Toymods » Tech & Conversions » mx83 strut/ r33/ coon brake upgrade query
V8_MA61
mx83 strut/ r33/ coon brake upgrade query Sat, 24 July 2004 07:27 Go to next message
I was wondering today, how big the 4 pot r33 calipers are and how much fluid they are gonna suck up.
Is the ma61 master cylinder and booster big enough? Obviously if its not, the brakes are stil only as good as the amount of fluid fed to them...
The ma61 > ma70 master cylinder has been covered on the celicasupra site, but how about the booster ?
Do lines need to be upgraded to a larger size for the upgrade as well?
people100
Rocklea qld
Re: mx83 strut/ r33/ coon brake upgrade query Sat, 24 July 2004 09:18 Go to previous messageGo to next message
If u do upgrade the master and booster. let me know a price to buy yours.
V8_MA61
Re: mx83 strut/ r33/ coon brake upgrade query Sat, 24 July 2004 10:10 Go to previous messageGo to next message
you want everything off my supra lol
Edit: my master cylinder was just fully rebuilt!
[Updated on: Sat, 24 July 2004 10:11]
Re: mx83 strut/ r33/ coon brake upgrade query Sat, 24 July 2004 11:06 Go to previous messageGo to next message
V8_MA61 wrote on Sat, 24 July 2004 17:27
i dunno about the 15/16 master cyl being suitable to drive the R31 calipers... but the booster will be just fine as will your brake lines.
booster only helps your foot push on the master cylinder - the ra40 stock-to-hilux calipers only needs upgrade of the master cyl and proportioning valve - lines are more than adequate for shifting all the extra fluid required, as is booster. Your upgrade would be similar improvement in terms of % of increase in fluid requirements. is not like you car is heavier by significant amount ergo needing extra braking effort on the master cyl.
You'll only need to replace booster if yours is leaking.
you may want to get new flexible lines for the front (seeing as they'll be pretty old by now)
btw: am glad you came out of accident mostly unharmed.
V8_MA61
Re: mx83 strut/ r33/ coon brake upgrade query Sat, 24 July 2004 11:08 Go to previous messageGo to next message
thechuckster wrote on Sat, 24 July 2004 21:06
thanks man..im sore trust me.
Yeah ill look at a mk3 m/c swap.
dorikin
NE Melbourne
Re: mx83 strut/ r33/ coon brake upgrade query Sun, 25 July 2004 08:55 Go to previous messageGo to next message
the 15/16 bore master cylinder will probably be fine with R33 4 potters. as for the coment about the brakes only being as good as the amount of fluid fed to them, it's a bit off the point. the brakes will work, just fine, it may just require further travel of the master cylinder to supply sufficient fluid to move all the pistons. don't forget too, that a smaller master cylinder will give more mnechanical advantage and the brakes will be very powerful. think of it as a lever and moving the pivot point on the lever, it's the same principle.
bbaacchhyy
Re: mx83 strut/ r33/ coon brake upgrade query Sun, 25 July 2004 13:12 Go to previous messageGo to next message
Blake, I'll let you know once the brake lines are done on my car.
I have a Mk3 M/Cyl and booster which will be installed if the Mk 2 one is not up to scratch. I have the piston size handy at home. I'll let you know the size tomorrow.
Michael B
V8_MA61
Re: mx83 strut/ r33/ coon brake upgrade query Mon, 26 July 2004 04:51 Go to previous messageGo to next message
thanks mick
bbaacchhyy
Re: mx83 strut/ r33/ coon brake upgrade query Mon, 26 July 2004 13:33 Go to previous message
Whoops Embarassed
I'll try and remember tomorrow !!!
Previous Topic:turbo's of a 2j
Next Topic:18r-g has NO GO!!
Current Time: Fri Nov 20 09:23:21 UTC 2026
Total time taken to generate the page: 0.0062808990478516 seconds
