Toymods » Tech & Conversions » lsd centre what size
cramet
warrnambool
lsd centre what size Mon, 26 July 2004 10:37 Go to next message
iam geting a hilux diff shorten for my sprinter what centre should i get its going to be a daily driver and i want it to be suitable for the summertime drags
Re: lsd centre what size Mon, 26 July 2004 12:19 Go to previous messageGo to next message
Well you don't have any choice about the size, it's a Hilux diff so you need a centre to suit a Hilux diff!
If it's a dedicated drag car you want a spool. If you plan to drive it on the street, I'd recommend a heavy-duty clutch-type LSD of some description. A factory Hilux LSD might be OK (depending how much power you have), or you could go for something aftermarket like a PowerBrute.
Jonny2TG
Tasmania
Re: lsd centre what size Mon, 26 July 2004 13:00 Go to previous messageGo to next message
HiLux diffs are a G series, which is 8". HiLux 4wd's come with LSD, HiLux 2wd's don't. The newest HiLux's use a different diff code, but I expect they are still a 8" and the center may fit.
The standard HiLux LSD is a clutch pack type, which is pre-loaded with a coil spring in the center. This is the same as some Supra LSD's, which are also of the G series 8". (MA70)
cramet
warrnambool
Re: lsd centre what size Thu, 29 July 2004 09:17 Go to previous messageGo to next message
i ment to say was what ratio i should use
Jonny2TG
Tasmania
Re: lsd centre what size Thu, 29 July 2004 09:24 Go to previous messageGo to next message
It all depends what motor you run, and what you want to do. Alot of 4wd HiLuxs have a 4.3:1 ratio diff, which is perfect for a higher reving 4 cylinder motor. If are are into drags, there are calculators you can use to find the optimum diff ratio for your setup. 4.3:1 is often the factory ratio behind 18R-G, 2T-G and 4A-GE engines.
cramet
warrnambool
Re: lsd centre what size Sat, 31 July 2004 11:04 Go to previous message
iam building up a 4agte with a t28 turbo
were is this calculater your talking about
Previous Topic:Toyota E-Lock
Next Topic:2t-g stem seals
Current Time: Mon Nov 23 07:35:04 UTC 2026
Total time taken to generate the page: 0.0077629089355469 seconds
