Toymods » Tech & Conversions » KE35 fuel tank leak
crispy
Christchurch , New Zealand
KE35 fuel tank leak Thu, 29 July 2004 08:06 Go to next message
Hopefully you guys can point me in the right direction,,, 2tgeu is in my sr, it's e.f.i. and i'm running the original tank. Lately i have noticed it's leaking from around the gauge sender unit so i have a couple of ideas.. 1:seal around the area with knead it or similar fuel rsistant sealer and hope it doesn't leak again or 2:replace it with a surge tank or another tank that fits in the space. I don't want to change tanks as i want it to remain as orig as possible inside. Could i relieve the excess pressure in any way??? Thanks in advance
Super Jamie
On Probation
North East NSW
Re: KE35 fuel tank leak Thu, 29 July 2004 09:27 Go to previous messageGo to next message
get another tank and sender from the wreckers?
crispy
Re: KE35 fuel tank leak Fri, 30 July 2004 06:55 Go to previous messageGo to next message
The thing is isn't this going to be under pressure being e.f.i. and 2tg or any injected engine runs fuel pressure constantly until you relieve it by disconnecting the fuel pump. Pretty much the fuel system is under pressure so that's why i think i have a leak.
pro_ke
adelaide
Re: KE35 fuel tank leak Fri, 30 July 2004 07:04 Go to previous messageGo to next message
the tank should certainly not be under pressure if you have set things up right
make sure the tank is vented correctly (look in a parts book/workshop manual to see how it is supposed to be done)
new tank from wreckers should be cheap
crispy
Re: KE35 fuel tank leak Sat, 28 August 2004 06:00 Go to previous message
Hey all, i have sorted out my problem with my tank leak. I had removed the gauge sender unit for some reason when the 2tg was going in and had put it in the wring way. had it in at work to do some things and removed the unit from the tank, looked at the unit. Now those that know the fuel gauge sender unit has a cutout in it, the tank has a prevision. I used a mirror and lined up the 2 marks put the gauge unit back in and now no more leaks and my fuel gauge (ke35) works with my te71 dash which i put in, full te71 loom, the only sr parts in the electrical side of things are the gauge unit, door switches and interior light. Not sure if it's accurate as i didn't have a full tank of fuel when i noticed the dash working
Previous Topic:88 corolla audio wire codes?
Next Topic:little help locating my fuel filter for st162
Current Time: Fri Nov 20 04:41:56 UTC 2026
Total time taken to generate the page: 0.0046200752258301 seconds
