Toymods » Tech & Conversions » 4K-E wiring
Toycrash
Finland
4K-E wiring Fri, 30 July 2004 10:57 Go to next message
Hiya!
Anybody got a complete 4K-E wiringdiagram?
or ECU pinouts for lambda version..
Pasi
Re: 4K-E wiring Fri, 30 July 2004 14:55 Go to previous messageGo to next message
Heya Pasi,
i ordered some manuals form the US in the hope of getting one but no luck so far..
the Chiltons manual didn't even have electrical diagrams or 4KE info..
the Clymer (A194) manual for 'toyota corolla 1968-1983' manual has 4KE info, but only had a diagram taped in the back for a 1979 corolla. i think if you could get one with a diagram for a 1983 car, might be ok?
these two were about US$10 incl postage.
i'll see if i can find links to them
Toycrash
Finland
Re: 4K-E wiring Fri, 30 July 2004 15:36 Go to previous messageGo to next message
OK. just opened the ECU and pinouts were labeled into the board.
so now i know something..
can someone give me a UK,US,DE or some country toyota info mail, that this engine type has been imported?
in here they dont seem to know anything only from has been imported.
it's unbelievably hard to find anything relating 4K-E Sad
Pasi
[Updated on: Fri, 30 July 2004 15:51]
Re: 4K-E wiring Fri, 30 July 2004 15:49 Go to previous messageGo to next message
it never made it to australia, but in the US and canada, the 4K-E came out in starlets, i believe from 1980-1983. mine came from a 1983 starlet.
newzealand has also had some of them, but they tend to get a lot of japan imports.
i imagine it was also available in japan, but never in Aus Sad
i am not sure about corolla models tho?
Toycrash
Finland
Re: 4K-E wiring Fri, 30 July 2004 15:59 Go to previous messageGo to next message
Do you have original wiring loom or only pieces?
and how about air temp sensor?
There don't seem to be any connector where sensor could go..
also i have some emission control relay in my sniped wiring loom. at least two afm wires go through it.
Toycrash
Finland
Re: 4K-E wiring Sun, 01 August 2004 08:52 Go to previous messageGo to next message
It seems that 4K-EU wiring in something between 2T-GEU and 4A-GE..
I have solved injector, TPS, fuel pump,AFM, Temp and cold start injector wirings by reading both 2T and 4A wirings.. And trying to go pass those stupid emission wirings.
Some day it will start... Wink
http://www.koti.phnet.fi/crash/KE20/johtohelvetti. jpg
[Updated on: Sun, 29 August 2004 10:50]
Re: 4K-E wiring Sun, 01 August 2004 08:58 Go to previous messageGo to next message
Hi Pasi,
i didn't get any diagrams with my setup, but i was led to believe that the ECU was similar or same as the early 2TG ECU's (with AFM).
on the 1979 corolla wiring diagram i have, it shows an 'emission computer' but no EFI.. i could scan that part of the diagram for you if you like?
good luck!
Toycrash
Finland
Re: 4K-E wiring Sun, 01 August 2004 09:34 Go to previous messageGo to next message
It surer is not same as the 2T-GEU ecu according to this wiring diagram i have for it..
no speed sensor, no oxygen sensor, different ballast resistor wiring, etc. and i dont think 2T-GEU had fault memory or emission control inside ECU Wink
4K has test socket and "check engine" lamp.. let's see how it flashes.
Purple_Beasty
New Zealand
Re: 4K-E wiring Sun, 01 August 2004 10:35 Go to previous messageGo to next message
Try http://forums.toyspeed.org.nz/index.php. They may be able to help out with the 4KE diagrams. We got them here in Jap import Starlets.
Callum
Jayem
Finland
Re: 4K-E wiring Sun, 01 August 2004 11:22 Go to previous messageGo to next message
Pasi ookko nää kokeillu ToyotaInfoo, siis sitä puhelin numeroo. Tuntuvat tietävän siellä aika paljon. Kaveri sai 2E-TE:n kytkikset jotka oli kans aika kiven alla.
Jayem
Finland
Re: 4K-E wiring Sun, 01 August 2004 11:25 Go to previous messageGo to next message
Tiukka tuo aja ihmisiksi tarra! Laughing
Toycrash
Finland
Re: 4K-E wiring Sun, 01 August 2004 13:27 Go to previous messageGo to next message
melko turha koko toyotainfo, vanhempien kanssa. etenkin jos ei ole koskaan tuotu maahan kyseista moottoria.. ja tuolla toisessa postauskessa jo yritin asiaa selventaakkin Wink
sorry about this finnish part.. nothing new to translate ;D
cambelt
melb
Re: 4K-E wiring Mon, 02 August 2004 09:35 Go to previous messageGo to next message
2se and 22re is similler in efi diagram,
cambelt
Toycrash
Finland
Re: 4K-E wiring Tue, 03 August 2004 05:16 Go to previous messageGo to next message
ECU pinouts are similar, wiring is NOT...
Medicine_Man
Brisbane, QLD
Re: 4K-E wiring Tue, 03 August 2004 06:43 Go to previous messageGo to next message
Reply might be a little late, but useful for reference at a later date..
http://www.geocities.com/MotorCity/Pit/9975/enginepix/drawings/ToyEFI_Pins_4K-E.gif
Toycrash
Finland
Re: 4K-E wiring Tue, 03 August 2004 07:06 Go to previous messageGo to next message
Thanks but i have that allready.. Wink
wiring diagram still needed(for reference)
harness done let's keep fingers crossed
Toycrash
Finland
Re: 4K-E wiring Wed, 04 August 2004 17:30 Go to previous messageGo to next message
Thanks ppl. today after work i finaly got courage to start the engine for first time. IT RUNS Smile Still open headers and no radiator etc. but idle is smooth as babys ass... i'm loving it Wink
Toycrash
Finland
Re: 4K-E wiring Tue, 24 August 2004 16:37 Go to previous message
Couple a weeks as an daily driver again and running like little angel Smile
It was something between 4a-ge and le-jetronic.. i used about 5 different wiring diagrams to solve the wiring disaster, but it worked nicely Smile
I needs still some work, but now it looks like this:
edit:no images? http://www.koti.phnet.fi/crash/KE20/ke20_engbay4ke .jpg
[Updated on: Tue, 24 August 2004 16:38]
Previous Topic:Plug Lead Question
Next Topic:4AFE With Coil Packs
Current Time: Sat Nov 21 18:55:24 UTC 2026
Total time taken to generate the page: 0.08617091178894 seconds
