Toymods » Tech & Conversions » Quick boost mod for 3S-GTE
dwango
Quick boost mod for 3S-GTE Mon, 19 July 2004 02:47 Go to next message
http://www.geocities.com/MotorCity/7177/3s-gte_boo stmod.html
I jst wanna know if anyone had tried this and had success or not.
And if so can they give me a little more detail about the underlying fundamentals
spectral
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 03:10 Go to previous messageGo to next message
biggest problem is that its a royal PITA to get to the turbo VSV on the back of the block.
You can get second-hand manual boost controllers for about $50 now, so it makes more sense to just buy that and fit it, rather than trying to pull on and then reinstall the VSV.
Still do the diode mod thou if you want to run higher than 12psi thou.
[Updated on: Mon, 19 July 2004 03:11]
ra23celica
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 03:22 Go to previous messageGo to next message
The underlying fundamental principle in that boost mod was that when the ECU says 'yes, good conditions now, lets go play' a higher boost level than the factory limit is allowed as the VSV has been drilled out to a greater diameter and it lets a higher pressure level be held before the wastegate opens. You still need to do the diode mod to beat the fuel cut.
If you really want what the title of your e-mail says, why don't you see if you can fit some thicker washers on the mounting bolts of the wastegate actuator arm, so that the distance that it opens through is reduced therefore if will see higher boost before it swings open.
Mitch.
dwango
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 03:23 Go to previous messageGo to next message
I have a top mount intercooler. I sit nessesary to modify it to a front mount for this much boost increase.
ra23celica
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 10:57 Go to previous messageGo to next message
No.
Classique71
Colac, Victoria
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 11:47 Go to previous messageGo to next message
just a word of advice - dont try any " cheap quick or easy " mods on the 3sgte without REALLy looking into them ..
3sgte's are not cheap to repair if you fuck them up - so play it safe before doing anything to the motor your not sure about
dwango
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 12:38 Go to previous messageGo to next message
Hey, thats why i'm here.
ra23celica
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 13:47 Go to previous messageGo to next message
And on that note, and something I should have said ages ago.....your very first ever mod on a turbo car is to fit a good boost gauge. Every time.
Mitch.
dwango
Re: Quick boost mod for 3S-GTE Mon, 19 July 2004 14:01 Go to previous messageGo to next message
I don't have a bov either. i was waiting to see whether i should move the intercooler to the front of the car 1st
celicamad
newcastle
Re: Quick boost mod for 3S-GTE Tue, 20 July 2004 12:36 Go to previous message
i have fitted a boost contoller to several gt4's.
the best result is to disconnect the vsv altogehter .block the fittng's going to it .
a simple pot and two 1k diodes handles boost cut fine .
leaving factory controlled boost intact gives little control over boost .
then you can fit a controller from there .
the factory wastgeagate suffers BADLY from creep so adding a wastegate control makes all the difference .
i cant remember boost levels for 185 but on an st205 group a we ran 17 psi no probs with boost coming on flat out until 15 psi .
Previous Topic:turbo seals after a year of no use?
Next Topic:where to buy firewall grommets
Current Time: Wed Nov 18 13:13:10 UTC 2026
Total time taken to generate the page: 0.0060579776763916 seconds
