Toymods » Tech & Conversions » Cam belt covers
Dylo
Cam belt covers Wed, 11 September 2002 15:00 Go to next message
Is there any problems with running an engine with out the cam belt cover if its one of those big plastic covers? or is it just a dust protector?
jazae86
Re: Cam belt covers Wed, 11 September 2002 16:08 Go to previous messageGo to next message
For cars running a dry belt such as 4ag, its no big issue but its not a good idea to regularly get it wet or oily (as it may slip).
Many ppl run their engines without them. My 4ac did so for 9mnths without fault.
Jaz
Bill Sherwood
Brisbane / Gold Coast
Re: Cam belt covers Wed, 11 September 2002 23:41 Go to previous messageGo to next message
I've never run one in the ten years I've had my 4AGE.
JIMMYD
Cairns
Re: Cam belt covers Thu, 12 September 2002 23:25 Go to previous messageGo to next message
Do you like to be able to count to ten with out removing your shoes? Exposed cam belts/gears have a voracious appetite and just love a steady diet of fingers, loose clothing etc.
If not running covers, be careful and treat those hungry teeth with respect.
That said, I have run without cam covers with a wide range of cars, the only one to give me any concern was a RS2000 that picked up a stone (while driving off road) that snapped the belt. Long wait for recovery. Long walk home.
rollaboy
Coffs
Re: Cam belt covers Thu, 12 September 2002 23:40 Go to previous messageGo to next message
So there's not much point of not having the Cam gear cover on???
Corolla Boy
Re: Cam belt covers Sat, 14 September 2002 10:35 Go to previous messageGo to next message
Id leave the cover on, for example lets say your pouring oil into the engine and accidently spill some over the edge. If the oil spills onto the timing belt it MAY cause it to slip, also not having a timing belt cover means there is the risk of maybe a hose, wire comming in contact with the belt. On my 4AC the radiator hose is toutching the timing belt cover, if I remove it the hose will rub against the belt and wear the belt & the hose out. It's really up to you.
[Updated on: Sat, 14 September 2002 13:45]
TCHOON
Sydney- Sutho Shire &...
Re: Cam belt covers Sat, 14 September 2002 11:18 Go to previous messageGo to next message
I thought the 4age didn't do any damage if the belt breaks. Pistons don't hit valves (non-interference ) etc.. ?
Bill Sherwood
Re: Cam belt covers Sat, 14 September 2002 11:31 Go to previous messageGo to next message
The timing belt is ribbed, it can't slip.
Corolla Boy
Re: Cam belt covers Sat, 14 September 2002 11:59 Go to previous messageGo to next message
Yes It can skip a tooth if the timing belt is slippery or loose.
Corolla Boy
Re: Cam belt covers Sat, 14 September 2002 12:01 Go to previous messageGo to next message
As for the 4age im not sure if damage can occure if the belt breaks but I know for a fact that on most twin cam engines, if the timing belt breaks damage can occur
Re: Cam belt covers Sat, 14 September 2002 13:23 Go to previous messageGo to next message
Uh... if your timing belt is loose enough to skip a tooth, you have serious problems that weren't caused by a bit of oil!
rob_RA40
c'town, NSW
Re: Cam belt covers Sat, 14 September 2002 13:34 Go to previous messageGo to next message
word on the street is that all toyota engines that run a timing belt are non-interference.
Corolla Boy
Re: Cam belt covers Sat, 14 September 2002 13:40 Go to previous messageGo to next message
I was just saying what might happen thats all, and as for what Rob said thanks mate I learn't something.
[Updated on: Sat, 14 September 2002 13:42]
JIMMYD
Cairns
Re: Cam belt covers Sun, 15 September 2002 23:33 Go to previous message
Non interference design IF standard profile cams, block heights, head thickness,etc.
Think about it,
increase cam lift = more valve protrusion into chamber,
deck the block = higher relative piston position,
shave head = more valve protrusion.
Just something to keep in mind. I have broken an timing belt on a noninterference engine at high RPM. Guess what happened.....
Previous Topic:Wheel spacers for JZA80??
Next Topic:sprinter gearboxs
Current Time: Wed Oct 21 10:54:31 UTC 2026
Total time taken to generate the page: 0.0056040287017822 seconds
