Toymods » Tech & Conversions » How to tell Cam's apart
GIN51E
Berowra-Sydney
How to tell Cam's apart Wed, 11 September 2002 07:47 Go to next message
I have an old 18-RC in the backyard and want to check if its the standard cam or a lumpyer cam how can i check?
jazae86
Re: How to tell Cam's apart Wed, 11 September 2002 12:31 Go to previous messageGo to next message
A few idea's:
get a set of vernier calipers or best micrometer but vernier calipers will have more room to move: measure the run out. measure the lobe including entire cam. Take lobe measurement - run out (ie area where no lift) = lift of cam. this would be the published lift from toyota.
For a cam in a motor, you will have to try and get a set of calipers in there. Considering you have 8 lobes, you may get lucky or need to turn over the motor a little.
Jaz
GIN51E
Berowra-Sydney
Re: How to tell Cam's apart Wed, 11 September 2002 21:48 Go to previous messageGo to next message
ok thanks mate Very Happy
Re: How to tell Cam's apart Wed, 11 September 2002 23:43 Go to previous message
If you have access to a dial indicator, then you could set that up with the cam in the head, rotate cam and you will get the exact lift. If you combine that with a degree wheel, you can roughly work out the advertised duration and the duration @ 50 thou.
Previous Topic:7 m engine water drain plug location
Next Topic:MA61 - Too much Vibs @ 140Kph
Current Time: Fri Nov 20 16:01:07 UTC 2026
Total time taken to generate the page: 0.0049121379852295 seconds
