Toymods » Tech & Conversions » turbo seals after a year of no use?
HighRolla
turbo seals after a year of no use? Mon, 19 July 2004 08:44 Go to next message
I'm just got the option of getting a turbo that has been sitting around for about year. Does anybody know how long it takes for the oil seals to go hard in these things, providing it's stored well.
Just don't want to rig it up and find it blowing smoke. Apparently it was fine on the car.
feral4mr2
Bundaberg, Qld.
Re: turbo seals after a year of no use? Mon, 19 July 2004 08:59 Go to previous messageGo to next message
the 1st and 2nd t25 turbo's i got had been sitting awhile, it did smoke a bit and then the seals softened again and stopped.
i think some do and some dont soften back up.
HighRolla
Re: turbo seals after a year of no use? Mon, 19 July 2004 09:26 Go to previous messageGo to next message
hmmm. Interesting, so yours were all good. I think the turbo is about 5 years old..so not really that old, just a little worried about it sitting around, I don't think it's that easy to put in new seals either..I guess every 2nd hand turbo is a bit of a gamble
thanks for the reply feral
TE72_Turbo
Re: turbo seals after a year of no use? Mon, 19 July 2004 09:28 Go to previous messageGo to next message
Soften up? The turbos I've had all have a metal ring seal on the turbine end of the shaft (like a piston ring), and either a carbon or dynamic seal on the compressor side. How can these go hard? Confused They're not like valve stem seals.
HighRolla
Re: turbo seals after a year of no use? Mon, 19 July 2004 09:50 Go to previous messageGo to next message
So it should be fine if the turbo has been sitting around a while?
feral4mr2
Bundaberg, Qld.
Re: turbo seals after a year of no use? Mon, 19 July 2004 12:09 Go to previous messageGo to next message
TE72_Turbo wrote on Mon, 19 July 2004 19:28
is only how it was explained to me.. Embarassed
HighRolla
Re: turbo seals after a year of no use? Mon, 19 July 2004 12:51 Go to previous messageGo to next message
TE72 (Phil is it?) - I remember you had some probs with your turbo oil seals when you replaced valve stem seals on your GZE only to find the turbo was the culprit. Did you fix the turbo up yourself?
Do the oil seals usually wear out rather than go hard then?
TE72_Turbo
Re: turbo seals after a year of no use? Tue, 20 July 2004 12:43 Go to previous message
No, the problem was that the oil return from the turbo was positioned too low in the sump (below the oil level), making it difficult for the oil to exit the turbo, so it found its way past the rear seal instead Mad Excess oil flow to the turbo can cause the same problem also, the bearings are only supposed to be fed a contstant trickle of oil to lubricate them, not swim in oil, hence why some setups need a restrictor in the feed line. Smile Worn seals (as opposed to hardened seals) will also cause oil loss/smoking.
Phil
Previous Topic:ignition system volages
Next Topic:Quick boost mod for 3S-GTE
Current Time: Sun Oct 25 19:06:01 UTC 2026
Total time taken to generate the page: 0.043033123016357 seconds
