Toymods » General Car Talk » My new brake setup (570k worth of pictures)
My new brake setup (570k worth of pictures) Sun, 25 July 2004 02:30 Go to next message
This is my new brake setup for my TA22. The setup uses RA40 struts, MS65 hubs, Honda S2000 rotors(300x25mm), Mazda RX7 calipers and custom milled caliper brackets.
http://members.iinet.net.au/~shanej/New%20Brakes/P0002947.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002948.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002950.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002952.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002953.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002955.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002957.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002961.JPG
http://members.iinet.net.au/~shanej/New%20Brakes/P0002965.JPG
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 02:31 Go to previous messageGo to next message
In the last picture above you can also see the spacers we had to make the calipers suit the thicker rotor.
Classique71
Colac, Victoria
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 02:35 Go to previous messageGo to next message
MMMMMMMMM brakes * droooool *
you are gunna die grinss that " mazda " off arentcha ! Smile
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 02:39 Go to previous messageGo to next message
Classique71 wrote on Sun, 25 July 2004 12:35
Correct Very Happy
EMP-2TG
Carlingford, Sydney
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 04:18 Go to previous messageGo to next message
omg Smile
fade-e
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 04:24 Go to previous messageGo to next message
FIRSTLY sweet as job mate VERY NICE!!!
just some Qs if you dont mind...
the MS65 hub fits straight nto the RA40 strut without any issues/mods?
same Q for rotor/disc to hub?
the nut on the bolt for the calipers, what are they for? is the bolt too long?
could i/we get specs for the bracket?
did the strut need to be cut or anything or does the ride height come out good of the bat?
does the RA40 strut sit onto the TA22 tierod arm thing on control arm (mate not sure what its called, basically where strut bolts to control arm)? or does that need to be changed?
THANKS... ONCE AGAIN SWEET JOB!!! Cool
Aust162
Melb, Victoria
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 05:59 Go to previous messageGo to next message
great work man! very impressive fabrication work there. Very Happy
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:06 Go to previous messageGo to next message
fade-e wrote on Sun, 25 July 2004 14:24
Thanks and ok.
Correct
We had to drill the correct stud pattern in the rotor to bolt onto the hub(5x114.3).
At the time those bolts were all we could find. But now that I look at and think, it seems like a good idea. Kind of like head studs.
Sure, they're made from alloy and have been sandblasted to give the mat finish.
At the moment I have just used the TA22 spring and strut top. The ride hight will be about an inch higher. This is not a problem because the struts will be cut down and have coil over kits fitted at a later date. At the moment I just need them to roll the car around.
The RA40 strut bolts on the TA22 control arm without any issues.
fade-e
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:14 Go to previous messageGo to next message
thanks for the answers mate VERY MUCH APPRECIATED!!!!
so the min rim size would be 15" or 16" now to make all clearences?
Allan
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:19 Go to previous messageGo to next message
you will need to heli-coil the alloy brackets where the cailper bolts to other then that VERY sexy
fade-e
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:23 Go to previous messageGo to next message
yeah that would be providing that you use alloy like Cool1 did right?
if you used another strong metal like cast iron/steel/iron or whatever than a thread would do fine
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:27 Go to previous messageGo to next message
fade-e wrote on Sun, 25 July 2004 18:14
At the moment I have a set of factory AU Falcoon 16 inch steel rims and these fit when I used some washers between the rim and hub. The caliper hits the inside of the rim so i'll be needing some spacers for the time being Confused
So to answer your question, 16 steel rims are the minimum because of the way they are constructed, but 15 inch alloys will fit fine.
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:34 Go to previous messageGo to next message
We are not going to use coils for the time being as the tempered grade alloy we used along with the correct threading procedure should be strong enough as is. We are also using a very large pitch thread to help the situation.
However to prove a point to ourselves, we threaded an off cut of the alloy and tightened up the bolt to more and than 3 times the suggested factory torque setting without the thread stripping.
fade-e
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:40 Go to previous messageGo to next message
oh yeah i can see from the pic how it sticks out SPEWING but still man sick ass job...
instead of putting spacers between rim and hub couldnt you put spacers between hub and rotor?
has anyone ever tried this before? could be something to consider...
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 08:43 Go to previous messageGo to next message
fade-e wrote on Sun, 25 July 2004 18:40
You could do that but it makes the bracket harder to make and keep strong enough.
