Toymods » Members Rides » BigWorm's RA-23 Celica
BigWorm
Toymods Board Member
Turramurra, Sydney.
BigWorm's RA-23 Celica Tue, 14 May 2002 08:22 Go to next message
It's about time for a bit of an update I think.....
http://forums.toymods.org.au/index.php?t=getfile&id=4520&rid=37&S=9ef866a5f9898fbcabac2d5171b392a1
http://forums.toymods.org.au/index.php?t=getfile&id=4521&rid=37&S=9ef866a5f9898fbcabac2d5171b392a1
http://forums.toymods.org.au/index.php?t=getfile&id=4522&rid=37&S=9ef866a5f9898fbcabac2d5171b392a1
http://www.toymods.org.au/gallery/albums/Gallery/Events/Dyno%20Day%2010/normal_DCP_0341.jpg
YEAR/MAKE/MODEL
1976 Toyota Celica RA-23
ENGINE
4A-GTE.
1.6L, twin cam, 16V, EFI, turbo.
ENGINE HARDWARE & ACCESSORIES
AE101 4A-GZE block,
GZE crank,
GZE rods, linished & shotpeened,
New GZE 8.9:1 ceramic & teflon coated pistons,
custom 7075 T7 alloy crank pulley,
4A-GE bigport head, match-ported,
HKS 1.6mm metal head gasket (9:1 C/R),
bigport cams,
Performance Springs 50lbs valve springs,
20V oil pump,
bigport RWD intake manifold, match-ported,
custom phenolic spacer between intake manifold & head, also match-ported,
13B turbo 550cc injectors,
Sard adjustable fuel pressure regulator,
standard 4A-GE 55mm throttle body,
ARE 440x300x76 tube & fin intercooler,
2" pre-cooler & 2.5" post-cooler alloy piping,
Trust Type-R BOV,
K&N 6" pod filter in alloy box,
HKS GT2510 turbo,
custom JMR turbo manifold, match-ported,
HPC coated turbine housing & manifold,
3" dump pipe with seperate wastegate pipe,
3" hi-flow cat,
3" mandrel exhaust,
2 1/2" stainless Genie turbo muffler,
4x Bosch coils,
custom Magnecor leads,
surge tank,
Bosch 040 fuel pump,
High Volume lift pump,
oil cooler with standard toyota oil bypass setup,
Noltec RX-7 urethane engine mounts,
Blitz SBC-iD III electronic boost controller,
Autronic SMC,
Autronic CDI unit.
DRIVELINE
W58 supra 5 speed,
4A-GZE 224mm flywheel,
5 puck sprung centre ceramic button clutch,
880kG modified pressure plate,
2.5" one piece driveshaft,
and a new diff on its way.....
SUSPENSION
K-Mac springs (lowered 2"),
K-Mac 24mm F & 17mm R anti-roll bars,
Front: Koni yellow (externally) adjustable shocks, to suite a Rav-4,
Rear: Koni red (internally) adjustable shocks, also to suite Rav-4, 15mm shorther than standard Celica,
Whiteline adjustable panhard rod,
Whiteline strut brace,
custom 31mm RCAs.
BRAKES
Corona struts,
10.5" vented discs,
Corona twin piston calipers,
Landcruiser 1" bore master cylinder,
Stock rear drums.
BODYWORK
DuPont 2-pac orange paint,
rust removed,
antenna & badges deleted.
ROLLING STOCK
Performance Lotus 16"x7" alloys, powdercoated white,
205/45x16 Dunlop FM901s.
INTERIOR GADGETRY
Autometer 2 1/4" oil press. gauge,
Autometer 2 1/4" boost guage,
custom white face speedometer & temp/fuel guges,
Smiths Motorsports 10,000rpm tachometer,
Blitz SBC-iD III boost controller,
alloy shift knob,
Recaro reclining bucket seat,
Momo suede steering wheel,
shiny (& legal) alloy pedals,
velour hood lining,
battery in boot.
