Toymods » Tech & Conversions » SW20 turbo electronic speedo cable
Draza
Wahroonga
SW20 turbo electronic speedo cable Wed, 21 July 2004 04:59 Go to next message
I was just wondering if there was any alternative to the electronic speedo cable. I seem to remember someone saying that the GT4 speedo cable being the same or good to use as a swap.
Can some one confirm this for me.
Yes i am trying to get my speedo working, i have worked out how to get the digital dash to take electronic speedo input, but this would mean that the odometer would not tick over as i would have to bypasss it. If any one has any ideas, my first was removing an electronic odometer from another car and put it in its place.
._T_.
Re: SW20 turbo electronic speedo cable Wed, 21 July 2004 07:31 Go to previous messageGo to next message
electronic speedo cable??? there is not one! it is 2 (or 3 depending on model)wires!!
i have some factory electronic sender units that will screw onto the std cable sender on the gearbox. you will have to do the wiring
T
Draza
Wahroonga
Re: SW20 turbo electronic speedo cable Wed, 21 July 2004 13:49 Go to previous messageGo to next message
I have the electronic sender on the box. I'm trying to get the speedo working, and the digital dash. Either both at the same time or speedo first.
Re: SW20 turbo electronic speedo cable Wed, 21 July 2004 13:58 Go to previous messageGo to next message
how about grafting in a VDO programmable speedo, than you have speedo and odometer at the same time Wink
Re: SW20 turbo electronic speedo cable Wed, 21 July 2004 22:21 Go to previous messageGo to next message
Yeah toby, Drazza is trying to get the ST162 digi-dash working, when he has an electronic speed sender in his gearbox.
Basically he wants a cable speedo drive gear, but hasnt been able to find one.
Joshstix
Toymods Vice President
Re: SW20 turbo electronic speedo cable Thu, 22 July 2004 10:00 Go to previous messageGo to next message
The ST185 and Gen 2 SW20 both had mechanical speedo drives. I replaced my electronic sender on my Gen 3 gearbox with one from an ST185 and it reads speed fine in my AW11.
The ST185 actually uses an electronic sender as well however it screws into a right angle drive. You can unscrew this cable from the sender then pull out the drive pin and simply plug in your normal speedo drive cable.
sideshow
Re: SW20 turbo electronic speedo cable Thu, 22 July 2004 10:14 Go to previous message
easiest way is to get an electronic speedo sensor from a gbox that is similar to yrs
it has 3 wires
earth 12 volts ignition
and signal wire
run the signal wire to the wire for the speedo
too easy
if u cant find one i sell electronic speedo drives to suit most toyotas
Previous Topic:s13 coilovers into 86
Next Topic:MX83 problems
Current Time: Sat Nov 21 08:47:36 UTC 2026
Total time taken to generate the page: 0.013498067855835 seconds
