Toymods » Tech & Conversions » Porting 270 heads
M.J.H
Porting 270 heads Wed, 21 July 2004 08:00 Go to next message
Just wondering how far you can port the 270 18rg head.
I have one to do and i don't want to cut up the spare head to find out.I want to go as far as i need to get the maximun flow possible but without going into any water jackets.
Will only be used for racing so high revs application as won't be going under 4000 on the track.
If any of you 18rg experts could help that would be great.
Thanks.
EDIT
Surely someone here would know how far you can go.
[Updated on: Fri, 23 July 2004 17:18]
M.J.H
Re: Porting 270 heads Fri, 23 July 2004 17:20 Go to previous messageGo to next message
Anyone?
toynado
Re: Porting 270 heads Fri, 23 July 2004 18:25 Go to previous messageGo to next message
wut you are asking is impossible
no one can tell you such things as heat is not homogenous in a hed
why dun you measure the present thickness of the cooling walls and go from there?
too thin, the heat causes leaks as the metal changes atomic structure
M.J.H
Re: Porting 270 heads Sat, 24 July 2004 06:19 Go to previous messageGo to next message
Yeah i might have to do that.
I thought someone would have done these heads before and be able to tell me how far they went or could have gone.
Unfortunatly when i did a search first the pics that WITZL had posted were'nt there in his post. Sad
CelicaRA45
nth ringwood, Victoria
Re: Porting 270 heads Sat, 24 July 2004 12:06 Go to previous message
just clean the ports up the exhaust is where the gains are we flowed the 2tg heads 220 222 and 260 there was not much btw them at std 200 hp 204 and 206 hp and with porting only pick up a little also the 18rg would be similar my mate done his 4 heads and much the same and thats with 440 thou lift 2tg and 18rg on aflow bench
Previous Topic:Solex Tuning & jet questions
Next Topic:Help ppl that have done ae82 drum 2 discs
Current Time: Thu Nov 19 19:12:27 UTC 2026
Total time taken to generate the page: 0.0049901008605957 seconds
