Toymods » Tech & Conversions » 22re problems
cthulhu
22re problems Sun, 25 July 2004 06:10 Go to next message
what seemed to start off as changing the head gasket on my 22re and turned into a dilemma
since we changed the gasket the engine would back fire badly so the mechanic recommended several different things so far ive had the head reconditioned the valves replaced new afm and new ignition system and the engine still wont seem to run
we cant seem to get it to idle at all and even at 2500 rpm it shakes madly and there seems to be a chuffling noise coming out of the afm
it almost seems as if its only running on 2 cyclinders but we cant be too sure of that atm any help i can get on the situation would be grateful
also im just considering getting rid of the 22re the way its running and throwing in a 1g the heart says yes but the bank account says no
fade-e
Re: 22re problems Sun, 25 July 2004 06:18 Go to previous messageGo to next message
who did the headgasket? if it was a mechanic then i would give him the car and say 'FIX IT CAUSE YOU STUFFED IT?'
if it was you then how exactly did you replace it? did you hake everything off first and replace the headgasket or just took of the head with everything still attached?
if everything was still attached then there is no reason at all that it would be anything other then the headgasket put on wrong (it can happen) or got damaged while being put pon and bolted down...
if you pulled everything off to get to the head and replace the gasket then all gaskets need to be replaced from head up otherwise it WILL leak no matter what you try (this is what i have found in the past)
cthulhu
Re: 22re problems Sun, 25 July 2004 06:22 Go to previous messageGo to next message
the first time we replaced it we took the head off with everything attched and thats when the problems started with two of the valves bending and supposedly the afm getting bent aswell from a huge back fire apparently
then we stripped the entire head took it to get fixed and all then redid everything replacing all the gaskets that we had to and the problem still persists
oh and also its was me and my dad who replaced the gaskets so far weve just had a mobile mechancic look at it for us to give us an opinion
[Updated on: Sun, 25 July 2004 06:23]
fade-e
Re: 22re problems Sun, 25 July 2004 06:38 Go to previous messageGo to next message
i find it hard to believe that valves were bent from a backfire (but im not an expert)
is the backfire from the exhaust or plenum/air filter?
could be timing needs adjusting? i havent seen a 22re so are they OHC/DOHC or UHC?
cthulhu
Re: 22re problems Sun, 25 July 2004 06:43 Go to previous messageGo to next message
the valves that got bent were on the intake side on cyclinder 3 and 4 it was the little shaft part thats was bent so that they wouldnt close properly on time
the timing was really bad when it first happened but then we fixed it and the mechanic said the timing was close to perfect and the timing is the same as before so were stumped for ideas most likely having the guy look at it again tomorrow
and the 22re is ohc
fade-e
Re: 22re problems Sun, 25 July 2004 06:50 Go to previous messageGo to next message
in that case did you put the cam back on in the right place? you could gave it that cylinder one is open but cylinder 4 is firing and THAT WOULD DEFINATELY BEND VALVES and even BLOW THINGS UP
very dangerous having cam put on wrong/wrong angle
when you took the head of did you measure the cam/crank chain to get the right placement? there is a dot on crank and on cam that need to be aligned correctly... this is usually done before taing head off by counting the number of joints on the chain from dot to dot when cylinder 1 is at TDC
very possible and most likely cam on wrong issue...
cthulhu
Re: 22re problems Sun, 25 July 2004 07:46 Go to previous messageGo to next message
when we took the head off and put it back on we had the 2 dots lined up but it may be possible what your saying there ive suggested it might be on the wrong angle but my dad insisted that it was right
fade-e
Re: 22re problems Sun, 25 July 2004 07:52 Go to previous messageGo to next message
yeah but it could be off by 180deg... which why im saying first cyl open and fourth firing...
Stefan
Hobart, Tas
Re: 22re problems Thu, 29 July 2004 09:50 Go to previous messageGo to next message
What is happening now for you sounds exactly like when me & my dad did the timing chain on the 22RE in my ra65 about 3 years ago. We were out a tooth or 2 on the cam chain, and had to slip the top cam gear forward onto a dowel and then turn the cranksgadt and then slip in back on again (if I remember right).
See, the dot you line up is slightly offset to one side (IIRC) which is confusing. Sorry I can't remember any more, but your symptoms sounds exactly the same.
Hot Celica
Re: 22re problems Thu, 29 July 2004 09:58 Go to previous messageGo to next message
your cam timing is stuffed, take it to a real mechanic
people100
Rocklea qld
Re: 22re problems Thu, 29 July 2004 12:11 Go to previous messageGo to next message
or possibly dizzy timing. Arent the dizzies in the head. But i agree. If you didnt know exactly how to do it apart from doing some dots you shouldnt have done it.
Hot Celica
Re: 22re problems Thu, 29 July 2004 13:12 Go to previous messageGo to next message
dizzy is run off cam gear, its the cam timing that is wrong if there is bent valves
Hot Celica
Re: 22re problems Thu, 29 July 2004 13:14 Go to previous messageGo to next message
i have a spare 22re here that i dont want, if you want the head pm me
Re: 22re problems Thu, 29 July 2004 13:21 Go to previous messageGo to next message
cthulhu wrote on Sun, 25 July 2004 16:10
<snip>
sounds like timing is way out (hence the cam timing suggestions ) and/or plug leads not on right spots on dizzi (wrong firing order)
bent valve can only be dud cam timing
so instead of throwing yet more money at a boat anchor, spend even more on the 1G. Seeing as your dad helped, make him pay half Wink
cthulhu
Re: 22re problems Thu, 29 July 2004 14:59 Go to previous messageGo to next message
Stefan wrote on Thu, 29 July 2004 19:20
when we set the timing back up we had the dot on the cam at the very centre so this sounds most likely it if this is the problem it may save me another $200
as ive said earlier i wouldnt be able to afford the 1g and i doubt my dad will be willing to fork out the money for it it would just be better i reckon to go out and get a ma70 probly even the same price in the end
[Updated on: Thu, 29 July 2004 15:01]
Hot Celica
Re: 22re problems Thu, 29 July 2004 23:27 Go to previous messageGo to next message
you need to have the dot on the cam exactly where it was before in relationship to the chain as well as the position of the cam
i would have thought a free cylinder head would be cheaper than a new car but what do i know Rolling Eyes
Stefan
Hobart, Tas
Re: 22re problems Fri, 30 July 2004 13:59 Go to previous messageGo to next message
LOL
Yes, straight up was what I did the first time, but IIRC the dot is off to one side. Can't remember which. Join the Old Celica Club @ www.celicas.org and ask the 22RE gurus there.
cthulhu
Re: 22re problems Fri, 06 August 2004 14:19 Go to previous message
well we found the problem the rockers were too loose to make contact Rolling Eyes so the valves werent opening fully or at all but the problems are now fixed the block has a crack or something and is pissing oil everywhere so were throwing it away
Previous Topic:how 20v's VVT work? want to mod into adjustable pulley
Next Topic:4agze injectors
Current Time: Sat Oct 24 05:21:32 UTC 2026
Total time taken to generate the page: 0.035195112228394 seconds
