Toymods » Tech & Conversions » AE86 EFi fuel tanks
45aken
NSW.south coast.Drifting
icon2.gif  AE86 EFi fuel tanks Sun, 25 July 2004 04:58 Go to next message
just wondering if i bought an EFI fuel tank for my 4AGTE conversion, i would definately need a bigger pump right? and are there and bigger pumps avaliable for straight drop in without modifications eg surge tanks etc?
ae86drift
sydney.au
Re: AE86 EFi fuel tanks Sun, 25 July 2004 06:49 Go to previous messageGo to next message
efi an carby tanks are identical
you need a different pump bracket (may have to make something up) and an efi pump from an ae82/ae92
shcao
Re: AE86 EFi fuel tanks Sun, 25 July 2004 07:07 Go to previous messageGo to next message
you could by the EFI fuel gasket (the arm and the piping) that holds the fuel pump from toyota brand new for about $400.
Then go to repco and buy a ae92 pump for about 150. In the end, it's pretty much like a JDM tank. No messing about, no surges.
rock on.
But then again, the ae92 fuel pump may not be enough to feed a 4gte..
45aken
Re: AE86 EFi fuel tanks Sun, 25 July 2004 18:14 Go to previous messageGo to next message
hmmmm
will the bracket from an ae82/92 fit in my tank with little modification and are there replacement pumps avaliable that will be enough to support the 4agte?
cuz if it costs $400 from toyota, im better off buying a jdm tank for the forum and then putting an a bigger pump.
pepsicola
Re: AE86 EFi fuel tanks Sun, 25 July 2004 18:16 Go to previous messageGo to next message
i've heard that 7mgte pump drop it with little mod.
try ask around in club4ag.com
45aken
Re: AE86 EFi fuel tanks Mon, 26 July 2004 08:00 Go to previous messageGo to next message
will do.
im leaning towards this idea of using a JDM tank then dropping in a bigger pump. because modifications = $$$ so id rather spend my hard earned moeny on other stuff, like tyres Shocked
ae86drift
sydney.au
Re: AE86 EFi fuel tanks Mon, 26 July 2004 08:28 Go to previous messageGo to next message
get a walboro pump
http://www.fuel-pumps.net/p527.html
expensive but the best!
my thread (pics at bottom)
it may help you.. maybe not
http://forums.toymods.org.au/index.php?t=msg&t h=38227&rid=964&S=1e77298e9276762b6ea9e520 fd51e2d6
ae95
Re: AE86 EFi fuel tanks Mon, 26 July 2004 18:05 Go to previous messageGo to next message
ae86drift wrote on Sun, 25 July 2004 14:49
Are you 100% sure?
I was told the efi tank has baffles in it Confused
Re: AE86 EFi fuel tanks Thu, 29 July 2004 12:18 Go to previous messageGo to next message
useful thread AE86drift.
Question though - did you ever get to compare the brackets of the AE82 pump and your AE86 pump?
Reason i ask is im going to be doing some EFI fuel system for a sprintah on the weekend, and i've never taken these intank pumps out myself.
Ill head down to piccies on saturday morning and see what i see i spose. But if anyone knows how different they are i'd appreciate it.
shcao
Re: AE86 EFi fuel tanks Fri, 30 July 2004 06:33 Go to previous messageGo to next message
the ae82 fuel gastket will fit the mouth of the ae86 tank.. Except, it sits the fuel pump a little higher. Just extend those metal arms a little longer, and it'll be ok
ra23celica
Re: AE86 EFi fuel tanks Fri, 30 July 2004 06:38 Go to previous messageGo to next message
EFI tanks *are* different from carb car tanks....look at the internal baffling arrangements and most importantly, the venting systems in place and you will see why.
AE86slut
Baulko Hillo
Re: AE86 EFi fuel tanks Fri, 30 July 2004 07:04 Go to previous messageGo to next message
Just do this... Works well....
http://img.photobucket.com/albums/v298/AE86slut/fuelpump2.jpg
http://img.photobucket.com/albums/v298/AE86slut/fuelpump1.jpg
Re: AE86 EFi fuel tanks Fri, 30 July 2004 07:22 Go to previous messageGo to next message
nifty Smile
lucky for me i have some spare 18g aluminium sheeting here Smile
Anyone see a problem with aluminium in petrol?
I could use steel, but im lazy.
ae95
Re: AE86 EFi fuel tanks Fri, 30 July 2004 07:58 Go to previous message
ra23celica wrote on Fri, 30 July 2004 14:38
Thought so. The amount of misinformation on these forums should be cut down somehow. Nothing is more annoying than getting wrong information.
Previous Topic:Engines to fit my W55
Next Topic:3sgte ecu's
Current Time: Mon Oct 26 07:32:34 UTC 2026
Total time taken to generate the page: 0.055878877639771 seconds
