Toymods » Tech & Conversions » Sw20 Power Steering Question
Luv_Psi
Sw20 Power Steering Question Thu, 29 July 2004 06:01 Go to next message
Hey
Ive got a 1990 sw20 mr2, and every now and then the power steering just cuts out, went to check the fluid and its full.
i was told something about a wire that overheats and thats what cuts it out????
ne one got ne ideas or know how i can fix this problem.
Let me know
Doctakay
Branxton
Re: Sw20 Power Steering Question Thu, 29 July 2004 07:27 Go to previous messageGo to next message
I hope it's not your pump because those electronic steering pumps are quite expensive (around $800 from toyota)
Take note of when and how it cuts, try and chase any loose terminals it may be cutting out possibly because of a loose terminal not grounding when going around a corner or something... basically all i can say is check all terminals for good clean contact, check any fuses and then consult a a guru from toyota if that doesn't sort it out.
Hope you get it all sorted.
Luv_Psi
Re: Sw20 Power Steering Question Thu, 29 July 2004 08:06 Go to previous message
hrmmmmmm im not sure, what the problem is!!!!!
it only happens occasionaly, when i turn or soemthing, and it has happened once or twice when jus driving str8. Confused
i'll get it checked out asap.
thanks for the advice
Previous Topic:ae86 headlights
Next Topic:ms65 grille on a ms85?
Current Time: Wed Oct 21 10:54:39 UTC 2026
Total time taken to generate the page: 0.0064001083374023 seconds
