Toymods » Tech & Conversions » more poke 3k
rehau
more poke 3k Tue, 27 July 2004 11:24 Go to next message
i was woundering how i can get more poke out of a 3k cheaply, when i went for a fang, 1st is fine, 2nd is fine, but as soon as i put it into 3rd it dies, this is going up hill btw, is there anyway to get more response out of the ol' 3k?
Re: more poke 3k Tue, 27 July 2004 12:28 Go to previous messageGo to next message
1. It's small.
2. It's old.
3. It's small.
Getting more poke out of it is easy enough, but it involves modifying the 3K into something bigger. A 5K for example will be a decent improvement, and doesn't have to be expensive. It will still be slow, but slightly less so. Razz
Re: more poke 3k Tue, 27 July 2004 12:57 Go to previous messageGo to next message
whilst Norbie is right, you can do a few things....
cam, compression, exhaust, porting, carb, EFI etc all spring to mind... in fact, exactly the same as you do to any motor you want to get more power from.
4K or 5K block could help, but for my budget dollar, 4K block with 3K head, mild cam, a bit of porting and a 1.75" exhaust will do well..
for a bit more poke, 4K block, 3K head, ported well, 235@50thou cam, 430-450thou lift, dual valve springs and machined rocker towers, tuned extractors, 2" exhaust.
thats about as far as you'd want to go in a street motor.
for race spec, google for TOSCO manual for the 3K.
rehau
Re: more poke 3k Wed, 28 July 2004 01:33 Go to previous messageGo to next message
Thanks oldcorollas.
i know what your saying is a good idea, but that thing is i would like to work with the excisting 3k i got in there, 4k was the plan later down the track, but my funds are low, and the garage space doesnt excist, would a 2k head increase my compression by much, what carb would you best recommend, i do have a 2lt escort webber one (downdraught), with spacer plate, do i need to re-jet it, and would the original inlet manifold be restrictive for the webber application?, also, what cam would be good for a 4k, and would i need to get new valve springs?.
p.s, anyone want to donate me a 2k head?
V8_MA61
Re: more poke 3k Wed, 28 July 2004 01:35 Go to previous messageGo to next message
save your money for something better than a k series motor..eg a 3tgte Smile
Re: more poke 3k Wed, 28 July 2004 02:55 Go to previous messageGo to next message
it's fun to play with the K motors, but if yu are after "performance" they will never be "quick".. but they do give a race car feel Wink..
do 3TG's rev to 8 grand?
anyway, if the 3K you have has good rings and pistons, then maybe have a play with it.. the reason for 4K block with 3K head is instant 10:1 CR.
2K is a 1L motor, K is 1100. K's came out in KE10's. some K heads are bigports also.
2K head woiuld give you around 11:1Cr, but there are not many 2K's floating around.
carb depends on the cam and the rest of the setup. no point having a big carb if you have a bad exhaust or a stock cam.
the escort 32/36 with 26/27 chokes is not good. the primary chke is too large.. look for a euro webber from maybe Fiat, with 22-23mm primary choke.
yes you will need to rejet any carb.
i have a straight runner K manifold and it still makes abut 100HP. but they are restrictive.
what cam? what do you want it for? i like high lift cams, but over a certain lift, the stock springs will bind. about 430thou lift will maybe bind. i have 435, but wuld like to go up to 450thou lift soon.
you need to design the engine as a package.
rehau
Re: more poke 3k Wed, 28 July 2004 03:03 Go to previous messageGo to next message
thanks for the info, all i need now, is space to do it in, and some cash, how can i tell if my rings are in good condition, it blows smoke when its cold, but i think thats because the choke is on, when its warmed up, it doesnt blow much or not at all any smoke, but i dont know seeming with the cold weather, if its smoke or condensation, it aint black smoke, and it doesnt burn oil, just leaks it..a bit Very Happy, i just went for a drive before, and dunno what it is, but its shi*#ing me off at the moment, when i come up to an intersection red light, i put it in neutral, and just roll to the intersection braking, and as soon as i start braking, it fn stalls, even when im at a normal intersection just sitting there it stalls, and the car is warm, even with choke on it doesnt like to idel.
Purple_Beasty
New Zealand
Re: more poke 3k Wed, 28 July 2004 11:21 Go to previous messageGo to next message
You DO NOT want a 2K head, the ports (and apparently valves) are smaller than the 3K and would take you a lot of work to get back a decent flow level.
Having said that if you still want one I have a fully recond one still wrapped in plastic......buts its in NZ.
Callum
Super Jamie
On Probation
North East NSW
Re: more poke 3k Thu, 29 July 2004 09:31 Go to previous messageGo to next message
blah blah blah
replace it with a 4k, put a 25/65 cam in, get decent headwork done and bigger valves if you can afford it. it will work with the stock carb but will work alot better with anything up to about a 32/36 weber
if you want any more than that, spend the money putting a 4ag or rotary in
arkon
September 2005
Re: more poke 3k Sat, 24 September 2005 07:37 Go to previous messageGo to next message
wat kind of increase will this give u , 90hp atfw? roughly speakin of course cause ye ol 4k's have bout 70hp atfw
tom210
Launceston
March 2005
Re: more poke 3k Sat, 24 September 2005 08:09 Go to previous messageGo to next message
arkon wrote on Sat, 24 September 2005 17:37
atfw = At the front wheels
atrw = " " Rear "
sorry put im picky
Super Jamie
On Probation
North East NSW
Re: more poke 3k Sat, 24 September 2005 08:43 Go to previous messageGo to next message
you'd need forced induction to get that. even the best ported, custom cam, big piston rally K engines are only making 80hp at the wheels
k heads just don't flow that much
Re: more poke 3k Sat, 24 September 2005 11:31 Go to previous messageGo to next message
tom210 wrote on Sat, 24 September 2005 18:09
atrw = " " Rear "
sorry put im picky
At The FlyWheel
Razz
arkon
September 2005
Re: more poke 3k Sat, 24 September 2005 12:46 Go to previous message
cheers oldcorllas , yeh i was talking bout the flywheel , ive got a 4k with gearbox sitting here but a 3k in the ke30 , hmm wat to do , cuz i am not exactly a mechaninc or too mechanically minded but if its easy to do im up 4 it, 4k with 3k head ?
Previous Topic:brake booster not working...
Next Topic:7MGTE weird cut out under boost/load?? ---SOLVED!!!!
Current Time: Fri Oct 30 03:45:57 UTC 2026
Total time taken to generate the page: 0.0081310272216797 seconds