STEREO COMPONENTS
Kenwood Mini Disc Head Unit,
Kenwood 6 CD stacker,
Kenwood 220W 7x10" 3-ways in parcel shelf,
Clarion 6" 2-ways in doors
FUTURE MODS
Coilovers,
adj. strut tops,
Volvo diff & disc brakes,
LSD to suit,
bigger discs & calipers (ST205 would be nice),
rollcage & harness maybe,
could go on for ever..........
More pictures can be viewed at: http://members.optushome.com.au/big.worm/images2/p age_01.htm
This is red.
[Updated on: Thu, 28 July 2005 08:55]
Les
Re: Joel's RA-23 Celica Wed, 15 May 2002 02:15 Go to previous messageGo to next message
LOVE THIS CAR MATE...
troyboy
Colyton, NSW
Re: Joel's RA-23 Celica Wed, 15 May 2002 09:24 Go to previous messageGo to next message
Joel,
U legend..
must be happy with all the effort put into the car!
Sweet As!
Twinky
N.S.W
icon5.gif  Re: Joel's RA-23 Celica Wed, 15 May 2002 12:41 Go to previous messageGo to next message
Is it just me or can you see through that timing belt cover?? Isnt that plastic like 5mm thick??
BTW, when you painted the rocker covers, did you just use the same paint as the car or is it like heat resistant? Cause I wanna paint mine gold when I get my car painted and I dont want the paint to peel off.
[Updated on: Wed, 15 May 2002 12:43]
mr_messy
Re: Joel's RA-23 Celica Fri, 17 May 2002 11:36 Go to previous messageGo to next message
i Heart it also!..
MaNGeW
Formerly TRD_RoLLa
Re: Joel's RA-23 Celica Fri, 17 May 2002 12:50 Go to previous messageGo to next message
Nice work Joel. Everytime i see your car. I wanna drink some Fanta Rolling
Go the TVIS.
Nod
MaNGeW
Formerly TRD_RoLLa
Re: Joel's RA-23 Celica Fri, 17 May 2002 12:53 Go to previous messageGo to next message
BTW what ignitor you using? The 100kw /4agze one? Looks like the new style anyways. Also Are those VT blinkers you got there?
BigWorm
Turramurra, Sydney.
Re: Joel's RA-23 Celica Fri, 17 May 2002 16:20 Go to previous messageGo to next message
Thanks fellas, no matter how dissapointed I get with my car sometimes, hearing stuff like that makes it all worthwhile! Smile [cartman voice] I love you guys! [/cartman voice]
Twinky, yeah, you can see through the timing cover, a silly idea I had a while ago. You must have your monitor up too bright!
As for the rocker covers, it just so happens that Krylon Engine enamel 'chevrolet orange' is an almost perfect match for my paint, si I stocked up on a few cans of it, and painted most of my orange engine/bay parts in it. It's quite a good match.
Mat, you wouldn't believe how much fanta I've been drinking lately, whenever I go to buy a drink I just reach for the orange by instinct!
The ignitor is a bosch one I had to get for the microtech, and yeah, the indicators are VT. Gettong a bit common these days, I'm thinking about getting some echo ones.....
[Updated on: Fri, 17 May 2002 16:22]
Les
Short Shift Tue, 21 May 2002 01:57 Go to previous messageGo to next message
Hey dood,
someone sent me your way re a shart shifter for an RA65 celica.. can u assist ?
BigWorm
Turramurra, Sydney.
Re: Joel's RA-23 Celica Tue, 21 May 2002 02:04 Go to previous messageGo to next message
Well, here's a link to the photo's of the one I had made. It shoews you how to do it, but actually getting it done is a bit harder, unless you know someone with a milling machine and who can weld pretty well.
http://members.optushome.com.au/big.worm/quicksh.h tm
Guest
Re: Joel's RA-23 Celica Mon, 27 May 2002 06:16 Go to previous messageGo to next message
For the record, quality 2 pac paint will withstand temperatures such that would be found on a rocker cover.
So you can paint a lot of engine bits with 2 pac !!!
