Toymods » Tech & Conversions » Engine vibrations - rebuild started
Engine vibrations - rebuild started Mon, 19 July 2004 03:13 Go to next message
Hi all, ages ago now I had a thread about how my 3T-GTE powered RA28 gets some seriously annoying vibrations over 3500rpm.
At that point I was suspecting drivetrain and lately have been mucking around with different tailshafts etc.
Anyhow.. After more testing it definately isn't drivetrain related as if the car is stationary, foot on or off the clutch, soon as you hit around 3500rpm all the way to redline there is a vibration you can feel.
Everything that isn't bolted down tightly rattles and shakes, you can feel it through the seat and especially the accelerator peddal.
Its a very fine vibration though and not like a big lumpy one.
Engine has been balanced including flywheel, pulley etc around 30,000 km ago now.
Wanted to start this thread again to get some suggestions as its really starting to piss me off to the point of wanting to pull the engine out and fit something else. I basically change gear now before it hits 3500rpm so I don't have to put up with it. But a turbo engine under 3500 is a bit average!
The 4AGE engine in AE86 I have you can basically cruise along at 6500rpm and its smooth as silk. I want something like this! Smile
Can the turbocharger itself cause vibrations? I'm wondering if that is out of balance.. Just seems such a hard thing to track down as its the 'whole' engine that seems to vibrate and very hard to know where exactly its coming from.
Well thanks all for any suggestions and putting up with this rant Smile
Joel
[Updated on: Tue, 07 September 2004 12:16]
Danners
Central Coast, NSW
Re: Engine vibrations, more questions! Mon, 19 July 2004 03:21 Go to previous messageGo to next message
engine mounts?
Dan
Re: Engine vibrations, more questions! Mon, 19 July 2004 03:38 Go to previous messageGo to next message
Definitely not the turbo; it would have to be a large component with a fair amount of mass to cause the symptoms you describe. My first guess would be flywheel or crank pulley, but if they've been balanced as you say it must be something else. Another thing to check is your clutch - I bent the pressure plate in my Supra a while back (accidentally selected 2nd instead of 4th on the freeway Embarassed ) and it caused nasty vibrations like you described.
Re: Engine vibrations, more questions! Mon, 19 July 2004 03:42 Go to previous messageGo to next message
Thanks for ideas so far.. I should have mentioned that I replaced the engine mounts with brand new items only a few weeks ago and they made no difference.
Norbie - maybe I should be pulling the gearbox out Sad .. Did you have any other symptoms after bending the pressure plate?
Re: Engine vibrations, more questions! Mon, 19 July 2004 03:46 Go to previous messageGo to next message
Apart from the car vibrating whenever the engine was running, no.
Re: Engine vibrations, more questions! Mon, 19 July 2004 03:49 Go to previous messageGo to next message
Hmm very interesting.. Thanks. It's worth a try then. Might as well get the flywheel balanced again as well while it is all out.
Re: Engine vibrations, more questions! Mon, 19 July 2004 04:31 Go to previous messageGo to next message
when you say whole engine was balanced, what exactly and to what degree?
my experience with K motors has been that almost all of them have sort of resonant vibrations at a couple of points in the rpm range (like 4000 and 6000), but one motor i picked up had a slight vibration all the way thru..
it wasn't a nasty one, just something you could notice..
when i pulled it down to balance it, one of the big end bearing caps was out by 7 grams!!! the pistons and pins were within 2 grams..
i balanced rods total and end for end, and piston/pin assembkly, all to within 0.1 grams (overkill i know) and now there is no annoying vibrations at all..
if you feel like pulling the motor down, i could weigh the bits for you to 0.001grams.....
reminds me i need to buy a scale ( "yes occifer, it really is for weighing engine parts")
Re: Engine vibrations, more questions! Mon, 19 July 2004 06:54 Go to previous messageGo to next message
Mate I can't tell you exactly how it was all balanced. When I rebuilt it Graham Wilkins did the machine work, I gave him crank, rods, pistons, pulley, flywheel, pressure plate to balance.
