Toymods » Tech & Conversions » MA61 5ME Blown Head Gasket
mattc
Glebe, Sydney
MA61 5ME Blown Head Gasket Wed, 11 September 2002 07:53 Go to next message
Hi all,
I'm fearing a blown head gasket on my MA61, it's loosing coolant, there are bubbles in the radiator and it runs pretty rough, it's been like this for a while but it's gradually getting worse and it's time to do something about it ! I'm going to attempt (with help from a mate whose done this before) to do the head gasket myself. I'm just wondering if there is any procedure (such as the on-line TSRM for the 5MGE) on the net or can anyone recommend any books that cover this ? I've checked the local library and there are the Haynes manuals for the supra/cressida was going to use these ?
Also what else should I check/replace while I'm doing the head
gasket ? I'm doing the valve stem seals at the same time as I'm
blowing a bit of smoke when I pull away after idle. I think I've
read I might have to do the chain tensioner, any other things as well ?
I'm in Sydney, anyone know of a good place/recommended brand of head gaskets etc. to use. I was looking at engine parts australia and they quoted me $86 for a HG and $22/set for the VSS is this a reasonable price ? I guess I will need intake/exhaust gaskets etc. as well Is this what's included in a a Valve Regrind Set ?
Sorry for all the questions ! I'm new to the forums and haven't done too much work on cars in the past, but am learning quickly with the Supra Very Happy
Thanks,
Matt.
Re: MA61 5ME Blown Head Gasket Wed, 11 September 2002 09:53 Go to previous messageGo to next message
Your 5M probably needs a lot more than a headgasket and seals by now. You say it's been like this for a while so there's a good chance some of your cylinder head has eroded away - and that means it's pretty much a basket case. I've seen it before. Sad
You're nuts spending money on that engine anyway, this is the perfect excuse for a 5M/6M-GE conversion - or maybe something even better! Smile
ed_ma61
Lost in the K hole
Re: MA61 5ME Blown Head Gasket Wed, 11 September 2002 14:31 Go to previous messageGo to next message
i have a head in absolute, very excellent condition. bolt on and drive away option. not rebuilt, but in original/excellent condition, no play on rocker supports, no wear on valves, straight, not cracked, purrrfecto. also have timing sprockets and vibration damper, near new to suit. might evn have a 'within spec' chain. $100 and its all yours. add a new head gasket and youre away. i also have a crank in A++ condition, and also full engine bolts etc etc.
if youre interested. drop me a line here, or PM me, or email me Smile
ed
wilbo666
Re: MA61 5ME Blown Head Gasket Wed, 11 September 2002 23:32 Go to previous messageGo to next message
Im my opinion Norbie is right, don't waste your money polishing a turd, get a better engine! (My head was stuffed when I pulled my off, some ppl don't run coolant Mad )
SUPRA MAN
Re: MA61 5ME Blown Head Gasket Thu, 12 September 2002 02:51 Go to previous messageGo to next message
Hey guys, some people cant afford - or dont know how to pull whole engines out and put new engines in.
If he just wants a head gasket done, help him with any questions he has.
I did the head gasket a couple of years ago on my first MA61. At the same time I had the head fully reconditioned,new injectors put in, and put a set of extractors on it.
mattc:
those prices you quoted sound pretty good.
good luck with your H/G, hope it all goes ok.
mattc
Glebe, Sydney
Re: MA61 5ME Blown Head Gasket Thu, 12 September 2002 03:25 Go to previous messageGo to next message
Thanks Guys,
I do realise that an engine swap would be the ideal (and great) solution, and one I would love to do ! But at the moment I don't have the funds or the room to do it (I'm in a unit with a small single garage). Also the Supra is my only car and I need it for work so can't really go without it for more than a weekend Sad
I thought I might have head erosion/warping etc. problems as I have let it go for quite a while ! and that was one of the reasons I posted on the forums. I was half planning on getting another head and doing a swap, and now thanks to ed I probably can Smile
Should be able to get the head, gaskets etc. do the swap and then onto the next job !! There's always something Smile
Matt.
Dabbid
Yowie Bay, Sydney
Re: MA61 5ME Blown Head Gasket Thu, 12 September 2002 10:03 Go to previous message
i wouldnt bother usin anything but genuine gaskets and seals
i've never seen anything last as long and work as well as toyota stuff... i'm a mechanic and see alot of this shit... where in sydney are u? need a hand? i also got a dead 5m-e if u loose any bolts etc u just gotta take the engine if u want the bolts Smile
Previous Topic:Exhaust Port Dimensions 4AGE Vs 4AGZE
Next Topic:4AGE owners
Current Time: Sat Nov 21 02:07:12 UTC 2026
Total time taken to generate the page: 0.0058619976043701 seconds
