Toymods » Tech & Conversions » clutch
Jonny2TG
Tasmania
clutch Wed, 22 May 2002 08:24 Go to next message
I could not change gears very
well, as the clutch was not fully releasing. (2TG - 3T clutch). I tryed
bleading the line and
even honed the slave cylinder and got new seals. The clutch will still not
fully release, which makes it imposiable to change gears, or even select
reverse of 1st when stopped. I don't know what the problem is. Now I have
to remove the gearbox and see whats up! which I will be doing
tonight/tomorrow. I may need a new clutch. A mate at Repco said $140, or
$200 for a PBR "performance" clutch.
faulksy
Re: clutch Wed, 22 May 2002 12:24 Go to previous messageGo to next message
Sounds more like a clutch problem then a clutch master cylinder problem. Can u flick you pedal fully up with your foot? Does this achieve anything?
Jonny2TG
Tasmania
Re: clutch Wed, 22 May 2002 13:52 Go to previous messageGo to next message
I got my gearbox and clutch out now. Nothing seems too odd looking. I will get a new clutch anyhow and see if that fixes it.
maybe it is the fins or something, look ok. Or maybe the mastercylinder? I don't think so.
Jonny2TG
Tasmania
Re: clutch Wed, 22 May 2002 14:21 Go to previous messageGo to next message
Now the gearbox is off, and I have a small rear seal leak. I wonder if I can take the flywheel off and get a new rear seal? without taking the motor out or sump off?
thetoyman75
Club President
Re: clutch Wed, 22 May 2002 14:28 Go to previous messageGo to next message
Johny,
Your pivot point may not be adjusted properly or perhaps you have the wrong clutch fork ? Just something to look at while it is out !
Jonny2TG
Tasmania
Re: clutch Wed, 22 May 2002 14:55 Go to previous messageGo to next message
The fork, bellhousing, bearing, clutch, plate, slave cylinder all came from the same car (TE72), and it was working fine before. THere is no adjustment at the pivot or slave cylinder, and the fork is not bent. The slave cylinder is now honed with new seals, didn't fix the problem. I don't think the master cylinder creaps. I has to be the preasure plate some how.
So I will get the flywheel off too, replace rear seal. Machine flywheel? Not nessesary I think.
faulksy
Re: clutch Wed, 22 May 2002 15:00 Go to previous messageGo to next message
Is the pressure plate lose. Ive heard of in one case it was vibrating causing the cultch to depress. But that was on a manual with a cable clutch
Jonny2TG
Tasmania
Re: clutch Fri, 24 May 2002 15:15 Go to previous message
Got the clutch out. It looked ok. Still don't know the exact problem, but it was in the clutch somewhere.
I got a new clutch kit anyway, a RPM Performance clutch, (painted yellow) for $140. ($301 retail). I put that in and everything is fine. The pedal is lighter, and the clutch grabs a bit harder.
Previous Topic:Bellhousing for W57 to 4A-GZE block
Next Topic:imports- where do u get the OK list?
Current Time: Mon Nov 2 09:12:21 UTC 2026
Total time taken to generate the page: 0.0041079521179199 seconds
