Toymods » Tech & Conversions » URGENT HELP! stripped bolt
naten
campbelltown
URGENT HELP! stripped bolt Fri, 13 September 2002 08:21 Go to next message
Hey,
i have a 1980 celica (ra40) i have to replace the gearbox mount on the gear box crossmember. The problem is that two of the bolts were rooted when i got the car. By rooted i mean there is not much of a head left on them. I cant use a spanner or a socket cuz they just slip around due to the lack of head.
my last resort is i have a set of easy outs, but i dont like using these things.
can anyone suggest something different as i need the car for work tomorrow morning. (btw keep in mind this is still on the car)
nathan
GIN51E
Berowra-Sydney
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 08:32 Go to previous messageGo to next message
get a pair of vice grips an if the bolts to tight heat it up with an oxy then use the vice grips Very Happy
Corvid
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 08:58 Go to previous messageGo to next message
My experience with this problem (ive had it lots) Smile
Is to be patient.. Get a couple of small files and get to work on each edge of the bolt.. Get the next size down spanner and use that as a guide.. Once its a pretty close fit.. get a hammer and tap it on.. (dont go crazy with the hammer) voila!
naten
campbelltown
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 09:22 Go to previous messageGo to next message
just tried vice grips, cant get them in there to get a good grip on the bitch
tried a file but i dont seem to get anywhere when i file for ages.
GIN51E
Berowra-Sydney
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 11:33 Go to previous messageGo to next message
room for an angle grinder Rolling Eyes
GIN51E
Berowra-Sydney
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 11:36 Go to previous messageGo to next message
get new bolts get a hacksaw and show the bolt who's bos but if hacksaw can't fit get a nice big chissel and hammer and belt it until it snaps
jza70-mel
Perth WA
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 11:55 Go to previous messageGo to next message
Weld another bolt/nut to the head of the first?
rollaboy
Coffs
Re: URGENT HELP! stripped bolt Fri, 13 September 2002 12:19 Go to previous messageGo to next message
Sorry to jump in but as ur on the topic of stripped bolts etc i was going to ask if anyone has any ideas of how to get a alley key bolt that is stripped off my steering wheel as i really need to take it off and theres one crappy bolt that the alley key hole is stripped and i don't really want to have to drill it out.
GIN51E
Berowra-Sydney
Re: URGENT HELP! stripped bolt Sun, 15 September 2002 01:14 Go to previous messageGo to next message
get a hacksaw and cut a groove into the top so you can use a screw driver
rollaboy
Coffs
Re: URGENT HELP! stripped bolt Sun, 15 September 2002 04:28 Go to previous messageGo to next message
Its a bit hard to get a hacksaw in there...i was thinking of hammering a screw driver in very hard then replacing it if i can get it out.
Apollo
Brisbane, QLD, Australia
Re: URGENT HELP! stripped bolt Sun, 15 September 2002 10:06 Go to previous messageGo to next message
This is where a dremel comes in handy. Smile Pity you arn't near me or you could borrow mine.
[Updated on: Sun, 15 September 2002 10:06]
rollaboy
Coffs
Re: URGENT HELP! stripped bolt Sun, 15 September 2002 11:07 Go to previous messageGo to next message
What is a dremel ???
Re: URGENT HELP! stripped bolt Sun, 15 September 2002 14:15 Go to previous message
A dremel is basiclly a small hand held drill that can hold different types of attachments like small drill bits, grinding stones and cutting blades!
As for those rounded bolts, I would do what has already been said! Get another bolt welded on top of it! This works every time without damaging anything!
rollaboy, I'm not exactly sure what allen bolt you are talking about, but does any of it hang out the top so you can get a grip on it with something? If not, you can get small security bits that look like allen bits but they are square! If you can get a size that you can hammer down into the bolt you can then unscrew it with no worries! I have done this a few times! Not on cars but its the same thing!
Previous Topic:Suspension in a front cut?
Next Topic:1JZ-GTE: F*%king Wires!!!!!
Current Time: Fri Oct 23 04:53:01 UTC 2026
Total time taken to generate the page: 0.061777114868164 seconds