GIN51E
Berowra-Sydney
Re: Joel's RA-23 Celica Sun, 04 August 2002 22:52 Go to previous messageGo to next message
Bigworm thats not what you call an Engine bay, THIS is an Engine Bay Razz Razz Razz
http://www.planet.net.au/~gins/engine2.jpeg
Wish mine looked as good as yours, how do you keep it clean?
[Updated on: Sun, 04 August 2002 22:53]
BigWorm
Turramurra, Sydney.
Re: Joel's RA-23 Celica Tue, 01 July 2003 14:15 Go to previous messageGo to next message
Hmmm, it's about time I updated this! Smile
Re: Joel's RA-23 Celica Tue, 01 July 2003 15:28 Go to previous messageGo to next message
yes joel. PLease update it Smile
at least the latest "Fanta Racer" pics are up
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Tue, 18 May 2004 14:58 Go to previous messageGo to next message
OK, mega update now complete. Very Happy
Grega
melbourne.victoria.austra...
Re: BigWorm's RA-23 Celica Tue, 18 May 2004 20:20 Go to previous messageGo to next message
holy shit you have been busy
um your pix don't work either champ.
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 01:53 Go to previous messageGo to next message
How's that, do they work now???
AE86slut
Baulko Hillo
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 01:56 Go to previous messageGo to next message
Yep, and it looks bloody awesome too......
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 02:37 Go to previous messageGo to next message
Looks unreal mate! Smile When it is going to grace the roads again?
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 07:50 Go to previous messageGo to next message
yay! big shiny things with stuff.
Lucid
Toymods Club Secretary
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 09:45 Go to previous messageGo to next message
TurboRA28 wrote on Wed, 19 May 2004 12:37
Sooner than the Witzl's '28 I reckon!! Very Happy
IRA11Y
Club Member
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 11:17 Go to previous messageGo to next message
mmm pretty ... shame.. would have been nice to go aginst it atmo now my engines in Razz
and Karls hardly worth the effort of giving a spanking Shocked
[Updated on: Wed, 19 May 2004 11:18]
CrAiGzEE
south of the big smoke
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 12:16 Go to previous messageGo to next message
looking great mate!!
how much longer u wreckon?
edit: paul dont go there!! that car is long gone i doult we will see it again
[Updated on: Wed, 19 May 2004 12:19]
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 13:10 Go to previous messageGo to next message
BAH! long gone! Laughing such harsh words!
IT will return. I just want the corolla a little more reliable first so that i am not left stranded with no car AGAIN!
The wheels are already in motion for the celica actually...
BlackSupra
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 13:15 Go to previous messageGo to next message
THE WITZL wrote on Wed, 19 May 2004 23:10
Pushed them down the hill already? Razz
Joel, that is some seriously cool equipment there. Shocked
Re: BigWorm's RA-23 Celica Wed, 19 May 2004 13:17 Go to previous messageGo to next message
***feels a hijack occuring***
Actually no. I bought some carbies to get the bitch running again, from there i will inspect the damage to the "spare" motor and stick the smallport one back in. Then its EFI time, later.
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Thu, 20 May 2004 10:05 Go to previous messageGo to next message
Right, time for the net marshals to step in here & thwart this attempted hijack....
I'm trying to get it all finished by dyno day, and then a week and a half after that it will have been out of rego for 3 months, so there's another good deadline.
But things keep cropping up, now I'm coming to terms with spending 3Gs on an autronic setup. I'm getting as bad as rod, that'll make it 2 different turbos, 2 different intercoolers & 2 different ECUs before it's even on the road. Very Happy
The main things still needed are exhaust, intercooler piping, adaptors to bolt up to the compressors inlet & outlet, ECU & wiring, turbo water lines airfilter & intake setup, intercooler mounting, and then there's other non engine issues that need dealing with, so I've got plenty to keep myself busy.
Never mind, it should go a bit better than it used too. Wink
RAV-GT4
Toymods member
Rydalmere, NSW
Re: BigWorm's RA-23 Celica Sat, 22 May 2004 00:39 Go to previous messageGo to next message
First time I've actually seen your homepage Joel, some good stuff. Can't see all the pics of your car though (broken links).
This thing sure has come a long way... I didn't know it was even in a crash. I gotta get out more often methinks, right after the RAV's back on it's feet.