Mr DOHC
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 09:32 Go to previous messageGo to next message
nice work shane
how much did the adaptors cost
Mr DOHC
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 09:34 Go to previous messageGo to next message
Cool1 wrote on Sun, 25 July 2004 18:43
and u could just get longer wheel bolts and get a proper spacer made
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 09:37 Go to previous messageGo to next message
Or I could just get some wheels that suit the job once the car is ready to be roadworthy Very Happy
Mr DOHC
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 09:41 Go to previous messageGo to next message
fuck that, keep the AU steelie sleeper look, goes with the
Quote:
1974 Multi-coloured TA22
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 09:44 Go to previous messageGo to next message
The AU steelies will stay on the back but i'll source some other still rims to suit the front Smile
bbaacchhyy
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 13:20 Go to previous messageGo to next message
Nice brackets man, but I'll point out a couple of things (just to be a smart ass Very Happy ),
If a 16" steeli only just fits, then a 15" alloy mag definitely wont.
A fine thread is stronger than a coarse thread.
Overall, a pretty schmick job.
Michael B
fade-e
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 13:51 Go to previous messageGo to next message
bbaacchhyy: i think he means that they would fit diameter wise but no matter what he needs spacers, therefore if he put 14" they would hit the side of the calipers as well as the front
bbaacchhyy
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 14:39 Go to previous messageGo to next message
Disagree fade-e.
I still think it would take 16" cast alloys, not 15".
With my brakes (326mm rotors and 300ZX calipers), 16" Simmons rims JUST fit, and 16" cast alloys wont, so if I need/want cast alloy rims, I'll have to go to 17".
I think it is a matter of the shell of the rim clearing the caliper.
EMP-2TG
Carlingford, Sydney
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 14:55 Go to previous messageGo to next message
if u look inside the au rim u will find its very deep inside
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 20:46 Go to previous messageGo to next message
Michael B, Your obviously not smart enough Very Happy
The 16 inch AU steel rim only just fits because the center part of the rim curves around and then attaches to outter rim. Its this curve that interferes with the caliper. An alloy rim (like the ones fitted to my falcoon)are not constructed like this so there is plenty of room to down size.
Also if you read my post a while back, I did not say anything a fine course threaded bolt. I mentioned the pitch which is a completely different story!
bbaacchhyy
Re: My new brake setup (570k worth of pictures) Sun, 25 July 2004 20:56 Go to previous messageGo to next message
Cool1 wrote on Sun, 25 July 2004 18:34
Fair enough re where the rim hits the caliper. But a 15" alloy fits over that size disc and caliper combo ? Confused Very well then.
As pointed out above (highlighted in bold), I understand it to be a coarse thread (i.e. large pitch vs fine thread which is mall pitch), but with some punctuation, it could be a 'large bolt, that has the right sized thread', which is what aI am assuming ?
Still though, it is all very nice and a neat job (especially the bracket as mentioned earlier) and a fine thread has greater strength than a coarse thread. Smile
Both front and rear brakes are well done, unlike many others (if they are done at all Shocked )
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 08:03 Go to previous messageGo to next message
This is about as direct as I can get:
The thread is fine, but the tip of the thread is square not triangular like off the shelf bolts people are more familiar with.
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 08:06 Go to previous messageGo to next message
Oh and today I fitted a 14 inch BSA alloy rim over the rotor caliper combo. So i'm sure most if not all 15 inch alloys will fit.
[Updated on: Mon, 26 July 2004 08:06]
gabe
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 09:51 Go to previous messageGo to next message
Just saw this thread and well dang.......very nice work.... engineering at it's finest.
Just on the Heli-coiling issue, its not required if using 7000 series or higher aluminium.
Once again, nice work. I can appreciate a job when its done right, first time around.
dcleyne
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:19 Go to previous messageGo to next message
Nice job!
I've got 270x20mm brembo discs with Mazda 4-spot calipers and that only just fits inside a 14" cast alloy rim. The extra 30mm will make it tough even for 15" rims I think. Those 300mm disks are HUGE! Very Happy
We had trouble with the offset of my rims because the caliper fouled on the raised part of the inside of the rim. Once the caliper was releaved of some fins and shaped and we added a couple of laser-cut spacers everything is cool! So I'd be wary of the offset (Mine are +26) and construction (I've heard the 3-piece are a PITA) of the rims you get as well.
