Toymods » Tech & Conversions » Ae86 -> T18 diff Questions
PerformanceCars
Ae86 -> T18 diff Questions Tue, 20 July 2004 03:19 Go to next message
Yes i have searched about this - but is still have questions Smile
If i grab a t18 diff, drum to drum including the t18 tail shaft (Just the 2nd half)? Is that all i need? Will this bolt directly up to the ae86, or will handbrake mounts or anything need to be changed?
also when buying an aftermarket LSD to throw in, do the driveshafts for the T series diffs from the T18 have the same amount of splines as the Jap T series driveshafts?
PerformanceCars
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 03:30 Go to previous messageGo to next message
1 more question - is $110 about the price i should pay for a drum to drum t18 diff?
FWIW i will take photos of the conversion and add them to the Faq for future reference.
45aken
NSW.south coast.Drifting
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 03:44 Go to previous messageGo to next message
for some reason me thinks the t-18 diff wont support an LSD, but people do this conversion because its stronger.
i'll accept that if im wrong im wrong, thats just my understanding on the t-18 diff. Confused
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 04:34 Go to previous messageGo to next message
The T18 certainly will "support" an LSD; just make sure you get one with the correct number of splines. Try searching again, this information has certainly been posted here at least once before by Simon (who currently has an LSD centre in his T18 diff).
Dodgy_Haro
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 06:31 Go to previous messageGo to next message
And I know that T18 diff's could be had for $75 drum to drum from some wreckers, unless the recent spate of T18 diff sales has jacked up prices ... Rolling Eyes
I know a few culprits ... Smile
PerformanceCars
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 06:38 Go to previous messageGo to next message
Ive already been to a few wreckers to no avail..
After chatting with Simon i have found my answers.
Yes it is a bolt in Job,
Yes i need the rear half of t18 tailshaft
The LSD to look for is the zenkie ( right amount of splines)
Now ive got something to do on the weekend Smile
Cheers Guys.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 07:17 Go to previous messageGo to next message
FWIW i paid 50 for complete rear end with cables and tailshaft from ABC Wreakers at Wacol, AND they took it out for me!
Ive found that most t18 axkes are a little on the worn side, they have some play in the LSD spline, i found a good set after buying 3 pairs
Simon
45aken
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 13:47 Go to previous messageGo to next message
hmmmmm. so i am proved wrong then, but it is also a good thing, because now i dont need to buy a $2000 JDM DIFF!!!
do the T-18 diffs come standard with an LSD and is there any downside to having one???
Simon-AE86
Banned user
Re: Ae86 -> T18 diff Questions Wed, 21 July 2004 15:23 Go to previous messageGo to next message
mate, the T18 diff is exactlly same as a JDM rear end except it has drums and smaller wheel bearings.
the aust t18 diffs that are commonly found here usually have a 3.7 open diff.
there are some early housings that done have sway bar links on them and other later housings that do. so keep an eye out./
Bobski
Re: Ae86 -> T18 diff Questions Thu, 22 July 2004 09:53 Go to previous messageGo to next message
how readily abailable are the zenkie centres and where do i get one, how much? Will a trd lsd centre fit or is it wrong number of splines?
u guys just solved all my problems with searching for a jdm housing...
thanx
joeninety
Re: Ae86 -> T18 diff Questions Thu, 22 July 2004 10:38 Go to previous messageGo to next message
I belive RA40 diff is exactly the same diff but tail shaft is diferent and manuals are 3.9 and autos are 4.1 and I heard that RT141 disc setup is a boltup. Not sure about the cables though.No sway bar mounts either but thats easily fixed.Turns out a Tercel rear sway bar is 17mm and near a perfect fit to so if you're already making mounts.....
ae95
Re: Ae86 -> T18 diff Questions Thu, 22 July 2004 17:28 Go to previous messageGo to next message
zenki centres are more common than the kouki centres
trd diff will fit provided its the zenki version
find one at a parts import place. or buy one new from japan
jesseT18
Castle Hill, Sydney
Re: Ae86 -> T18 diff Questions Fri, 23 July 2004 06:03 Go to previous messageGo to next message
as far as i know they are all 3.9
no all aus spec ones are open diff
now my question, im also looking for a LSD for my t-18 diff, how much are these zenkie centres worth?