I'll be seeing you at the Dyno Day, if not sooner. Very Happy
Cheers, great work.
people100
Rocklea qld
Re: BigWorm's RA-23 Celica Sat, 22 May 2004 10:37 Go to previous messageGo to next message
can i buy your 4a injecters when you put the new ones in??? If so how much???
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Sat, 22 May 2004 13:36 Go to previous messageGo to next message
Hey Andrew, thanks mate, that website's a bit of a joke really, it could do with a bit of an update, to put it mildly! But at least I do have some documented evidence of my effort. Smile
People100, do you mean my old 4A-GE 186cc injectors, or the 4A-GZE 365cc injectors once I use the 13Bs? If you want the GE ones, they're yours for $50, if you want the GZE ones, sorry but I'll be holding on to 'em if I ever stop using them.
TE72_Turbo
Re: BigWorm's RA-23 Celica Mon, 24 May 2004 08:31 Go to previous messageGo to next message
nice work Cool looks tough as.
ta22celica_boy
Re: BigWorm's RA-23 Celica Tue, 25 May 2004 01:01 Go to previous messageGo to next message
hey nice car bigworm, looks sweet!! just wonderin if you could put a pic up of ur intercooler fitted as im looking at gettin the same one from are, possibly the 440x360 if it fits
cheers josh
YOGI8U
up yours!
Re: BigWorm's RA-23 Celica Tue, 25 May 2004 02:07 Go to previous messageGo to next message
Dude! bout time............
Looks the part, we will have to go on that cruise we are always talking about!
how did the 20v oil pump go??
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Wed, 26 May 2004 12:52 Go to previous messageGo to next message
Thanks phil, it should give you a little competition at least. Wink
G'day josh, I reckon there's at least another 100mm above my intercooler, so I reckon it would fit. I know the '22 & '23 radiator supports are a bit different. Here's a pic.
http://forums.toymods.org.au/index.php?t=getfile&id=4670
It does sit very close to the radiator here, but I can afford to space mine back a little. As you can see, you couldn't fit any wider if you plan to use the bumper bracket holes to run the cooler pipes through, I'm gonna stick a 90 degree hose on each end & hope it's not all too tight when the bumper goes back on, which I suspect it might be.
It also fits (just) behind the grille & bumper panels without any cutting or trimming.
Yogi, how are you mate?!?
I've actually got a cruise down the gong way on the agenda, you might have to bring the reincarnation of the beast. Smile
The 20v oil pump went well, I took it to work & pulled it apart, cleaned it all up & had the housing sand blasted, so it came up schmicko. Thanks heaps for that man, I owe you one.
NVD05X
parra
Re: BigWorm's RA-23 Celica Tue, 03 August 2004 09:25 Go to previous messageGo to next message
my mate at Rocco's was tellin me about this...
he reckons it looks even better in person...
i reckon if it looks this good on a screen i'd go blind in person!
nice work dude...
Ms Puzzleman
Lurnea
Re: BigWorm's RA-23 Celica Tue, 03 August 2004 10:38 Go to previous messageGo to next message
Hey Joel,
Love the photo's, your car looks awesome. Still haven't seen it up close but I'm impressed.
Cassie
CrAiGzEE
Re: BigWorm's RA-23 Celica Wed, 04 August 2004 11:44 Go to previous messageGo to next message
mate! updates come on!!
getting slack
Lucid
Re: BigWorm's RA-23 Celica Wed, 04 August 2004 22:41 Go to previous messageGo to next message
Yeah - Bring on some updates!!! It has to be getting close now right??!
BigWorm
Turramurra, Sydney.
Re: BigWorm's RA-23 Celica Sat, 07 August 2004 11:46 Go to previous messageGo to next message
Thanks for the kind words! Cool
Yeah it's not far off now, it's currently at Roccos Performance having the intercooler fitted, cooler pipes, turbo intake, exhaust, wastegate actuator bracket, etc made up, and with any luck it'll be coming home on monday.
