Toymods » Tech & Conversions » For those of you with MAP 4agze
GZETrueno
icon5.gif  For those of you with MAP 4agze Tue, 27 July 2004 20:02 Go to next message
My car runs! I even drove it to the nearest gas station to fill it up. It hesitates at various rpm's and dies often but I have found out why. It is running soley off of the battery so I have to jump-start it almost every time. I'm hoping the alternator isn't dead but I'll check. The confusing part is, and this should sound right if you have a MAP 4agze, the alternator harness is part of the body harness on the AE86 but the MAP 4agze has it as part of the engine harness which is the one I am using now, the original ae86 alt plug is just tucked away. Do I have to splice them together for it to work?
Re: For those of you with MAP 4agze Tue, 27 July 2004 23:43 Go to previous message
you need to connect the altenator most definitely! Think about it dude, its quite easy.
Basically for your alternator to charge it needs the following:
# to be spinning
# Output connected to battery (this is the bolt-down terminal)
# Voltage Sensor wire (on 3 pin plug) connected to batt
# Ignition (3 pin plug) connected to .. you guessed it
# Warning light (in same 3 pin plug) connected to charge light.
That is all.
Previous Topic:1974 TA22 auto tailshaft fits t50 box: T/F ?
Next Topic:Maximum guards liped on an 86
Current Time: Sun Oct 18 21:02:30 UTC 2026
Total time taken to generate the page: 0.0076680183410645 seconds