I am kinda tempted to strip it down. Soon i'll be putting in some head studs that YelloRolla is organising. So it's already half way there I suppose.
Can't hurt to give it all a freshen up.
I'll see how I go mate, thanks very much for the offer!
AE86slut
Baulko Hillo
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:05 Go to previous messageGo to next message
Well, I guess there is always that thing called 'human error'. You never know, perhaps something was not balance correctly. Not saying anything about people's skill or anything, just the old 'human error'.......
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:11 Go to previous messageGo to next message
Nah you are right mate..
When I originally brought the 3t-gte it was auto so had to find a flywheel for it. I found one down in melbourne from a reptutable shop, the guy sold it saying it was balanced & lightened.
I ran the flywheel for a few years and engine felt smooth as. then when I rebuilt the whole engine, the shop who balanced it said they had never seen a flywheel so far out of balance before.
First thought was shit, that place I brought it from did a dodgy job. Then I thought, hmm what happens if the place balancing it this time didn't set it up right etc etc.
So yeah could very well be human error involved. Thing is though when the engine was first rebuilt it all felt good, then as I slowly did upgrades (turbo, manifolds, etc) somewhere along the way it developed the vibration but i cannot pinpoint when it happened exactly as it seems its more slowly happened and got worse.
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:13 Go to previous messageGo to next message
Also should mention after it was rebuilt it made 85kw at the wheels, now its closer to 170kw.. so everything has been put under a lot more strain.
AE86slut
Baulko Hillo
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:18 Go to previous messageGo to next message
How long ago was it rebuilt? How much boost are you running? Should the motor be pretty strong internally?
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:25 Go to previous messageGo to next message
Was rebuilt getting close to 30,000km I reckon. Maybe 20,000...
Running 20psi boost. Has forged pistons, heavy duty valve springs.
AE86slut
Baulko Hillo
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:27 Go to previous messageGo to next message
20psi constantly?
Could be your g'box too I guess..... It's a vibration - Could be anything!
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:32 Go to previous messageGo to next message
With the clutch in, vibration is still there so I think that rules out the box?
Yeah could be heaps of things .. I might start with the flywheel/clutch as thats only half a days work or so. If that doesn't help then strip the engine down and take Oldcorollas up on his offer to weigh the components.
I didn't realise you weighed bearing caps?
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:39 Go to previous messageGo to next message
you don't usually...
usually you weigh them for total weight, and also for big end and little end weights (pivoting at the other end)..
when i did this, one rod was 7-8g total out, and big end was about the same, so i pulled off all the bearing caps, and one was totally different in weight... 7grams more!!
this was in a never pulled apart motr, so it must have been like that from factory! the cap was a slightly different casting (thicker ribs)....
so ya never know Wink
for you i'm hoping it is just the flywheel! Good Luck!
Re: Engine vibrations, more questions! Mon, 19 July 2004 07:44 Go to previous messageGo to next message
Does anyone know if it might be the pulley, as this is the harmonic balancer right? I never quite understood these.
CelicaRA45
nth ringwood, Victoria
Re: Engine vibrations, more questions! Mon, 19 July 2004 10:30 Go to previous messageGo to next message
sounds like a presssure plate let go maybe have you any holes in the bellhousing cause they are only cast
Re: Engine vibrations, more questions! Sat, 24 July 2004 01:55 Go to previous messageGo to next message
Howdy, well I just finished pulling the box out. Took the clutch and flywheel off also.
Everything was tight, so not something come loose. Visually it all looks ok, but I suppose just by looking at it you cannot really tell.
I'll organise to get the flywheel machined and balanced during the week and put a new pressure plate on and see how it goes.
Is there anything else I should be checking while the box is out?
