Toymods » Tech & Conversions » 4K fuelling....
HyDrA
Adelaide, SA
4K fuelling.... Thu, 29 July 2004 03:40 Go to next message
Hi all,
I've narrowed the problem with our KE70 losing all power to the fuel delivery... It's getting spark, and definetly getting air Razz
Is there any way I can narrow it down more, as in, narrow it down to which pump is causing the issues? I suspect it's the mechanical fuel pump on the block itself causing the problem, it is 20 years old!
Before I spend any money on a new pump / pump from a wrecker, is there anything else I should check?
Also, while i'm at a wrecker, is there anything else I should grab? It's a 4K-C so it has crappy emmisions systems all over the place. I might grab myself a 3k head if the price is right. The engine is due for a rebuild Smile
Purple_Beasty
New Zealand
Re: 4K fuelling.... Thu, 29 July 2004 05:21 Go to previous messageGo to next message
Sit a tin of fuel in the engine bay and run the pump from that. It will eliminate a blockage in your tank as an issue.
Callum
HyDrA
Adelaide, SA
Re: 4K fuelling.... Thu, 29 July 2004 06:10 Go to previous messageGo to next message
Thats a good idea...
But the only problem is it happens after some amount of time, like 1 hour of driving... it cuts in and out a bit, then totally dies (tacho still reading RPM though).
It's as if it's starved of fuel, and bubbles are getting in....
Super Jamie
On Probation
North East NSW
Re: 4K fuelling.... Thu, 29 July 2004 09:29 Go to previous messageGo to next message
perhaps your float levels are set incorrectly. gregories manual tells you how to set the carby up properly. could be a clogged line, clogged fuel filter, or yes the mech pump wearing out. thats the only pump on the whole car except the oil pump. rebuild kits for the fuel pumps are usually 90 bucks. pumps can be had for 20-30 at the wreckers
Purple_Beasty
New Zealand
Re: 4K fuelling.... Thu, 29 July 2004 09:43 Go to previous messageGo to next message
Hmmm, maybe your tank vent is blocked and after too long driving is creating a vacuum. Try removing the seal from the cap or use one of those plastic emergency caps that never seal properly. See what that does for the problem.
Callum
HyDrA
Adelaide, SA
Re: 4K fuelling.... Thu, 29 July 2004 09:56 Go to previous messageGo to next message
Hmmm....
So there isnt a fuel tank pump?
I've not really worried about the fuel side of this car yet... not until now! Plus this is the only carby car i've owned, and up until recently i've not bothered to take care of it Razz
I'll try those suggestions this weekend, should keep me busy!
Thanks guys!
Super Jamie
On Probation
North East NSW
Re: 4K fuelling.... Thu, 29 July 2004 12:42 Go to previous message
no
Previous Topic:MA61 DBA rotors and pads????
Next Topic:Light plastic cleaner
Current Time: Fri Oct 23 22:40:51 UTC 2026
Total time taken to generate the page: 0.0056679248809814 seconds