[Updated on: Fri, 23 July 2004 06:04]
shcao
Re: Ae86 -> T18 diff Questions Fri, 23 July 2004 06:28 Go to previous messageGo to next message
at a good price, bout a grand brand new..
1600 normally
PerformanceCars
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 05:20 Go to previous messageGo to next message
FWIW,
I did this conversion on the weekend, Unfortunately i got an early t18 diff with no swaybar mounts, so i had to grind them off the ae86 diff and weld them on the t18 diff.
Apart from that it was a bolt in job.
Need to use the rear half of the t18 drive shaft and also need to use the ae86 handbrake cables (i found this out after putting it all back together Confused
now i just have to find a good lsd center Smile
Flogbag
Sydney (Campbelltown...!)
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 12:00 Go to previous messageGo to next message
are there any other brakes you can easily fit onto this diff?
like corona disks or something???
4a-c
Sutherland Shire
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 12:03 Go to previous messageGo to next message
Yeah i picked one up a t18 diff on the weekend but its missing brakes. Will my sprinter S series drums fit?
Flogbag
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 12:18 Go to previous messageGo to next message
dont know id prolly say they would but id like to know for sure
FKN16V
NSW, East Coast
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 12:21 Go to previous messageGo to next message
4a-c wrote on Mon, 26 July 2004 22:03
I do believe there the same size 10" but wether there the same im not sure.
Who has a t-18 diff they want the sell me.
Steve
ae95
Re: Ae86 -> T18 diff Questions Mon, 26 July 2004 17:57 Go to previous messageGo to next message
s series drums are smaller and wont fit easily
PerformanceCars
Re: Ae86 -> T18 diff Questions Tue, 27 July 2004 00:27 Go to previous messageGo to next message
i had them both apart on the weekend.. the pads and parts inside are identical.
BUT i dont know if the s series drums would bolt onto the t series diff housing as the T series is bigger.
T on left S on Right
http://brisbaneperformance.com/fileupload/store/diffs.jpg
[Updated on: Tue, 27 July 2004 00:34]
ae86slaver
Re: Ae86 -> T18 diff Questions Tue, 27 July 2004 00:46 Go to previous messageGo to next message
FKN16V wrote on Mon, 26 July 2004 22:21
Steve
There are 2 T-18's wrecking at pick'n'pay less, both still have complete rear ends. (this was 2 weeks ago - not sure if still there) but everything seems to be in good order, straight axles/hub etc. But i'm pretty sure the rear tailshafts were taken...funnily enough there was an ae86 there, i was scampering it out like a rat, got some nibbly's......has anyone else seen an 86 there before? cuz that was the first i'd seen
turbokid
Re: Ae86 -> T18 diff Questions Tue, 27 July 2004 07:19 Go to previous messageGo to next message
Picked up my t18 rear end and tailshaft today.
For those of you in QLD looking for a rear end, the wreckers at Narangba are wrecking 3 t18's.
$450 ta22
vic Castlemaine
Re: Ae86 -> T18 diff Questions Sun, 08 August 2004 10:18 Go to previous messageGo to next message
Where do people suggest to get a lsd center
truenosedan
Re: Ae86 -> T18 diff Questions Tue, 10 August 2004 02:38 Go to previous message
from me if you want trd 2 way pm me
Previous Topic:KE71 with 20valve?
Next Topic:ATTN megasquirt users
Current Time: Wed Nov 18 17:19:46 UTC 2026
Total time taken to generate the page: 0.0090939998626709 seconds