Dan
Edit: Spelling (or the lack thereof...)
[Updated on: Mon, 26 July 2004 10:19]
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:28 Go to previous messageGo to next message
It all comes down to the brand and make of the rim. I have tried some other 14 inch alloy rims(minilites) and they were no way near going to fit.
My 16 inch PCW rims also fit with tons of room to spare.
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:29 Go to previous messageGo to next message
gabe wrote on Mon, 26 July 2004 19:51
Thanks mate. I cant remember what grade alloy we used but I remember telling you Rolling Eyes
dcleyne
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:35 Go to previous messageGo to next message
Yup, It's the 14" minilites that I've got. When we originally setup to do the work we checked my wheels against a Sprinter that was in the shop with the exact brake conversion already done to it. We thought the rims were identical and so proceeded. Apparently the offsets must have been different...
Anyhow, why would you bother with 14" alloys with a 5-stud pattern? The reason I chose the path I did because it was going to work with the wheels that were already on the car (thereby saving the cost of new rims and tyres).
How wide do you want to go with rubber? 225? 235? bigger?
Dan
gabe
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:42 Go to previous messageGo to next message
Yep, 7076 if I remember rightly
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 10:51 Go to previous messageGo to next message
dcleyne wrote on Mon, 26 July 2004 20:35
Dan
I only really want to go 225's on the back with 15 inch rims. Maybe 16 just depends on what I think looks better. I dont really like low profile tyres on old cars.
fade-e
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 11:01 Go to previous messageGo to next message
i agree with ya Cool1! low profiles Confused understandablew we do all these mods to perfect the car but im not one for killing the look completely and the mods we do dont kill/affect the look but make it a better car
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 11:07 Go to previous messageGo to next message
Exactly.
dcleyne
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 11:12 Go to previous messageGo to next message
I agree. Mine are 195x60x14 and I'm happy with the way it looks... I'd like to see pictures of what you end up with!
Dan
clubagreenie
1st street on the right
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 11:58 Go to previous messageGo to next message
FYI
some, not all square profile threads are called ACME threads.
Re: My new brake setup (570k worth of pictures) Mon, 26 July 2004 12:06 Go to previous messageGo to next message
clubagreenie wrote on Mon, 26 July 2004 21:58
FYI
Could be. I wouldn't know. But I do know that the thread on the bolts we used is the best for this application.
The bolts in question are to hold the turn table on the back of prime movers.
TheNav
Re: My new brake setup (570k worth of pictures) Thu, 29 July 2004 23:36 Go to previous messageGo to next message
Hey Cool1, i was just wondering how much this brake setup cost you all up and if possible could you make a setup like this for me, only if its not too much trouble and if you have the time.
Re: My new brake setup (570k worth of pictures) Fri, 30 July 2004 08:11 Go to previous messageGo to next message
The brackets could be worth about $200 each but I wouldn't know without going into it further.
I have been thinking about designing a brake setup using the RA40 strut and hub. It would probably use the 4 pot Mazda caliper and a suitably large rotor.
But you'll have to wait and see if this happens Very Happy
TA-022
Glenmore Park, NSW
Re: My new brake setup (570k worth of pictures) Sun, 19 December 2004 11:53 Go to previous messageGo to next message
just a qwikie on threads.
fine isnt stonger than coarse and vice versa.
it all comes down to application... as in coarse thread is better for timber work because a fine thread tends to spin out and de-coil the thread.
*food for thought*
boris
On probation
Brisbane, Queensland
Re: My new brake setup (570k worth of pictures) Sun, 19 December 2004 11:54 Go to previous messageGo to next message
Dude this is quite old....
Re: My new brake setup (570k worth of pictures) Sun, 19 December 2004 11:55 Go to previous messageGo to next message
TA-022 wrote on Sun, 19 December 2004 21:53
*food for thought*
Thats not totally fact. As stated above the bolts I used are fine thread but they are square threads.
TA-022
Glenmore Park, NSW
Re: My new brake setup (570k worth of pictures) Mon, 20 December 2004 08:32 Go to previous messageGo to next message
old yes but still worth talking about.
anyhooo my point was threads all depend on the intended application.
you cant just state one is better than the other.
