Toymods » Tech & Conversions » connecting stock oil cooler on a 4a
EVOSTi
cambo
      no
connecting stock oil cooler on a 4a Tue, 27 July 2004 08:50 Go to next message
nearly finished my conversion, just wanna make sure i hook up the oil cooler corectly. ive mounted it upside down which i assume doesnt matter, as long as the feed from the oil sandwhich plate goes to the BOTTOM of the cooler, am i right?
its a GZE with regular 4afe oil cooler.
thanks.
EVOSTi
cambo
      no
Re: connecting stock oil cooler on a 4a Wed, 28 July 2004 06:26 Go to previous messageGo to next message
no ideas? anyone wanna go check out their SX corolla or anything?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: connecting stock oil cooler on a 4a Wed, 28 July 2004 13:14 Go to previous messageGo to next message
I would assume the feed from the sandwich plate should go to the top of the oil cooler, that way once it comes out of the oil line, which is easy to pump oil through, it can pretty much fall through the oil cooler, rather than having to be pumped up through it, which must be alot harder to do.
This is how I've hooked mine up, although it's not running yet.
It's also how pretty much all upright radiators flow, with the fluid flowing down through core.
EVOSTi
cambo
      no
Re: connecting stock oil cooler on a 4a Thu, 29 July 2004 06:15 Go to previous messageGo to next message
i just thought it may need to pump up through the bottom to ensure it fills up without any air pockets in the cooler.
Re: connecting stock oil cooler on a 4a Thu, 29 July 2004 07:24 Go to previous messageGo to next message
hey - how does everyone have their oil coolers draining into their sumps?
I pulled mine off a car where there was just a banjo bolt on the sump drain plug.... but then i saw my sisters AE92 csi which has like a special tube?
ARGH!
EVOSTi
cambo
      no
Re: connecting stock oil cooler on a 4a Thu, 29 July 2004 09:13 Go to previous messageGo to next message
i have only seen the banjo/sump plug one you have on the ae112 turbos for the oil return.
all ae82s, ae92s, ae95s etc ive seen have the special fitting on the sump halfway back up near the top.
Re: connecting stock oil cooler on a 4a Thu, 29 July 2004 09:32 Go to previous messageGo to next message
yeah thats what im talking about - my sisters AE92 has that!
Ill probably just pinch one from piccies later.
EVOSTi
cambo
      no
Re: connecting stock oil cooler on a 4a Thu, 29 July 2004 09:35 Go to previous message
how you gonna fit the sump in your pocket? unless you wanna drill a hole in your sump and weld a nut on the inside.
Previous Topic:my smallport 4age conversion - with no pics!
Next Topic:18rc coverted to efi.
Current Time: Thu Oct 22 05:05:29 UTC 2026
Total time taken to generate the page: 0.0063531398773193 seconds
