Toymods » Tech & Conversions » can it be? 18r-ge
brett_celicacoupe
townsville NQLD
can it be? 18r-ge Sat, 31 July 2004 10:58 Go to next message
hi
i was wondering if anyone would know if this would work or has been done. would a 18r-geu (low compression engine) head be compatible and fit to a 18r-g (higher compression) block without there being any clashes etc? would this be a good combination?
i thought this maybe good seen as 18r-g block has the higher compression and the 18r-geu has the big valves and fuel injection
any opinions or ideas would be appreciated
cheers brett
people100
Rocklea qld
Re: can it be? 18r-ge Sat, 31 July 2004 13:09 Go to previous messageGo to next message
AS far as i know it should be a straight swap but the only ones with high comp are the first of the rg's i think. Make sure its the high comp one or its just a waste of time.
Re: can it be? 18r-ge Sun, 01 August 2004 05:43 Go to previous messageGo to next message
88230 is the casting to look for.
omegaman
SYDNEY
Re: can it be? 18r-ge Mon, 02 August 2004 08:00 Go to previous messageGo to next message
I've just done pretty much just that.I've put 9.7.1 pistons in an 18rgu block and an 18rgeu head 88270. Blocks are all the same just comp are different for each variant motor. The valve clearance was questionable. But once fitted and checked clearances were good.I have not started it yet, maybe next week. Though I will put a piggy back computer in it because off the cams used 88231 18rg, might run a bit funny without this and premium fuel to be used.
blackRA28
adelaide
Re: can it be? 18r-ge Wed, 04 August 2004 02:34 Go to previous messageGo to next message
id be quite interested to hear how she goes Cool so your using both the earlier 18RG hi-comp cams but with the factory efi? i always considered doing this but $$ has stopped me dabbling with a project engine... Sad
brett_celicacoupe
townsville NQLD
Re: can it be? 18r-ge Wed, 04 August 2004 10:44 Go to previous messageGo to next message
nah mate just curious, i havent done it
people100
Rocklea qld
Re: can it be? 18r-ge Sun, 14 November 2004 03:13 Go to previous message
THE WITZL wrote on Sun, 01 August 2004 15:43
why do u say that its the one to look for???is this the best of the heads??? high compression engine etc???
Previous Topic:Taking out 4AC help
Next Topic:dont read (all sorted)
Current Time: Wed Nov 18 15:44:31 UTC 2026
Total time taken to generate the page: 0.0054299831390381 seconds
