Toymods » Tech & Conversions » TIMING ON 1G-GTE
indian
south east - melbourne
TIMING ON 1G-GTE Fri, 23 July 2004 01:26 Go to next message
guys need to know the timing to set the car to get a bit more power out ,
i know std timing should be set at 10 deg
is there any other setting like 11 or 12 or maybe 9 which will be more better for power
also anyone got any pics of twhere to install boost controller on the 1g-gte engine
Bugman
Re: TIMING ON 1G-GTE Fri, 23 July 2004 02:20 Go to previous messageGo to next message
http://members.optushome.com.au/lrwilliams/enginedside.JPG
Bugman
Re: TIMING ON 1G-GTE Fri, 23 July 2004 02:21 Go to previous messageGo to next message
its the bright blue thing. it then goes to a T and then to the actuators, buy you could take of both turbos t it then to a boost controller then t it back to the wastegate actuators
indian
Re: TIMING ON 1G-GTE Fri, 23 July 2004 02:47 Go to previous messageGo to next message
u got to be joking is that all i have to do , someone told me that before and it didnt work
what i basically did wasjust tee in the boost controller exactly into the same line that u have done
AND NOTHING HAPPENED
tried connecting the boost controller the otrher way around , stil nthing happened
any ideas
indian
Re: TIMING ON 1G-GTE Fri, 23 July 2004 02:53 Go to previous messageGo to next message
far4k that gotme confused alrigt Confused Confused Confused Confused Confused Confused Confused Confused
Siktoy ra23
Plumpton/sydney
Re: TIMING ON 1G-GTE Fri, 23 July 2004 10:13 Go to previous messageGo to next message
put both hoses from the actuators to a T peice and both hoses from the turbos to a T peice and run them hoses to your boost controller.
Then you adjust it till you engine goes BOOM then back it off a bit so next time it wont go BOOM Laughing
Bugman
Re: TIMING ON 1G-GTE Fri, 23 July 2004 22:25 Go to previous message
that line on your c ar most likely runs to the power steering byepass valve though. but on the older celicas we dont use them. but you could tee into that line then run a line of that t then to the controller then to a t and to both actuators.
Previous Topic:Question: KE TX3 AWD TURBO 1.6
Next Topic:HELP: 4AGZE turbo smokey!
Current Time: Wed Nov 18 14:34:38 UTC 2026
Total time taken to generate the page: 0.007627010345459 seconds
