Toymods » Tech & Conversions » cd player decided to not work...
Evil_Foetus
Ballarat, Victoria
cd player decided to not work... Thu, 22 July 2004 06:18 Go to next message
hmmm
in rewiring my foglights, my cd player refuses to turn on now. ive checked the fuse in the drivers kick panel and in the back of the cd unit, they're fine. there is also power running to the cd player (checked power wire with multimeter), and ive attached all the earths etc...
so i just don't get it. i think it did this before, but i can't remember what happened...
if someone could help me out, that'd be nice Very Happy Very Happy
SIKRA40
Re: cd player decided to not work... Thu, 22 July 2004 07:38 Go to previous messageGo to next message
did u check the fuse in the back of the stero? other than that i would have suggested stuff like fuses, power and earth wires but it seems u already checked those
Dan
STR8 2.8
Re: cd player decided to not work... Thu, 22 July 2004 07:51 Go to previous messageGo to next message
i wish i could help, but i have found myself in the same situation.
the head unit just wont turn on. :S
BlackSupra
Re: cd player decided to not work... Thu, 22 July 2004 08:05 Go to previous messageGo to next message
what wire did u use for 12volts?
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Thu, 22 July 2004 08:57 Go to previous messageGo to next message
for the foglights you mean?
its just a standard wire, im not 100% sure what it is... i got it from dick smith, told them my application and they said that it was the best wire... its just like normal wires behind the cd player Confused
but the earths and fuses are all fine, and its getting power, but i dont know
its just an entry level pioneer cd player too.... Confused
STR8 2.8
Re: cd player decided to not work... Thu, 22 July 2004 08:58 Go to previous messageGo to next message
i think he means which wire did u tap the 12V from?
[Updated on: Thu, 22 July 2004 08:58]
BlackSupra
no silly
im guessing this has only happened after the rewire
in that case, what wire did you tap into for 12 volts?
BlackSupra
Re: cd player decided to not work... Thu, 22 July 2004 08:59 Go to previous messageGo to next message
hmm freaky.
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Thu, 22 July 2004 09:00 Go to previous messageGo to next message
the cigarrette lighter- just the smaller plug that goes to the lighter itself, and not to the a/c switch...
am i naughty? Confused
Re: cd player decided to not work... Thu, 22 July 2004 09:01 Go to previous messageGo to next message
Give your deck a better earth
BlackSupra
Re: cd player decided to not work... Thu, 22 July 2004 09:05 Go to previous messageGo to next message
Nah thats right.......
to tell the truth, i have wired it up this way and have a similar issue, my Headunit will be on but just mutes for a few seconds then comes back on.....
Its odd and something i havent got around to fixing yet.
The system is ground switching, so when you hit high beams the spotties will come on automatically.
Id say the answer is another power source, or a new ground and make the spotlights totally independant of the high beams....that will solve the issues.
Aust162
Melb, Victoria
Re: cd player decided to not work... Thu, 22 July 2004 09:41 Go to previous messageGo to next message
is your interior light still working????
the audio fuse in the kick panel is for accesories (ign), so u want to check ur constant 12v source for ur h/unit too. the interior light should share the same fuse. it could be call "room" on the fuse panel maybe.check them all, cant hurt Smile
[Updated on: Thu, 22 July 2004 09:42]
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Thu, 22 July 2004 15:02 Go to previous messageGo to next message
the foglights (that ive rewired) are already independant of the high beams- i put them on, and the foggies don't come on, unless i flick the switch
(if thats what you mean Razz )
thansk guys Very Happy
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Fri, 23 July 2004 01:20 Go to previous messageGo to next message
ive checked all fuses.
im going to disconnect the foglights, and see if it works. if it does, what should i do?
im going to try and add a bigger or another earth to my stereo as well....
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Fri, 23 July 2004 06:11 Go to previous messageGo to next message
hmmm, its still not working
i think my battery has gone a bit dead during this procedure, as its hard to start atm.....
can anyone help? sideshow even? Smile
[Updated on: Mon, 26 July 2004 10:52]
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Mon, 26 July 2004 10:51 Go to previous messageGo to next message
hmmm my cd player is still not working... and its getting power, the multimeter says.
its a pioneer deh-1450, as pictured here.
http://www.hotwireauto.co.nz/car_audio/pioneer/images/DEH-1450.jpg
BlackSupra
Re: cd player decided to not work... Mon, 26 July 2004 12:10 Go to previous messageGo to next message
then its a bad earth.
BlackSupra
Evil_Foetus
Ballarat, Victoria
Re: cd player decided to not work... Mon, 26 July 2004 12:42 Go to previous messageGo to next message
righto, bigger earth strap? is there a better position than the mounting holes?
cheers glenn, you're a lifesaver Very Happy
[Updated on: Mon, 26 July 2004 12:43]
BlackSupra
Re: cd player decided to not work... Tue, 27 July 2004 09:51 Go to previous message
mounting holes are dodgey....the frame rusts over time
bolt it straight to the tranny tunnel or something similar if possible......or use some steel wool and make sure the mounting surface is paint and rust free.
Previous Topic:Engine help
Next Topic:mandrel bend or standard bend exhaust
Current Time: Sun Nov 22 16:47:00 UTC 2026
Total time taken to generate the page: 0.023147821426392 seconds