Joel
Bugman
Re: Engine vibrations, more questions! Sat, 24 July 2004 03:28 Go to previous messageGo to next message
isnt it anice idea to have the flywheel balanced with the pressure plate on it?
TA22
Re: Engine vibrations, more questions! Sat, 24 July 2004 03:51 Go to previous messageGo to next message
what happens when u get a new clutch? rebalance it again?
should be fine to balance jus the flywheel
Re: Engine vibrations, more questions! Sat, 24 July 2004 04:18 Go to previous messageGo to next message
Yeah in the past the pressure plate and flywheel have always been balanced together..
So i'll give whoever is doing the job the flywheel and pressure plate.
TA22-3SGTE
MACKAY
Re: Engine vibrations, more questions! Sat, 24 July 2004 12:01 Go to previous messageGo to next message
Sounds like engine harmonics as you said when it was first built there was no vibration but as you upgraded with turbo and manifold ect it then got a vibration in it , when you modify a manifold and fit a different turbo you then have the weight of the turbo and manifold sitting out further, higher or lower and maybe heavier which can amplify the natural harmonics of the motor , To fix this you need to make a couple of good sturdy stays from the turbo to the bottom of the block this also applies to the inlet side and also check for cracks in the alternator bracket or adjuster .
Trevor
Re: Engine vibrations, more questions! Sat, 24 July 2004 23:34 Go to previous messageGo to next message
Thanks for that idea Trevor, i'll definately give that a go. How thick would you suggest the metal be for the supports?
Joel
TA22-3SGTE
MACKAY
Re: Engine vibrations, more questions! Sun, 25 July 2004 05:12 Go to previous messageGo to next message
Something fairly rigid , I used 25mm RHS with 8mm plates welded each end to bolt to the block and turbo , I'v had to put braces on the turbo and plenum and also mount my alternator more rigidly now 99 percent of my vibrations are gone .
Trevor .
Re: Engine vibrations, more questions! Sun, 25 July 2004 10:37 Go to previous messageGo to next message
Thanks, well while the flywheel is off i'll get it checked out anyway.. Then get stuck into some bracing.
It's good to hear you got rid of most of yours.. Maybe light at end of tunnel Smile
Joel
Re: Engine vibrations, more questions! Mon, 26 July 2004 00:32 Go to previous messageGo to next message
Well I dropped the flywheel and new pressure plate in today, they are going to put it in their balancing machine thing and check it all out. They were leaning though to the fact that when the engine was first built it was smooth, and the flywheel shouldn't change really.
In regards to bracing turbo and inlet etc, would it be acceptable to use rose joints on a threaded shaft between them? Only reason I ask this as I cannot weld, and have a few rose joints lying around and figure I could make a brace easily with these. Or would the movement in them stuff up the original aim?
Joel
Steve_Reynolds
Gold Coast
Re: Engine vibrations, more questions! Mon, 26 July 2004 06:04 Go to previous messageGo to next message
Have you dropped the belt off your alternator to discount the alt being the cause??
Get yur pressure plate tested. If a spring breaks, they are hard to see but make a racket (but clutch may also slip as well)
Surely you can narrow down the location of the vibration using the big screwdriver to the ear trick?? ??
Good luck.
Re: Engine vibrations, more questions! Mon, 26 July 2004 06:18 Go to previous messageGo to next message
Mate the alternator idea is good, didn't even think of taking the belt off.
Thanks!
Joel
Re: Engine vibrations, more questions! Mon, 26 July 2004 06:31 Go to previous messageGo to next message
Thanks!
Joel
stupid computer.. sorry about double up.
omegaman
SYDNEY
Re: Engine vibrations, more questions! Mon, 26 July 2004 07:32 Go to previous messageGo to next message
Nobody has mentioned the thrush bearing in the crank/flywheel for the box to fit in, could this be a reason for vibration, I would think so.
