Toymods » Tech & Conversions » 1/2 cut or engine?
sebta22
icon7.gif  1/2 cut or engine? Wed, 11 September 2002 09:16 Go to next message
To all the experienced conversion gurus which is better (fit into TA22):
1/2 cut with 4agze
or
4agze engine alone
Is it better to get 1/2 cut so that you can totally strip it (i will be using atfermarket ecu) or is no problems using engine only. I have read that sometimes to dont get the entire engine (missing sensors, hoses, etc)
Re: 1/2 cut or engine? Wed, 11 September 2002 09:39 Go to previous messageGo to next message
Well, if you're going to use aftermarket management and make it RWD for a ta22 anyway, I really don't spose there's a whole lot of point in getting a cut. You'd throw almost all of it away.
Alainve
Newcastle NSW
Re: 1/2 cut or engine? Wed, 11 September 2002 10:42 Go to previous messageGo to next message
unless you can sell all the bits you don't need from the 1/2 cut then go for the engine alone, but you will need to get a thermostat housing as the FWD engines use remote ones mounted on the top of the gearbox. I'm not sure whether you can use the RWD 4AC thermostat housing which is mounted to the motor. Confused
Re: 1/2 cut or engine? Wed, 11 September 2002 11:06 Go to previous message
or just mount the GZE one in the hose
Previous Topic:Norbie!
Next Topic:Diffs and TAilshafts
Current Time: Fri Nov 20 12:46:51 UTC 2026
Total time taken to generate the page: 0.0053679943084717 seconds
