Toymods » Tech & Conversions » converting 18R turbo to EFI - update: new turbo manifold
converting 18R turbo to EFI - update: new turbo manifold Sat, 31 July 2004 09:28 Go to next message
hi folks,
update of progress of this rather unique beast (18R with turbo, EFI and digital spark) intake manifold is now welded and assembled.
history: originally was setup as suck-thru carbi in front of a T04 turbo. On it's last cruise (to Dubbo in Easter) it ran uber-lean and i stuffed the ignition timing making things even worse, so the plans for EFIing were brought forward.
progress: Intake manifold (little more than a log with runners) has been modded to accept 4AGZE injectors and now has a throttle body. Fuel rail has been modded to suit the injectors (tho the in/out pipes may have to be changed). Exhaust section of manifod has been removed and new (and better) manifold is being built to suit a t25 (better suited to a 2 litre engine and comes with b/in wastegate).
The plenum isn't quite large enough, and the angle of the injectors isn't ideal either - but i've got limited space to work with so i think it's a fair outcome. The car isn't going to be a daily driver so a smooth idle isn't that important. And with a small plenum, perhaps throttle response is going to be interesting Wink
fwiw: For a mates rate job (i bartered an ECU and wiring assistance for all the welding) i think it looks pretty cool
http://www.mkhala.com.au/thechuckster/18r_efi_parts/18r_efi_parts-Images/2.jpg
The ECU will be a Megasuirt running the fuel and spark. i'll use a temp sensor and the aircon system to directly run an aux-air valve solenoid so - as well an ex-camira aux-air valve doing duties at starup - so the ECU won't do any cold-start idle control but will still do cold-start enrichment.
Most of the parts have now been organised (tho i've managed to loose the pickup for the dizzi in my tool room again) so once the turbo manifold and intercooler piping is in place, we'll fire it up.
thanks to: Ben (people100) for the welding and locating the 4agze injectors; Stewart (oldcorollas) for being the australian Megasquirt evangalist and group-buy oprganiser; Bigworm for the t25 turbo.
pics are here:
http://www.mkhala.com.au/thechuckster/18r_efi_part s/18r_efi_parts.html
(sorry these are small and a bit crappy - i'll rebuild the slide show with larger images and lighten them all)
and pics of the original manifold setup can be found here:
http://members.optushome.com.au/mkhala/red_celica/ motorvation.html
and you can find more thru the link in my sig.
updated to include post on turbo manifold - see pic and links down futher.
cheers,
Charles.
[Updated on: Fri, 13 August 2004 13:45]
people100
Rocklea qld
Re: converting 18R turbo to EFI - progress Sat, 31 July 2004 13:18 Go to previous messageGo to next message
I just hope it works. My other thought if the plenium isnt big enough is we can remove the throttle body and extend the pipe to go across the head to allow maybe 600ml more volume if we find it isnt big enough. that will be heaps easier then removing the existing (plenium). As for the fuel lines we can either try to bend them or i can get them rewelded straight in the ends of the rail but i dont think that will be needed.
Allan
Re: converting 18R turbo to EFI - progress Sat, 31 July 2004 15:12 Go to previous messageGo to next message
will be VERY interesting to see how the non cross flow engine responds to boost!.. now all you need is to source a gear drive setup to replace those friggin' chains!!
Allan
people100
Rocklea qld
Re: converting 18R turbo to EFI - progress Sat, 31 July 2004 23:55 Go to previous messageGo to next message
The car is already turbo'd and has been running with a carb setup for a while now. Ther noncrossflow head is not ideal but considering he has kept the original engine insted of doing a engine conversion the old 18r goes bloody well. Its just a matter of how it will go now as it should go better and lets hope the engine engine can still stand up to it.
SIKRA40
Re: converting 18R turbo to EFI - progress Sun, 01 August 2004 01:00 Go to previous messageGo to next message
Thats a pretty interesting set up you used there. wot did the total efi conversion cost u if i may ask? i was looking at doing somthing simmilar with a sohc 18R that i ahve sitting in my shed, but i mannaged to get a factory 18RGEU with turbo for $500. good luck with all the tuneing etc. hope it all goes well
Dan
CrAiGzEE
south of the big smoke
Re: converting 18R turbo to EFI - progress Sun, 01 August 2004 02:17 Go to previous messageGo to next message
good on ya mate for thinking out side the circle, ill be following your process, hope all goes good
Re: converting 18R turbo to EFI - progress Sun, 01 August 2004 04:01 Go to previous messageGo to next message
massif restepca! Cool
Re: converting 18R turbo to EFI - update: turbo fitted Fri, 13 August 2004 12:33 Go to previous messageGo to next message
hi folks,
New manifold has been fabricated (thanks to exotic exhausts) - trail fitting of my t25 makes it look pretty smick:
http://www.mkhala.com.au/thechuckster/18R_t25_manifold/18R_t25_manifold-Images/0.jpg
there's pics here of the intake side for EFI here:
<http://www.mkhala.com.au/thechuckster/18r_efi_part s/18r_efi_parts.html>
and more pics of the turbo/exhaust manifold:
http://www.mkhala.com.au/thechuckster/18R_t25_mani fold/18R_t25_manifold.html
Dan: total cost is "don't ask - not worth it"... seriously, if starting with a motor suitable for turbo/efi:
- intake manifold (swapped for MS-EFI ECU, wiring help, suspect T04 and labour)
- parts (TPS, TB, temp sensors, O2, FP) $150?