Re: Engine vibrations, more questions! Thu, 29 July 2004 23:52 Go to previous messageGo to next message
I picked up the flywheel and stuff today, they said the old pressure plate was rooted and could definately have been the cause for the vibration.
But can't be sure until it's all back together.. Will get stuck into it this weekend and fingers crossed that the problem will be gone.
If not, will investigate bracing/alternator/etc
Joel
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 08:09 Go to previous messageGo to next message
Well put it all back together this weekend, unfortunately it wasn't the flywheel/pressure plate Sad ...
On a good note though changing the pressure plate has fixed the problem I had with the clutch picking up so low to the floor. Also have the brass button clutch in there which should stand up to the abuse more. So not all was lost from that job.
Back the the vibrations though....
I spent some time with a screwdriver testing each area of the engine to get an idea where it might be most noticable.
The vibration is definately coming from around the throttle body/front of plenum area.
The plenum is a custom front facing one. Even at the back of the plenum its not as noticeable. But the front is a shocker.
If you try and hold your hand on it almost hurts from the way its vibrating.
There is a rubber bend on the front of the throttle body and then the intercooler piping. There is NO vibration in the intercooler piping.
So whats everyone think? The plenum/runners more so is already braced to the block with the factory brace. Maybe I need another brace around the throttle body? Or is it possibly the throttle body itself, maybe the butteryfly vibrating around?
Joel
SeptemberSquallIndustries
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 10:05 Go to previous messageGo to next message
The throttle body won't be causing the vibration. You notice it most there because it's hanging off the side of the motor and as a result the vobration at this point is most pronounced.
You can brace it to the block if you like but bracing won't cure vibration in the rotating assembly.
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 11:16 Go to previous messageGo to next message
does the 3T have a harmonic balancer from factory? if so, perhaps it's stuffed?
if it's most promonent on the drivers side of motor, are you sure the engine mount on that side is OK?
allencr
tallahassee FL usOFa
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 12:44 Go to previous messageGo to next message
the TB vibe is an effect, not the cause. is its brace & the manifold bolted on tight??
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 15:36 Go to previous messageGo to next message
SeptemberSquallIndustries wrote on Sun, 01 August 2004 20:05
Rolling Eyes
Re: Engine vibrations, narrowed it down. Sun, 01 August 2004 23:31 Go to previous messageGo to next message
Hmm so are you saying I can feel the vibration in the throttle body, but it might not be generated from this area?
Like the rocker cover, even the fuel rail which is attached to the inlet manifold has very little vibration.
I had Graham Wilkins check out the pully/harmonic damper and he gave it a balance and said appears all ok.
Yeah engine mounts are fine almost brand new.
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 03:09 Go to previous messageGo to next message
If the vibration is being generated from a part of the rotating assembly, the further you go from there the greater the vibration will seem to be. It's about leverage.
For a vibration as severe as you say, there must be a relatively heavy component out of balance. There's just no way your wafer-thin throttle butterfly would shake the plenum so hard you can't hold it. In fact, there's no conceivable way the butterfly will shake anything at all.
TA22
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 03:50 Go to previous messageGo to next message
just had an idea
have u actually gone back to basics and checked the tune of the engine
seems like maybe one of ur cylinders is being a little sluggish..
have u cheked the tune.. made sure all the plugs are good, and they got good spark, that ur injectors arent blocked, ur getting fuel and spark.
cuz it could do with that. on idle it might be allright, cuz its jus getting enough, but when u give it a little it gets the shakes....
just an idea..
mik
ChuckLandwehr
Re: Engine vibrations, more questions! Mon, 02 August 2004 09:27 Go to previous messageGo to next message
Joel while you have the gearbox out, think seriously about replacing the input bearing with something a little stronger. Most guys who run the Wxx series behind HP engines change the bearing. Check your local bearing supply shop, if the guys are on the ball they should be able to supply a good bearing at a good price.
regards Chuck.
cseufert
Melbourne Vic
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 10:08 Go to previous messageGo to next message
I dont know too much about the 3T but, my 7M-GE was vibrating like a bitch, and after changeing the timing belt, tensioner spring, and tensioner pulley, it ran ALOT smoother. It was so bad it had almost no power above about 6k. Vibration got bad from 4k.
