Toymods » Tech & Conversions » TA22 feed fuel line
fade-e
TA22 feed fuel line Tue, 20 July 2004 11:39 Go to next message
Hi guys.
iv done a search and got to page 10 of 220 on fuel line threads and jsut couldnt look anymore so im just gonna ask
now i know the return line doesnt have to be changed from the threads i did read but what is a good sized fuel feed line i should get made for the car?
iv got a 3TGTEU in it
ra23celica
Re: TA22 feed fuel line Tue, 20 July 2004 12:14 Go to previous messageGo to next message
A 3T-GTE does not have any huge fuel demands on it in standard form so the original TA22 6mm fuel line should service it nicely. If you are keen to upgrade, fit a 8mm line to your car, and retain the existing 6mm return line.
fade-e
Re: TA22 feed fuel line Tue, 20 July 2004 12:41 Go to previous messageGo to next message
sweet thanks for that much appreciated
thetoyman75
Club President
Re: TA22 feed fuel line Thu, 22 July 2004 09:55 Go to previous messageGo to next message
Fade-e,
Just remember you need to use EFI hose clamps on ALL the rubber hoses, make sure you change the ones on your return line or it can weep/squirt fuel.
Fuel leaks and hot exhausts are a nasty combo !
Re: TA22 feed fuel line Thu, 22 July 2004 13:03 Go to previous messageGo to next message
Yes - don't skimp on any of it, use new decent quality pipes/hoses/fittings on every part of the car, and replace everything. It's a pain in the arse, but well worth it when your car doesn't end up torching itself Evil or Very Mad
fade-e
Re: TA22 feed fuel line Thu, 22 July 2004 14:09 Go to previous messageGo to next message
ATM its running stock as a rock other than the haltech and 3"exhaust. that should be suffiecient for now shouldnt it?
also there are 2 fat mothers of a rubber hose on the current lines where the fuel pump is to fit, is that good enough?
Azrael
Crapberra
Re: TA22 feed fuel line Fri, 23 July 2004 04:57 Go to previous message
thetoyman75 wrote on Thu, 22 July 2004 19:55
What is the diffence between a EFI hose clamp and a normal clamp. I'm hoping not a lot cause I'm just using normal ones... Eeeep
Previous Topic:SST Needed to Borrow - Pickle Fork
Next Topic:RA65 Celica Info and Engine swap possibilities
Current Time: Fri Jun 19 03:39:42 UTC 2026
Total time taken to generate the page: 0.0045709609985352 seconds
