Toymods » Tech & Conversions » What is Wrong with my EFI????????
ta2272
icon9.gif  What is Wrong with my EFI???????? Fri, 23 July 2004 07:18 Go to next message
Ok i just intalled my efi on my car it is controoled by a microtech digi one and is on a 2tg motor.
Got up this morning and drove it around town fine for 20-30 mins, when i stopped at my freind house for an hour i hoped back in my car and started it up moved about ten meters and it stopped.
On the computer it diplayed it was not getting power nor idlepulse, after a while of siiting there it started again got a kilometer down the road and it konked out again i turn my igniotion right of, and then the car would start again then it konked out againb 20 meters later. the powere and idle pulse would only come back on if i turned ignition right of.
guys
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 08:51 Go to previous messageGo to next message
Maybe you should of got someone who knows what they are doing to install it.
sideshow
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 08:56 Go to previous messageGo to next message
maybe its coonected to yr speedo
when it gets too many pulses from the speedo
it turns of the microtech
sorry i should not make jokes
turn the ign on but dont start
now go around and wiggle the wiring
relays etc anything to do with microtech
especially dizzy wires
if the mircotech starts turnin on and off then u have a bad connection
ta2272
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 09:24 Go to previous messageGo to next message
i installed it correctly, just has something wrong within the wiring, but yeh thanks for your help will check it out, anyone else got any ideas.
Jason
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 09:57 Go to previous messageGo to next message
Ask your science teacher if he'll come home after school and help you with it.
people100
Rocklea qld
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 11:14 Go to previous messageGo to next message
HEHE I hope i dont have these probs with my wiring. Id say something serious is going on but i doubt a bad connection. It wouldnt fix itself as soon as you turn it off. Maybe a dodgy relay for your ecu is shitting itself.
Toobs
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 13:10 Go to previous messageGo to next message
Although I don't have a microwreck I would assume the ECU uses the tacho pulse to work out if the cars stalled... i.e. your tacho pulse is your idler pulse and as a safety feature the ecu should power off the car if it stalls (in case of an accident)
Maybe your tacho wire is dodgy or tacho signal too weak?
toynado
Re: What is Wrong with my EFI???????? Fri, 23 July 2004 18:36 Go to previous messageGo to next message
gawd
wish my efi told me wut's wrong with it like that
it told you wut's wrong...
trace the offending wire(s) backwards till you find the open circuit causer
do you know P=IR ?
kinda helps in the process ...
altho i guess you just need a voltmeter or trouble lite
ta2272
Re: What is Wrong with my EFI???????? Sun, 25 July 2004 08:28 Go to previous messageGo to next message
there is one wirte which was connected to the old points dizzy which isnt goign anywere now because the new dizzy did not have any were for it to go anyone know what it could be for (and yes my tacho is working)
thanks guys.
Jason
people100
Rocklea qld
Re: What is Wrong with my EFI???????? Sun, 25 July 2004 09:23 Go to previous messageGo to next message
No the wire will not matter. On a points dizzy there is a wire from the (-) of the coil going to the dizzy. When u convert to electron ignition the wires go from the ignitor top the dizzy so the old (Black) wire from the coil can basically be left out and doesnt need to be conected. Seeings as this is a problem that comes and goes id say maybe a dodgy relay the keeps opening and closing or something along those lines could be the problem.
SeptemberSquallIndustries
Re: What is Wrong with my EFI???????? Sun, 25 July 2004 10:01 Go to previous messageGo to next message
Shocked
Shocked Shocked
Re: What is Wrong with my EFI???????? Sun, 25 July 2004 10:08 Go to previous messageGo to next message
hehehe hehehe hehehe
ta2272
Re: What is Wrong with my EFI???????? Sun, 25 July 2004 10:38 Go to previous messageGo to next message
Laughing
ta2272
Re: What is Wrong with my EFI???????? Mon, 26 July 2004 06:37 Go to previous messageGo to next message
I drove it and fidled with it for a while and found it was my throttleposstion sensor it was only just on and the clip was missing. so now i have secured it proply and the car is running well.
Jason
thanks for you help guys those who helped
Re: What is Wrong with my EFI???????? Mon, 26 July 2004 08:30 Go to previous messageGo to next message
ta2272 wrote on Mon, 26 July 2004 16:37
No problem.
Re: What is Wrong with my EFI???????? Mon, 26 July 2004 13:14 Go to previous messageGo to next message
Cool1 wrote on Mon, 26 July 2004 18:30
No problem.
Rolling Eyes
Re: What is Wrong with my EFI???????? Tue, 27 July 2004 11:53 Go to previous message
SeptemberSquallIndustries wrote on Mon, 26 July 2004 23:14
No problem.
Rolling Eyes
Yawn
Previous Topic:AE86 Digi-Dash wiring diagram
Next Topic:TRD supplies in Australia!!!!!
Current Time: Sun Oct 18 01:17:06 UTC 2026
Total time taken to generate the page: 0.0060780048370361 seconds
