Toymods » Tech & Conversions » Dismantling Turbo (TD04)
HighRolla
Dismantling Turbo (TD04) Thu, 29 July 2004 10:47 Go to next message
Just trying to pull apart my td04 to rotate the housings. I'm starting with the exhaust side. Having a try at prying apart. Took the clamp off put screwdriver between exhaust housing and bashing end of screwdriver with hammer but won't budge. Any ideas.. bash harder maybe Surprised
http://img56.exs.cx/img56/102/IMG_0026.jpg
http://img56.exs.cx/img56/1503/IMG_0029.jpg
PS1: I have disconneted the wastegate actuator
PS2: started new thread so less pictures open.
[Updated on: Thu, 29 July 2004 10:59]
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 11:44 Go to previous messageGo to next message
have you got access to an oxy torch? you'll need a large amount of heat or force to seperate them
TE72_Turbo
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 11:50 Go to previous messageGo to next message
Soak the turbo in a bucket of diesel for a day or more to penetrate the corrosion in the join, that's whats stopping you from separating the exhaust housing from the core. Rather than using the end of a screwdriver, use the blade of a knife, as it has a nice sharp edge & gradual taper (think hunting style knife Smile ). Work you way at different points around the join to edge them apart gradually. Before you put it back together, remove all the corrosion with emery paper (or even better, a wire wheel on a grinder) and apply some high temp anti-sieze compound to the joining surfaces to save yourself the pain next time it has to come apart.
Phil
HighRolla
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 11:52 Go to previous messageGo to next message
hmmm. No oxy, got a few gas (butane) torches that might do the trick. Should I heat the exhaust housing more or just at the join. Didn't think it would be this damn hard.
Thanks Simon
HighRolla
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 11:54 Go to previous messageGo to next message
Phil. Does the diesel hurt anything else, seals, wheels or anything..Why diesel instead of petrol?
Thanks for the ideas. Smile
TE72_Turbo
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 11:59 Go to previous messageGo to next message
Diesel wont hurt anything. Its not necessary to immerse the complete turbo though, just sit it in the bucket with the compressor facing up, and just enough diesel to soak the exhaust housing & core. Diesel penetrates much better than petrol.
A butane torch is unlikely to get enough heat into the join to break the corrosion, there's a lot of cast metal to absorb the heat. I dont think you'll need an oxy to heat it though (instead of soaking in diesel), but it should work if you decide to go that way.
HighRolla
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 12:09 Go to previous messageGo to next message
I have some really good penetrating oil also. Could I spray around the joint with that first before the diesel. That isn't likely to hurt anything is it?
Thanks for the help Phil, and Simon
TE72_Turbo
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 12:15 Go to previous messageGo to next message
Any penetrating agents designed to loosen corroded parts cant be a bad thing. I'd give it a go, then leave it in the diesel for at least a day.
Be patient, they are a pain in the ass (toyota turbos are the same) but you will get there Cool Just don't tilt the housing too much in relation to the core as you remove it, cause the exhaust wheel will bind against the housing & you will damage it if you force it further.
Phil
HighRolla
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 12:24 Go to previous messageGo to next message
Cool. I just gave it a soak with the penetrating oil..see how good this crap really is. Failing that - onto the diesel..
Thanks for the words of warning also. Smile
Johnny Blade
Sweden
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 20:42 Go to previous messageGo to next message
Put the clamp back but dont tighten it, then give it a hit with a plastic sledgehammer.
If you give it a hit without the clamp you can break the turbin.
HighRolla
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 22:47 Go to previous messageGo to next message
So what do you hit with tth plastic sledge..the exhaust housing itself? What does the clamp do there..do you mean just to stop it separating to quickly, then damaging the turbine due to it coming off crooked.
Ben Wilson
Re: Dismantling Turbo (TD04) Thu, 29 July 2004 22:56 Go to previous messageGo to next message
Looking at your pictures, there's no need to mark it before you pull it apart, there is a locating pin in there which you'll need to cut off.
Johnny Blade
Sweden
Re: Dismantling Turbo (TD04) Fri, 30 July 2004 11:14 Go to previous messageGo to next message
Exactly!
HighRolla
Re: Dismantling Turbo (TD04) Fri, 30 July 2004 14:20 Go to previous message
Thanks for the help lads.
Got her off.
Here's how:
1. Sprayed penetrating oil in between (as much as could get in)
2. Left for 24 hours
3. Used a slightly more tapered flat screwdriver (thanks Phil "hunting knife"), could eventually get that wedged in there using hammer on the back. Left that wedged in, wedged in another screwdriver, removing the previous and working around.
http://www.miamihost.net/ims/u/benl1981/car/30lowqual.JPG
Tools used, it's a small little locating pin hey(if you can call it that)
http://www.miamihost.net/ims/u/benl1981/car/32lowqual.JPG
Sorry pretty unexciting pics..
[Updated on: Fri, 30 July 2004 14:22]
Previous Topic:repair manual
Next Topic:Toyota Stud Patterns
Current Time: Fri Oct 23 01:06:06 UTC 2026
Total time taken to generate the page: 0.0056400299072266 seconds