That engines a chain thou, right?
maybe the chain is stretched, the slippers are worn, or the tensioner is not working correctly. Stiffer valve springs cant help this effect too much.
Oh, and is your Head Gasket still ok? Good o'l headgasket eating 7M, that was also a contributor to the vibration.
and you dont have one of those silicon clutch fans on the front of the water pump do you? there a notorious source of vibration.
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 11:19 Go to previous messageGo to next message
Howdy, thanks all for the more ideas Smile
In regards to the tune etc, its possible, but the fact it can even happen on deceleration with no load at all makes me think it's not that. The engine has heaps of power and apart from the vibration goes well, like no misses or hesitation etc. But I suppose you can't rule anything out completely can you.
The 3T is timing chain yeah.. I tried having a play with the external tensioner just loosing it off a touch and tightening it up a little bit but this had no effect. But the bottom tensioner is internal and works on oil pressure so its possible this is causing it?
I do have heavy duty valve springs in there. Could a vibration be valve related? Or like clearance between cam and valve?
With the headgasket, i've been suspecting a problem with it as seems to be getting pressure in the radiator. So you mentioned a headgasket can cause vibration?!?
I have electric thermo fan so not the clutch fan.
Tonight I tried putting a shitty little brace between the throttle body and head, just to test it and see if any difference. it wasn't a very substancial brace just some 4 or 5mm thick metal bolted to 1 bolt on the throttle and 1 bolt on the head.
Anyway, that took away a lot of the vibration from the throttle body, but still the plenum is just as bad.
I'm wondering if more bracing would help, or is this just a bandaid fix for another problem?
Joel
fade-e
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 12:49 Go to previous messageGo to next message
mate that would definately be a bandaide fix! could also make things worse as you would be utting more pressure and strain on whatever is wrong.
if you bolt it up then whatever the problem would be wont have anywhere to release its strain, hence the vibrations. also it is highly unlikely it is bottom tensioner OR chain as you would hear the chain rattle on startup until oil builds up in tensioner.
so if there is no noise at atart up then its definately not tensioner or chain. the benefit of having a chain is the FACT that you can HEAR it when its stuffed.
this isnt something you hear all the time but when the motor is on, in neutral and you rev over 3500 have you tried holding the tip of the exhaust? i know it would be a bit hot BUT if the exhaust shakes as much as the plenum and as bad as the vibration then it would most probably be something loose (engine mounts, ex/in mani, etc) or overall engine balance off. i know the exhaust always vibrates but make sure it is the same magnitude of vibration.
also the reason it vibrates most at the plenum would be cause it is the least supported part of the engine. when reving can you notise the engine shaking as bad aswell? or is it just a feel and not visual? if its a feel then i would have to go for internal balancing (crank, rods, etc)
510rob
Vancouver
Re: Engine vibrations, narrowed it down. Mon, 02 August 2004 18:16 Go to previous messageGo to next message
perhaps you will have to do the inevitable - open the motor up and weigh all the components, then take the rotating components back to the balancing shop and ask them to spin them up as a double-check of their work which apparently wasn't completed sufficiently last go 'round the ferris wheel
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 01:19 Go to previous messageGo to next message
Well the rear main seal has started leaking now. Talked to Graham about it and he is pretty sure all signs are pointing to a crack in the crank Sad
Looks like a rebuild.... bugger.
fade-e
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 01:30 Go to previous messageGo to next message
or you could look into your 3SGTE Very Happy
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 01:35 Go to previous messageGo to next message
Ahh mate i'd love to finish the 3sgte off and now does seem the perfect time.
It's just that I need at least another 4k to throw at the 3S which I don't have and wont for a long time.
