Toymods » Tech & Conversions » KE55 4K
scano
KE55 4K Tue, 27 July 2004 11:30 Go to next message
Hey everyone, just bought my first Toyota KE55 with a 4K donk in it, im new to this site, my mate told me to come here, just after some information on working my 4K, i had a look at some searchs but i need a bit more information, im thinking of the 3K head, 4K block, extractors, exhaust2"?? lumpy cam and carby?? any ideas on what good mods are for these sluggy little 1300cc? any help would be greatly apprieciated. thanks
Jonny2TG
Tasmania
Re: KE55 4K Tue, 27 July 2004 11:55 Go to previous messageGo to next message
You will NEED a bigger carby. And a different cam is cheap performance. Also, try and lighten the flywheel a bit. Also, get new valve springs. Old ones can let the engine valve bounce bad, and effectively reduce your rpm by heaps. I recomend electronic ignition of some sort. If you run points, make sure they are new and change them at least every 3 months.
I will let others tell you of specific head/piston combo to use to get the compression you want. All the different generation pistons are different. Welsh plug 3K head will have the biggest valves, and give good compression on a 4K.
Re: KE55 4K Tue, 27 July 2004 12:57 Go to previous message
cam, compression, exhaust, porting, carb, EFI etc all spring to mind... in fact, exactly the same as you do to any motor you want to get more power from.
4K or 5K block could help, but for my budget dollar, 4K block with 3K head, mild cam, a bit of porting and a 1.75" exhaust will do well..
for a bit more poke, 4K block, 3K head, ported well, 235@50thou cam, 430-450thou lift, dual valve springs and machined rocker towers, tuned extractors, 2" exhaust.
thats about as far as you'd want to go in a street motor.
for race spec, google for TOSCO manual for the 3K.
Previous Topic:what clutch do i need :?
Next Topic:AE86 Digi-Dash wiring diagram
Current Time: Sun Oct 18 22:57:35 UTC 2026
Total time taken to generate the page: 0.0048820972442627 seconds
