Toymods » Tech & Conversions » W50 gearbox fits 1jz
bender
W50 gearbox fits 1jz Wed, 28 July 2004 04:17 Go to next message
First question is that i have a 84 model 2.4l celica which i want to know wheather or not its a W50 and i plan to do a 1JZ conversion and i have been told that it bolts straight in is that true? and if so with a performance cluch and flywheel will my celica 5 speed be able to take a 300hp 1jz
joecoolmk2
Re: W50 gearbox fits 1jz Wed, 28 July 2004 04:23 Go to previous messageGo to next message
i'm not positive, but the gearbox in you celica is a w58. guy on here has a 2jz with a w58, and he broke it several times. the box you need is an r154, but there expensive. good luck, your gonna need it. oh, i'm pretty sure the r154 won't fit in the tranny tunnel without massaging the tunnel first! there chunky!!! Very Happy
Re: W50 gearbox fits 1jz Wed, 28 July 2004 04:29 Go to previous messageGo to next message
A W58 will be just fine behind a 1JZ if you treat it nice. I'm the guy who broke "several" W58's behind a 2JZ, (actually was just one, the other one was a W57), but a 2JZ has a lot more torque than a 1JZ and I was far from nice with it!
The W58 will bolt up to a 1JZ but you need a JZ bellhousing first, which unfortunately aren't that easy to find. Keep an eye on the forsale section, or if you get desperate you can buy them new from Toyota (ask BlackSupra about this, he bought a new one).
joecoolmk2
Re: W50 gearbox fits 1jz Wed, 28 July 2004 05:56 Go to previous messageGo to next message
i didn't say you broke several of them, i said you broke it several times, but as you said, one was a w57. was i right? does his celica have a w58? or is it a w57? have a look on your vehicle id plates and tell us what it says next to trans/axle please.
Re: W50 gearbox fits 1jz Wed, 28 July 2004 06:31 Go to previous messageGo to next message
I broke a W58 and a W57, once each.
bender
Re: W50 gearbox fits 1jz Thu, 29 July 2004 03:51 Go to previous messageGo to next message
thanks for that guys but does anyone know if my gearbox bolt on to a 1J has anyone done it?
Re: W50 gearbox fits 1jz Thu, 29 July 2004 03:57 Go to previous messageGo to next message
Your question has already been answered, but since your comprehension skills are apparently sub-par, I'll re-iterate for you.
1. The transmission in your Celica is a W57/58, NOT a W50.
2. W58 transmissions were installed behind JZ engines from the factory (non-turbo versions that is).
3. You will need a JZ -> W58 bellhousing to make this work.
4. Lots of people have done this before, which you would know already if you'd done some research.
wilbo666
Re: W50 gearbox fits 1jz Thu, 29 July 2004 04:18 Go to previous messageGo to next message
Norbie wrote on Thu, 29 July 2004 13:57
or we could hold his hand? Confused
KOFFEE-BLACK
Re: W50 gearbox fits 1jz Thu, 29 July 2004 05:04 Go to previous messageGo to next message
Is it true, that JZA80 W58's bolt straight up to 1JZ?
ChuckLandwehr
Re: W50 gearbox fits 1jz Thu, 29 July 2004 08:26 Go to previous messageGo to next message
King of Zamunda, Yes, it will "bolt up", but will it fit the recipient vehicle? Time for a tape measure, a scrap of paper and writing implement.
Markings on bell housing, " xJ - W5x ". Which really means, any "J" series engine to W55/W57/W58.
regards Chuck.
Fattony
Re: W50 gearbox fits 1jz Fri, 30 July 2004 07:58 Go to previous messageGo to next message
bender, just by some chance that your car does have a W50 in it, which i would not know how, you would not want to run it on a 1jz, you would prob most likely blow the box reversing out the driveway. Check your vehicle id tag, look under the
trans/axel: section and it should tell you what box you have W5x.
slylux
perth WA
    nup
Re: W50 gearbox fits 1jz Sat, 31 July 2004 01:08 Go to previous message
i will be selling my r154 box,flywheel and brand new clutch all to suit 1jz .. $2k
thats the going rate
Previous Topic:How strong is a 1JZ GTE
Next Topic:Motor running like crap
Current Time: Thu Nov 19 03:46:59 UTC 2026
Total time taken to generate the page: 0.0067989826202393 seconds