/end rant
Steve_Reynolds
Gold Coast
Re: My new brake setup (570k worth of pictures) Tue, 21 December 2004 02:09 Go to previous messageGo to next message
I realise this is an old thread, ( & nice conversion Shane) but a quick comment on the Mazda alloy calipers. For those who are contemplating using them, do NOT grind off the small raised rectangular section just below the raised 'Mazda' word.
That raised section houses the brake fluid gallery from one piston to the neighbouring piston. A mate who races a RX3 ground it off as it was interfering with a wheel he wanted to try out, and hey presto, brake fluid everywhere and a stuffed caliper.......very bad idea!!!
Just passing on some info after reading a comment above about grinding things off..................
Steve
Re: My new brake setup (570k worth of pictures) Tue, 21 December 2004 02:29 Go to previous messageGo to next message
Steve_Reynolds wrote on Tue, 21 December 2004 12:09
Steve
Haha thats funny.
Does your mate want to sell those calipers?
Steve_Reynolds
Gold Coast
Re: My new brake setup (570k worth of pictures) Tue, 21 December 2004 02:33 Go to previous messageGo to next message
This happened about 5 years ago Shane, so I doubt he'd still have them...........
Re: My new brake setup (570k worth of pictures) Tue, 21 December 2004 03:45 Go to previous messageGo to next message
DOH. No problem.
wil8115
Seattle area, USA
Re: My new brake setup (570k worth of pictures) Fri, 31 December 2004 19:45 Go to previous messageGo to next message
So what did the custom bracket cost to produce? Do you have the blueprints?
Will
Re: My new brake setup (570k worth of pictures) Sat, 01 January 2005 04:42 Go to previous messageGo to next message
I'm not really sure what the brackets cost me, but it wasn't much. And there are no drawings available for the brackets.
However I am in the process of designing a new brake setup using RA40 struts, RX7 calipers and a rotor that will hopefully fit under 14 inch wheels. If anyone is interested you maybe able to purchase some brackets off me to suit.
foxtail
January 2005
Re: My new brake setup (570k worth of pictures) Mon, 03 January 2005 10:09 Go to previous messageGo to next message
My ke70 panelvan has AE86 struts with similar custom brackets and wide body camry discs and single spot calipers. The discs are 28mm wide and i had to lightly shave the calipers to get my 14s on. I have never been able to overheat or even smoke these brakes down any will at any speed. Would recomend a master upgrade tho.
Here is a tip - Skyline 4 spot calipers bolt directly onto RA60 struts. You will need bigger discs and machine 10-12mm off the back of the hub tho.
Good luck.
http://www.users.tpg.com.au/foxtail/pics/B1.jpg
http://www.users.tpg.com.au/foxtail/pics/B2.jpg
Re: My new brake setup (570k worth of pictures) Mon, 03 January 2005 11:57 Go to previous messageGo to next message
But skyline calipers blow and RA60 struts dont suit early celicas!
rsdeo
Burlington, On. Canada
Re: My new brake setup (570k worth of pictures) Mon, 03 January 2005 19:52 Go to previous messageGo to next message
What year RX-7 are the calipers from and what is the distance between the caliper mounting holes center to center?
Thanks.
Re: My new brake setup (570k worth of pictures) Tue, 04 January 2005 06:46 Go to previous messageGo to next message
Cool1 wrote on Mon, 03 January 2005 19:57
Any particular reason?
Re: My new brake setup (570k worth of pictures) Tue, 04 January 2005 06:56 Go to previous messageGo to next message
About the skyline calipers?
Re: My new brake setup (570k worth of pictures) Tue, 04 January 2005 07:04 Go to previous messageGo to next message
Ah, yes, sorry, shoulda made that more clear.
Re: My new brake setup (570k worth of pictures) Tue, 04 January 2005 07:12 Go to previous messageGo to next message
Nothing really. Just that they are bigger and bulkier than the Mazda caliper. This is not a realy problem unless your trying to use them on big rotors under small wheels like I was Very Happy
Re: My new brake setup (570k worth of pictures) Tue, 04 January 2005 07:17 Go to previous messageGo to previous message
Cool1 wrote on Tue, 04 January 2005 15:12
Ah k, gotcha.
Nissan 4spots + 280mm rotors fit under 15" wheels btw.
Previous Topic:Early Celica parts.
Next Topic:AE86 Brake kit. Massive.
Current Time: Sat Oct 24 05:41:08 UTC 2026
Total time taken to generate the page: 0.010643005371094 seconds
