Toymods » Tech & Conversions » ae86 lsd fit into ta22 t series diff?
ta22celica_boy
ae86 lsd fit into ta22 t series diff? Fri, 30 July 2004 00:11 Go to next message
yeah as the title says just wanted to know if they fit into ta22 diff, as im pretty sure they are the same series diff, or do they have different spline axles, etc.
cheers for any info josh v
Bugman
Re: ae86 lsd fit into ta22 t series diff? Fri, 30 July 2004 01:17 Go to previous messageGo to next message
aslong as it is a tseries you can use the center but i think i recall some ae86s coming with S series diffs. so make sure it is a t series
Henn
Rosanna, Melb
Re: ae86 lsd fit into ta22 t series diff? Fri, 30 July 2004 01:45 Go to previous messageGo to next message
I'm not 100% sure on this exact swap, but I am sure it has been covered before:
TA22 diff centre is the same as a T18 diff centre.
AE86 T-series LSDs will fit a T18 housing.
If the centre is small axle (can't remember if that's zenki or kouki) then the T18 axle splines will fit.
Only thing that spring to mind is that TA22 and T18 may have different track, but that is easily discovered with a ruler or some searching. Good luck
Hen
And dont worry about the whole S-series vs T-series. Yes, oz-spec sprinters had S-series diffs, but no LSD was ever made for S-series.
PerformanceCars
Re: ae86 lsd fit into ta22 t series diff? Fri, 30 July 2004 03:53 Go to previous message
Zenkie Lsd's are the one that fit the T18 housing..
Cool
Previous Topic:New Guages
Next Topic:Static timing on 4AGE
Current Time: Sun Oct 25 19:01:52 UTC 2026
Total time taken to generate the page: 0.067800045013428 seconds
