Toymods » Tech & Conversions » BOV install
dwango
BOV install Sun, 25 July 2004 10:17 Go to next message
I am just about to get a guy at virginia to install a BOV (to atmosphere) in my '90 GT4. I know he doesn't have a dyno. Can he do a good job, is it possible.
How much damage can be done.
-==L=a=N=c=E==-
Brisbane, Queensland
Re: BOV install Sun, 25 July 2004 10:18 Go to previous messageGo to next message
The problems that you might encounter installing the BOv, is that you will run overly rich between gear changes, because of the AFM system.
Thats about the only damage that could happen. Installing a BOV is peanuts.
dwango
Re: BOV install Sun, 25 July 2004 10:25 Go to previous messageGo to next message
Well he says he will calibrate it. can he do this minus one dynometer
Re: BOV install Sun, 25 July 2004 10:37 Go to previous messageGo to next message
ummm... i don't think you need a dyno to calibrate a BoV... at all.
any adjustment (if the unit allows it) can be done with hood up and then a quick drive around the industrial estate.
also ... your engine's ECU (progrmming actually) is not designed for air to be lost from the induction system post-turbo (hence the AFM comment from lance). expect a bit more popping from exhaust when changing gears.
dwango
Re: BOV install Sun, 25 July 2004 10:57 Go to previous messageGo to next message
Is there a way around this.
dwango
Re: BOV install Sun, 25 July 2004 10:59 Go to previous messageGo to next message
Is there a way around this programming problem ??
Re: BOV install Sun, 25 July 2004 11:00 Go to previous messageGo to next message
Who is he? And have I seen your GT4 around here before?
Re: BOV install Sun, 25 July 2004 11:02 Go to previous messageGo to next message
yes...
obvious answer: don't by a BoV that vents 100% to atmo
seriously tho: if you vent into the intake pipe post-AFM, you'll still get [i]some[/]i of the sound that the atmo BoV would have given you....
unless you're running a programmable ECU (e.g. after market) then i doubt there is any ECU-related solution to this.
i thnk there's a few recent BoV threads that cover this.
dwango
Re: BOV install Sun, 25 July 2004 11:19 Go to previous messageGo to next message
He is DriftKing. And no i have only owned the car for about 2 months.
And bugger.
I get a pop or a small bang at the moment about 1 occasion every second or third time i drive the car.
Is stock bar 2 1/2" exhaust.
Re: BOV install Sun, 25 July 2004 11:27 Go to previous messageGo to next message
Oh no, not dorifto king Confused
Jag7799
Re: BOV install Sun, 25 July 2004 11:50 Go to previous messageGo to next message
just make sure u let them put a HUGE sticker down the side of your car while ur there
i hate drift king peoples cars
dwango
Re: BOV install Sun, 25 July 2004 12:27 Go to previous messageGo to next message
Yeah i have a mate with the same car as mine who's car got questionable treatment and stickered to death.
That's why i'm asking how much damage can be done.
Jag7799
Re: BOV install Sun, 25 July 2004 12:33 Go to previous messageGo to next message
ring up mercury motorsport and go to their place.. id trust them
dwango
Re: BOV install Wed, 28 July 2004 04:34 Go to previous messageGo to next message
yup well i took ur advice and got mercury to do it today.
As luck would have it the Redline BOV i purchased doesn't dump to atmosphere in 1 great fucken wiss. It's a variable valve release which seems to overcome at least some of the problem of backfires. After a couple of adjustments and a few rather loud explosions coming from the bottom of the car later and we seem to have found a sweet spot.
Boost next!!
thanks for all your help folks.
SIKRA40
Re: BOV install Wed, 28 July 2004 09:48 Go to previous message
Cool1 wrote on Sun, 25 July 2004 21:27
LMFAO i agree. drift king is not the best place to go.
Previous Topic:4agze TRD metal clutch
Next Topic:4age coil & Ignitor Q's
Current Time: Tue Oct 13 22:06:07 UTC 2026
Total time taken to generate the page: 0.073976993560791 seconds
