Toymods » Tech & Conversions » vacume lines diagram NEEDED 18rgeu
omegaman
SYDNEY
vacume lines diagram NEEDED 18rgeu Mon, 26 July 2004 07:46 Go to next message
I need to get my hands on a diagram showing the vacume lines locations. Eg. My 18rgeu dizzy has 2 vacuum line locations, 1 being advance the other (is it retard ?) where do I connect this line to. Also I have a charcoal cannister to connect, I'm contemplating removing this , is there any adjustments I need to make anywhere.
people100
Rocklea qld
Re: vacume lines diagram NEEDED 18rgeu Mon, 26 July 2004 09:01 Go to previous messageGo to next message
Standard 18geu dizzies usually have 1 vacuum line i think. Id say that someone has done a 22re changeover on your dizzy and when u do that you need the 22re vacuum advance. Id suggest either bridge it into the other vacuum line from the advance or just leave it disconnected.
enigma
Re: vacume lines diagram NEEDED 18rgeu Mon, 26 July 2004 10:01 Go to previous messageGo to next message
I just talked to my mechanic about vacuum advance today. In my case I am using the original 18rgu electronic dizzy so it may/maynot apply to your case.
He said that vacuum adv is mainly for idle/off-idle and mainly used in autos.
Also the vacuum needs to get be attached to each cylinder not just one otherwise it will screw your timing as each individual cylinder fires, making the vacuum inconsistent(assuming you have the std four separate chamber manifold)
So as far as I understand just rely on you mechanical adv.
omegaman
SYDNEY
Re: vacume lines diagram NEEDED 18rgeu Tue, 27 July 2004 08:29 Go to previous messageGo to next message
As far as the dizzy is concerned, I received a vacuum diag from toyota for an 18rgeu and it shows that the motor has a dizzy with 2 vacuume exits.Also my dizzy does say 18rgeu on the tag.The diag is a bit fuzzy from the fax but I think I can work it out. But it shows a lot of t sections but no conectins to the intake. any further advise on the cannister would be good.
SIKRA40
Re: vacume lines diagram NEEDED 18rgeu Tue, 27 July 2004 10:22 Go to previous messageGo to next message
is it possibel that you could send me a copy of that diagram? either scan it or i can pm u with my fax number. i am also chasing the vaccume diagrams for the 18r-geu engine.\
Dan
omegaman
SYDNEY
Re: vacume lines diagram NEEDED 18rgeu Fri, 30 July 2004 08:55 Go to previous messageGo to next message
pm me your fax number and I'll send it to you.
blackRA28
adelaide
Re: vacume lines diagram NEEDED 18rgeu Sat, 31 July 2004 11:00 Go to previous messageGo to next message
wana post it up if you guys can at all ?? heheh Cool
omegaman
SYDNEY
Re: vacume lines diagram NEEDED 18rgeu Mon, 02 August 2004 08:09 Go to previous messageGo to next message
I would post it up if you tell me how to.
beterthenu
Dubbo NSW
Re: vacume lines diagram NEEDED 18rgeu Sat, 12 March 2005 06:33 Go to previous message
did you end up working out what the 2 connections on the vacuum advance go to?
i need to know too.
Previous Topic:locked keys in MA70 :(- how to unlock?
Next Topic:Will air con parts from a 4ac fit a 4a-fc?
Current Time: Fri Nov 20 05:41:50 UTC 2026
Total time taken to generate the page: 0.018487930297852 seconds
