Toymods » Tech & Conversions » microtech ecu hand controller not workng?
ta2272
icon9.gif  microtech ecu hand controller not workng? Wed, 21 July 2004 01:15 Go to next message
i hav ejust installed efi and when i connect my hand controller to the ecu only the backround lites up but not data is displayed anyone had this problem or know what is going on?
Jason
ke382TG
Re: microtech ecu hand controller not workng? Wed, 21 July 2004 02:12 Go to previous messageGo to next message
The only time I have seen the same problem you have (backlight comes on and no data displayed) is when there was not enough power being supplied i.e. flat battery or the power supply to the ECU was inadequate.
Could be other problems, but this one is a cheap and easy one to check first, grab a multimeter and check the voltage make sure connections are good and the battery is charged. Most people have a low or flat battery after conversions, long periods of working on the car because the battery sits for so long not being used/charged and dissipates voltage over time.
Hope it's nothing too problematic.
ta2272
Re: microtech ecu hand controller not workng? Wed, 21 July 2004 04:04 Go to previous messageGo to next message
thanks for the advice i will check it out tonight all thought i think that the battery is already charged as i charged it thougt it is a possibility, thanks.
Jason
ke382TG
Re: microtech ecu hand controller not workng? Wed, 21 July 2004 04:35 Go to previous messageGo to next message
No worries, always best to start with the simple checks first and then go from there.
Good luck.
ta2272
Re: microtech ecu hand controller not workng? Wed, 21 July 2004 05:19 Go to previous message
for enitial start up i had just shoved the power lead in to the terminal so maybe now that i have propler crimped it on it should work (hopes so )
jason
Previous Topic:Rx22
Next Topic:rally suspension for the AE86
Current Time: Fri Oct 30 11:32:04 UTC 2026
Total time taken to generate the page: 0.0052878856658936 seconds