- turbo $350
- manifold & wastegate $650
- MS ECU from a group buy $180
- various electrical and plumbing bits $100
- still to come... intercooler plumbing
cheers,
Charles.
drift86levin
brisvegas
Re: converting 18R turbo to EFI - update: turbo fitted Fri, 13 August 2004 13:33 Go to previous messageGo to next message
what sorta cam are you running in it? that manifold looks F$%##@& awsome!, but it looks like it won't bring the boost on till a fair amount of revs are passed, then it will drop the arse down and boogie! did you try it with a shorter manifold, it could bring the boost on erlier with the larger T04..
Re: converting 18R turbo to EFI - update: turbo fitted Fri, 13 August 2004 13:57 Go to previous messageGo to next message
cam (from memory) is slightly higher lift for both int/exh and has longer intake duration. exh duration is stock to minimise overlap time. Is a 'mild street' cam modded to suit turbo.
i went to smaller turbo (t04 down to t25) to lower spool up time and the rev point where that happens. This new manifold isn't much longer than the previous log unit, but is only 1 1/4 steam pipe (prev was > 1 1/2) so i should have good gas pressure and speed.
This new manifold also has the four runners feeding into the base of turbo instead of into the log, should eliminate issue of exhaust pressure wave from one port, interfering with others (which the log design does suffer from).
this was original manifold:
http://members.optushome.com.au/mkhala/red_celica/pictures/car07-custom-manifold.jpg
prev t04 needed 3k to start making sustained boost (not spiking from vacuum up to 0-2 psi territory) - i want that to lower to about 2500rpm and get ful boost (13-15psi) lower than 4.5-5k rpm
Machina
Ballarat, Vic.
Re: converting 18R turbo to EFI - update: turbo fitted Fri, 13 August 2004 18:24 Go to previous messageGo to next message
hey, chuck, do you still have the old log?
ive got an 18r and a garret tb03 in the garage doing nothing....
might be fun on the ra40....
by the by, what fuel pump setup did you use in the carby setup?
like efi pump+regulator or holley blue ect?
thanks.
M.
Re: converting 18R turbo to EFI - update: turbo fitted Sat, 14 August 2004 03:56 Go to previous messageGo to next message
hi Machina,
old log manifold (if i can find it) goes to Ben - sorry. but it is stuffed anyway (warped and intake bits cut out).
your t03 would be much better suited to an 18R than the big arsed t04 (the t25 is similar size i think?) - but unless you work on lowering compression ratio (mine is at 7.4:1) you'll have massive detonation/pinging problem. cheap way is a spacer plate (not advised) better solution is to attack head with grinding tools but get a pro to do it. In the long run, i'd suggest you chuck a webber on it and maybe extractors - but get a crossflow motor if you want to turbo it as this setup is a PITA for plumbing.
fuel pump was a holley low pressure.high vol (blue i think) near the fuel tank - there was a simple 'bleed' hose leaving the carbi and connected to return line to control fuel pressure - a better solution would have been FPR but seeing as the whole system was low pressure, it did the job...
cheers,
Charles.
Machina
Ballarat, Vic.
Re: converting 18R turbo to EFI - update: turbo fitted Sun, 15 August 2004 08:16 Go to previous messageGo to next message
fair enough.
ill get a head ported out and use my 38DGMS weber [previously from, well, still on, my 2ltr gemini], and find a set of extractors.
im not too keen on spending a great heap on the 18r, its a heap.
i think ill use the t03 on a single turbo 1G, or 18-RG if i can find one.
thanks anyways,
M.
Bradelz
Tamworth
Re: converting 18R turbo to EFI - update: new turbo manifold Mon, 16 August 2004 09:35 Go to previous message
hey dude,
lol what car is this beast in?
brad
Previous Topic:My new 18RG head **now with pics**
Next Topic:URGENT - 2Y Wiring Diagram
Current Time: Fri Nov 20 20:56:58 UTC 2026
Total time taken to generate the page: 0.0090150833129883 seconds
