Toymods » Tech & Conversions » 1j able to fit ford X-members? (XF)
TurboCelica
1j able to fit ford X-members? (XF) Thu, 22 July 2004 01:08 Go to next message
Guys, just asking on the chance someone has looked at this before or has a ford and can look. Will the 1j format fit the XF engine bay ( i am sure it will) secondly will it require major mods to the X-member / sump config? and perhaps the steering?
regards
(trying to convince a mate its quicker(car) and better engine, to do this swap,than get a old XR6 with there 170 odd kW. and mega km's)
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 04:35 Go to previous messageGo to next message
The 1J come's with either front, mid or rear sump configurations, so chances are ther'll be a sump to fit around the crossmember.
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 04:46 Go to previous messageGo to next message
I looked at this a little bit for a mate of mine once, however the idea never worked out. Also, the old Falcon six, despite being tractor like, can be made to produce some pretty big power when combined with a decent sized turbo... Add up what a conversion is going to cost and look at all the options.
KDog
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 06:04 Go to previous messageGo to next message
Whilst you could probably find a 1jz sump that will come close to fitting you would probably still need to do sump/xmember mods.
The falc 6 has a pretty strong botttom end and a good freshen up and a turbo would be cheaper and much easier. There are quite a few really good examples going around. Check out the ford forums for a better idea.
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 06:16 Go to previous messageGo to next message
whilst the 4.1 is a hefty motor and doesn't like to rev, it sure does make torque.
you could fit one of the AIT twin turbo kits.. a mate of mine is doing that now with (i think) 2x T25G's
we did some calcs for it.. a 4.1 with even 7psi boost is still comparable with a 1JZ with 14psi...
the 1J is 2.5L no? in a heacy car like the XF, you need capacity to get the torque to get the slug moving Wink
a 2J would be a better start, and a 1UZ, even better...
but do it anyway, not enough people have a go at things like this!!
good luck!
CLG
Perth, Western Australia
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 07:11 Go to previous messageGo to next message
And if you do do it, you'll want a front sumped 1J motor, as the engine crossmember in a Falcon basically assumes a mid mount position!
Clint
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 07:19 Go to previous messageGo to next message
Take a leaf out of MS75's book. Turbo a 1FZFE.
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 07:34 Go to previous messageGo to next message
You dont need to fit a turbo to the old ford sixto get some sweet power from it. http://www.jimmockmotorsport.com
Mr DOHC
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 11:03 Go to previous messageGo to next message
can u imagine rolling up to summernats in a TT 1UZ XF, u would be shot, raped, stabbed, strangled and beaten in the first 5 mins
V8_MA61
Re: 1j able to fit ford X-members? (XF) Thu, 22 July 2004 11:17 Go to previous message
whats wrong with the old 250 xflow Razz
Seriously...if its an XF put a 351 Windsor or Cleveland in it
THey were built for the car, so leave it like that...
I spose i shouldnt really talk Rolling Eyes
Previous Topic:Celica Drive layout info pls
Next Topic:horn wont work
Current Time: Sat Nov 21 08:21:41 UTC 2026
Total time taken to generate the page: 0.005856990814209 seconds