Where as a freshen up on the 3t should only cost $500 or so. I already have a gasket kit for it, just need to find a secondhand crank and get some bearings and some machine work done.
fade-e
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 01:43 Go to previous messageGo to next message
i know what you mean...
where do you get metal head gaskets for the 3TGTE??? or do you still use normal ones
Scorpion
Menai area of Sydney
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 12:11 Go to previous messageGo to next message
Have you double checked your distributor and spark plug leads. Seeing vibration is occurring at higher revs - could be spark is arcing at higher volages from crossed leads, lead to earth or across the dizzy cap. Any chance of trying someone elses dizzy cap and leads ? Could try running the engine with the bonnet up and in complete dark to see if you can see any arcing when rev to 3,500 or higher. Could also be the coil breaking down at higher revs causing engine to misfire and hence vibration.
[Updated on: Mon, 16 August 2004 12:12]
fade-e
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 13:45 Go to previous messageGo to next message
he doesnt use a dizzy, he is running direct fire
Bugman
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 13:51 Go to previous messageGo to next message
and its still making the power.
Scorpion
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 14:40 Go to previous messageGo to next message
Fair enough - could still be spark problem though.
fade-e
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 21:19 Go to previous messageGo to next message
not necessarily cause a spark problem would cause back fire, power loss, car jolts (car jolting back and fourth when accelerating)
but he is only getting the shakes... joel i doubt its going to be a cracked crank but it would most definately need a re-balance of everything
which brings to mind if your gonna get the crank re-done and new bearings (big ends and rod bearings) throughout can you let me know!!! i might get a set with you... actually check your PMs
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 23:32 Go to previous messageGo to next message
Had the car at Graham Wilkins yesturday and now after seeing it first hand he is as confused as I am. Basically has no idea what the cause is..
Looks dismal though if one of the most reputable engine builders can't diagnose it then i've got no chance haha.
He originally thought crack crank, but said normally vibration is a lot worse when you back off.. Where with mine the vibration is there if you are accelerating, decelerating, or keeping it at a fixed RPM.
It does look like I just have to strip the engine down and hopefully once it is all apart something will show up.
Fade-e , mate once I decide what to do i'll let you know incase u want to get some bearings etc as well.. But i'll probably strip it down and give it to Graham to source bearings and machine it all up then i'll assemble it.
Joel
fade-e
Re: Engine vibrations, narrowed it down. Mon, 16 August 2004 23:38 Go to previous messageGo to next message
thats sweet and what i was expecting, but yeah if you can order 2 sets of bearings, get him to do all the work need to bearings and ill pay ya for all of it
EDIT: Confused well my part anyway Very Happy
[Updated on: Tue, 17 August 2004 00:15]
Scorpion
Re: Engine vibrations, narrowed it down. Tue, 17 August 2004 11:51 Go to previous messageGo to next message
Mate, I can tell you a spark problem can cause vibration. The suymtoms you describe occur at low rpm - we're talking 3,500 rpm plus. WTF not my car anyway.
Re: Engine vibrations, narrowed it down. Tue, 17 August 2004 12:52 Go to previous messageGo to next message
could you hook up a microphone, record some noise, and then check with a sound program (like goldwave?) to see what the frequency is? see how it correlates with engine rpm? ie is it at crank speed, half crank speed, or something else?
Re: Engine vibrations, narrowed it down. Tue, 17 August 2004 23:15 Go to previous messageGo to previous message
Scorpion wrote on Tue, 17 August 2004 21:51
Howdy, so are you saying that spark related vibrations occur at low rpm or high? sorry just bit confused there... As with mine it is from 3500 to redline.
Joel
Previous Topic:Nitrous Oxide and 18R-G
Next Topic:7M-GTE emissions set up
Current Time: Fri Nov 20 15:30:40 UTC 2026
Total time taken to generate the page: 0.01357102394104 seconds
