Toymods » Tech & Conversions » ac st185 -> ae93
3sfe
ac st185 -> ae93 Tue, 20 July 2004 10:44 Go to next message
I just bought a ae93 pretty cheap so of cause not everything works the heater fan is one. I have just recently done a swap from a 3sge to 3sgte so i have a few things left over the like the climate control ac for one so i was think i might try and put it into the corolla. I was wondering if anyone has tried this or done it?
I know a lot of the wholes won't line up if any but i got a drill and welder Very Happy
Rod83
Re: ac st185 -> ae93 Tue, 20 July 2004 13:16 Go to previous messageGo to next message
Probably not without a lot of stuffing around. Sensors, etc would have to be integrated into your existing loom, and existing a/c components.
What's not working? Is it the fan, or the heater core?
3sfe
Re: ac st185 -> ae93 Tue, 20 July 2004 20:19 Go to previous messageGo to next message
From what i can tell its just the fan, but also when moving the temp lever on the control panel it doesn't move right across because of the angle of the switch at the bottom of the heater unit. So I thought i could just do away with all the cables as the celica on has got all motors. I thought i might as well us it as its just sitting around collecting dust.
Rod83
Re: ac st185 -> ae93 Wed, 21 July 2004 03:13 Go to previous message
First things to check:
Is the heater core connected to the engine?
Is the fan working at all, or is it only blowing air on one setting?
My temp lever doesn't move right accross either, but that's because I didn't adjust the cable properly when I put the aircon stuff back in.
Physically the st185 components might fit under the dash, but then you'd have to modify the ducts so they line up with the vents. I think the real problem would be the wiring, not really worth the hassle if its just the core or fan that needs replacing.
Previous Topic:rally suspension for the AE86
Next Topic:HP Torque Limit for early W58 and/or R154 Transmissions
Current Time: Thu Oct 29 13:50:25 UTC 2026
Total time taken to generate the page: 0.047114849090576 seconds
