Toymods » Tech & Conversions » car wont stop
DazbaVBZ
Noosa QLD
icon12.gif  car wont stop Sat, 31 July 2004 09:20 Go to next message
MX73 Cressida with the 5MGE in it, just done the head gasket on it and replaced it hooked everything up the way it was now the car wont turn off any ideas, is there a relay that would do this or something, or if i cant fix it where can i put a kill swich on this motor
Toobs
Re: car wont stop Sat, 31 July 2004 10:46 Go to previous messageGo to next message
Usually this happens due to an excessive carbon buildup on your pistons.
Did you check & clean your pistons when you had the head gasket off?
A blown head gasket could have hidden the dieseling problem if it was blown between one of the water jackets and one of your pistons.
Hot Celica
Re: car wont stop Sat, 31 July 2004 11:11 Go to previous messageGo to next message
this could also be that your timing is out, check the simple things first
brett_celicacoupe
townsville NQLD
Re: car wont stop Sat, 31 July 2004 11:22 Go to previous messageGo to next message
you can always conect a wire to the negative on the coil to a button which is connected to earth. this will kill the engine. but best to find out wot is causing it first.
Siktoy ra23
Plumpton/sydney
Re: car wont stop Sat, 31 July 2004 12:54 Go to previous messageGo to next message
check that your thurmo fan is not generating feed back my car had this problem once and it would keep running for about 30 seconds after I turned it off
DazbaVBZ
Noosa QLD
Re: car wont stop Sun, 01 August 2004 00:35 Go to previous messageGo to next message
yeah when i replaced the head gasket, i cleaned all of the coke off the pistons and acid bathed the head and replaced all gaskets etc, before i replaced the gasket i was turning off no probs, now it run fine when you turn the key off the motor increases in revs and you can come back half hour later and its still running, so........ i dont know if i put a kill swich on the -ive side of the coil i wont short anything out?? because its a electronic ignition, timings all in its set around the 12deg mark so its not like a pre ignition,
[Updated on: Sun, 01 August 2004 00:38]
Hot Celica
Re: car wont stop Sun, 01 August 2004 08:04 Go to previous messageGo to next message
are you using a thermal diode on your ignition
DazbaVBZ
Noosa QLD
Re: car wont stop Fri, 06 August 2004 08:15 Go to previous message
to be honest i would nt even have a clue, for that matter what a thermal diode is at the moment ive put a kill swich from my coil to a swich in the cab so...
Previous Topic:3sge g/box
Next Topic:22re pod filters
Current Time: Mon Oct 26 14:22:39 UTC 2026
Total time taken to generate the page: 0.08214807510376 seconds
