a series 4 rotory, i maybe wrong thou, not very good with ecu's, just trying to throw some ideas around.
Steve
tsbb1
North Qld
Re: crank angle sensor (4age) Mon, 19 July 2004 00:56 Go to previous messageGo to next message
. l run a Microtech with four coils the dizzy is used.as the crank angle sensor.No cutting of teeth ...um trying to think how we did it.... it was quite simple ...Just removed a couple of bits from the dizzy l think it was the magnets ... could be wrong ... Will get back to you
45aken
Re: crank angle sensor (4age) Mon, 19 July 2004 14:27 Go to previous message
thanks for your help guys,
i was thinking removing the dizzy completly, as it may interfere with the turbo/mainfold.
what are the major advantages of using this multicoil system?
Previous Topic:engine mounts gone
Next Topic:7mge...wheres the intake air temperature sensor?
Current Time: Wed Nov 18 20:21:19 UTC 2026
Total time taken to generate the page: 0.0064218044281006 seconds
