Toymods » Tech & Conversions » steering rack troubles!
ae86slaver
steering rack troubles! Mon, 26 July 2004 00:51 Go to next message
hi guys,
I'm in the process of replacing the barrel and cast alloy ignition housing on my steering rack (car was broken into). I managed to get my hands on a complete steering rack, and i'm having troubles getting this ignition casing off the main part of the rack. I have already unscrewed the 2 hex bolts and grinded off the grub screw, but after many attempts of pulling and twisting, it seems as if it was not meant to come off so easily. Do i need to remove the entire shaft? If so, how?
Or do i have to dread replacing the whole rack from steering wheel to end pinion? Rolling Eyes
[Updated on: Tue, 27 July 2004 05:46]
Re: steering rack troubles! [ae86] Mon, 26 July 2004 01:22 Go to previous messageGo to next message
you mean steering column?
takai
Re: steering rack troubles! [ae86] Mon, 26 July 2004 01:24 Go to previous messageGo to next message
There is a really small circlip on the shaft, really really tight. Took me a few times to get it off the first time, But once you have practice its ok.
From then on off its pretty tight, but just lever it off slowly with progressively bigger screwdrivers.
Edit: its covered by a metal plate with 3 screws holding it to the ignition barrel module.
[Updated on: Mon, 26 July 2004 01:25]
ae86slaver
Re: steering rack troubles! [ae86] Mon, 26 July 2004 01:34 Go to previous messageGo to next message
you mean that plate which covers the ball bearings?
takai
Re: steering rack troubles! [ae86] Mon, 26 July 2004 01:55 Go to previous messageGo to next message
Yes, under that plate. Right up next to the bearing there is a circlip.
ae86slaver
Re: steering rack troubles! [ae86] Mon, 26 July 2004 03:36 Go to previous messageGo to next message
so basically i just use a small flathead and try to wedge that circlip out and the ignition key unit should slide off the shaft?
takai
Re: steering rack troubles! [ae86] Mon, 26 July 2004 05:17 Go to previous messageGo to next message
Try using cirlip pliers, 200x easier.
ae86slaver
Re: steering rack troubles! [ae86] Mon, 26 July 2004 05:26 Go to previous messageGo to next message
hmm.....what do they look like?
description?
takai
Re: steering rack troubles! [ae86] Mon, 26 July 2004 05:28 Go to previous messageGo to next message
http://www.google.com/search?q=circlip+pliers& ie=UTF-8&oe=UTF-8
ae86slaver
Re: steering rack troubles! [ae86] Mon, 26 July 2004 05:54 Go to previous messageGo to next message
So i'm gathering that this circlip is a round 'circular clip' that i need to grab out with pliers?
From what i saw, there was not much space (if any) is this all that needs to be removed ?
ae86slaver
Re: steering rack troubles! [ae86] Tue, 27 July 2004 04:58 Go to previous messageGo to next message
hmmm....harder to remove then i thought. Anyone have circlip pliers for me to borrow?
V8_MA61
Re: steering rack troubles! **need to borrow circlip pliers** Tue, 27 July 2004 05:06 Go to previous messageGo to next message
go to a hardware store and spend $10
ae86slaver
Re: steering rack troubles! **need to borrow circlip pliers** Tue, 27 July 2004 05:16 Go to previous messageGo to next message
Got quoted $40 and not even the right ones
don't particularly wanna spend so much for a tool i'll be using twice Rolling Eyes
but hey, i might have to if all else fails
ae86trueno
Re: steering rack troubles! **need to borrow circlip pliers** Tue, 27 July 2004 05:47 Go to previous messageGo to next message
I picked mine up at K-mart Laughing
cost like $15 and can do inner and outer circlip and has a couple of ends to do big and small ones.
best $15 i ever spent.
Ben.
ae86slaver
Re: steering rack troubles! Tue, 27 July 2004 05:51 Go to previous message
awesome
*aquired*
thank you all Very Happy
Previous Topic:sprinter hub
Next Topic:MA61 Steering
Current Time: Sun Nov 22 08:16:01 UTC 2026
Total time taken to generate the page: 0.0060489177703857 seconds