Then it just needs the computer, CDI & loom installed, new headlight loom, all the interior reinstalled (retrimmed seats, new carpet, maybe new seatbelts) and the dash put back together. Plus there's a myriad of little thinkgs still needed.
Anyone got an old FWD 4AGE dizzy cap they don't need? I just need an old one to cut up & fashion a lid for my modified dizzy cam angle sensor.
Paul, you replaced yours recently? Surely it's due for a new one? Wink
Lucid
Re: BigWorm's RA-23 Celica Sat, 07 August 2004 23:58 Go to previous messageGo to next message
BigWorm wrote on Sat, 07 August 2004 21:46
Hehhe.. there's more vital things in my engine bay that need to be replaced first dude, sorry..
BlackSupra
Re: BigWorm's RA-23 Celica Sun, 08 August 2004 03:08 Go to previous messageGo to next message
Like the 4A? Laughing
Lucid
Re: BigWorm's RA-23 Celica Sun, 08 August 2004 09:16 Go to previous messageGo to next message
BlackSupra wrote on Sun, 08 August 2004 13:08
Laughing Good call.. Razz
But some parts of it certainly need to be replaced judging by the noises it's making. Crying or Very Sad
thetoyman75
Club President
icon6.gif  Re: BigWorm's RA-23 Celica Tue, 21 September 2004 09:22 Go to previous messageGo to next message
Dude,
The intercooler looks like it should be a great size, Tina's was just that inch or so too big so I had to trim alot of the front headlight and trim brackets
http://www.toymods.org.au/~rod/Celicas/Tina's%2028 /Intercooler%20fitted%20small.jpg
Was just thinking that the show n shine will be the first time I can remember both our cars being at the same place at the same time. Sure they will both be being pushed around lol but will be great to have em both out and about again.
Looks like you will beat me on road tho ya bastard, mine will be struggling for the January Dyno day. Sad
Josh,
The TA22 requires a much smaller cooler than you can fit in an xA23 or xA28. My core is 360mm x 360mm and 75mm thick, it only just clears some of the fittings and the tanks are angled just to clear a few areas. You could possibly go slightly bigger but at the expense of end tank design.
[Updated on: Tue, 21 September 2004 09:31]
Re: BigWorm's RA-23 Celica Tue, 21 September 2004 12:29 Go to previous messageGo to next message
go joel!
Go rod
GO TEAM 8 VALVE! Razz
looking good as usualy bigperm, keep going!
dimmy77_03
Potts Point, Sydney
Re: BigWorm's RA-23 Celica Fri, 10 December 2004 10:57 Go to previous messageGo to next message
Shocked looks very nice... Were the pics taken at Hyde Park? how did you get up there without getting told to piss off? Confused
I've tried 2 times now and they werent successful
TE72_Turbo
Re: BigWorm's RA-23 Celica Mon, 13 December 2004 12:05 Go to previous messageGo to next message
New pics of the completed engine bay? Cool
christo
Re: BigWorm's RA-23 Celica Sun, 26 December 2004 13:19 Go to previous messageGo to next message
This is one of the best looking 23's ive ever seen!!! Love it mate! CHRISTO
IRA11Y
Club Member
Re: BigWorm's RA-23 Celica Sun, 26 December 2004 20:13 Go to previous messageGo to next message
Hey Joel,
was nice to see the jaffa finally back on the road again. Will have to catch up with you to have a spin after xmas once its run in and the boost is .. urrrm .. tweaked Wink
Lucid
Re: BigWorm's RA-23 Celica Sun, 26 December 2004 22:13 Go to previous messageGo to next message
IRA11Y wrote on Mon, 27 December 2004 07:13
Lol.. Young Joel decided to give the boost a bit of a wind-up on the Freeway coming home the other night - Needless to say we were both quite impressed!! Surprised
CrAiGzEE
Re: BigWorm's RA-23 Celica Wed, 29 December 2004 09:37 Go to previous message
updates!!!
Previous Topic:nevs ra23 grunter rally car
Next Topic:4AGTE AE101
Current Time: Sat Oct 24 17:07:53 UTC 2026
Total time taken to generate the page: 0.0102219581604 seconds
