Toymods » Tech & Conversions » Brake Booster for KE10 disc concersion
Fatterthanyamumma
ADELAIDE
icon10.gif  Brake Booster for KE10 disc concersion Thu, 29 July 2004 05:24 Go to next message
Does anyone know of the part Number for the Brake booster needed for this conversion? I understand it's something along the lines of VH-44 or there abouts?
cheers.
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 05:37 Go to previous messageGo to next message
yup, sounds like the right number.. there is another (i think VH40)
what brakes are you converting to? i find that there is no need for a booster with KE70 brakes.
pro_ke
adelaide
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 05:44 Go to previous messageGo to next message
vh44 is the remote brake booster
will make your brakes feel bad so i would avoid unless you need one for engineering
Fatterthanyamumma
ADELAIDE
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 06:15 Go to previous messageGo to next message
Old Corollas >>> Cool. I thought I wasn't far off. I read it somewhere, but couldn't relocate where I read it!
I'm coverting to KE30, so I can stay with the same stud pattern to reatain my small stockies with whitewalls and hubbies.
__________________________________________________ _____________
Pro Ke >>> ok. The car will not be getting any engineering attention. But, I would like to know your understanding and thoughts on the part VH40, if it exists and if it's a different addition.
Cheers again.
pro_ke
adelaide
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 07:09 Go to previous messageGo to next message
remember to keep ke20 hubs - if you use ke30 ones you will have the 114.3 stud pattern
you also wont be able to fit your 12s over the ke30 brakes, i have tried and failed!
adding a brake booster will make the brakes fill like they need a good bleed... it will feel springy rather than firm
whereabouts in adelaide are you? got a pic of your ke10?
Fatterthanyamumma
ADELAIDE
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 07:37 Go to previous messageGo to next message
Ok. Basically I am running from the article on this site:
http://www.materials.unsw.edu.au/~sford/dtod.html
So, understandably there is no mention of fitting 12s on the car in the article. That's fine, but I'm glad you pointed it out! I can see where you are coming from with the disc size increased for sure. This just arms me with a reason to upgrade to 14s with the bigger hubbies and fresh whitewalls! sweet.
I reckon I might just do the conversion and see what happens with regard to the pedal feel. That way I'll have a feel for it, then I can make the decision to add the booster or not. Sweet again.
Hey, cheers for your advice on this, muchly appreciated.
I will post a pic tomorrow here for you, as I'm about to head home from work. I just bought the car a week ago from a mate, that decided to trade it in for a WRX... I know, what was he thinking!!! lol.
pro_ke
adelaide
Re: Brake Booster for KE10 disc concersion Thu, 29 July 2004 23:36 Go to previous messageGo to next message
what 14s are you going to use? ive been down that road on a ke10 and it is a very expensive task - the only 14" steel rims in 4x110 are r100 rims... usually about $200 each) and toytoa 14" hubcaps are a nightmare to fit on them...
Fatterthanyamumma
ADELAIDE
Re: Brake Booster for KE10 disc concersion Fri, 30 July 2004 00:42 Go to previous messageGo to next message
Not sure what 14's.. I was thinking it shouldn't be too hard to source some, but what you're saying sounds like I'm gonna run circles trying to find some... Then I guess being a small car with small guard clearance I'd run into an off set issue.. cos she's pretty damn slammed (and will be staying like that regardless!)
Perhaps 13's - would be the easiest option? Hmmm.. I'm just like everyone else - wanting bigger and better!
IS THERE AN EASY ANSWER? - for me with regard to my brake upgrade and keeping stockies with hubbies???... surely?
.eomiT
Re: Brake Booster for KE10 disc concersion Fri, 30 July 2004 01:15 Go to previous messageGo to next message
the KE20 discs will fit under 12".
the KE30/70 discs fit under 13"
if you want to keep the "fully sik grandma, slammed with stockies look" you're just gonna have to work it out for yourself Wink
[Updated on: Fri, 30 July 2004 01:18]
pro_ke
adelaide
Re: Brake Booster for KE10 disc concersion Fri, 30 July 2004 02:28 Go to previous messageGo to next message
mazda 13s with some other hubcaps like celica or something would fit...
augo
Melb
January 2005
Re: Brake Booster for KE10 disc concersion Tue, 22 March 2005 09:02 Go to previous messageGo to next message
If the mazda stud pattern works go a 626 wheel 14 inch
or if ya really keen saab interceptors 15 inch.
Fatterthanyamumma
ADELAIDE
Re: Brake Booster for KE10 disc concersion Tue, 22 March 2005 22:33 Go to previous message
I have found Mazda B1600 wheels (front only) to be the go, being 15".
Previous Topic:Corona MKII Engine conversion. . . . .
Next Topic:Super 5 stud conversion...
Current Time: Thu Nov 19 22:28:31 UTC 2026
Total time taken to generate the page: 0.0072379112243652 seconds
