Toymods » Tech & Conversions » How to get to T50 top bolts
68rolla
How to get to T50 top bolts Wed, 11 September 2002 07:16 Go to next message
How do you take out the 2 tops bolts to undo the gearbox without taking the whole motor out?
Whould cutting 2 holes in the floor to get to them be a bad thing? because taking the motor out everytime the clutch need replacing or gearbox breaks is going to be a pain.
Also its in a KE10 so theres not alot of room.... Just thought some1 might know a trick or 2?
BigBadBenny
Brisbane, Queensland
Re: How to get to T50 top bolts Wed, 11 September 2002 08:56 Go to previous message
ok the way I normally do them is with a 17mm ring spanner going from the top or you can just drop off the g'box cross member remeber to plug the end or you get showered in oil, and just use a few long extensions with a socket and wobbler.
droping the crossmember off is safe, ok.
this tilts the whole lot downwards to a more accesable angle
Previous Topic:Diffs and TAilshafts
Next Topic:Weird thing happened?
Current Time: Fri Nov 20 12:42:31 UTC 2026
Total time taken to generate the page: 0.0041959285736084 seconds
